Old 28th March 2006, 22:55   #1
subwoofer + optra OE system?
hi guys
i got a sony xplod sub+amp and would like to fix it to my optra royale
thing is i dont want to disturb existin OE head unit (its good) and my speakers
any experiences in getting the OE double din head unit to work wit the sub?
anything i gotta look out for?
thanks
PS: the OE headunit dosent have subwoofer controls!
xtr21 is offline
Old 29th March 2006, 10:58   #2
panky12345's Avatar
Thanked: 172 Times
which sub + amp combo have u got?
IMO, i think u'll be just fine with ur OE HU....but u'd be definitely needing a pair of 6 X 9 or comp else, the sub would take away ur mids and highs and leave with just low note thumps....
so, go ahead and change ur speakers as well. as for HU and amp, they should be compatible beacuse of the speaker level inputs.
u just dont need anything else, but yes a good installer (as ever)
panky12345 is offline
Old 29th March 2006, 11:31   #3
navin's Avatar
Thanked: 9,998 Times
Most probably the HU does not have RCA line out. If it does you are in luck.
and if so does your amp have a Low pass crossover in it? if this is true all you need ot do is run a paid of RCA from the HU to the amp switch on the Low Pass Crossover and connect the sub to the amp.
Now if you dont have either....
You will need a speaker level to RCA level adapter. then use the rear speaker out and connect this adapter across the rear speaker out. connect the adapter to the amp and let your subs run fullrange. Not as effective but the inductance of the sub will act as a slow filter.
navin is offline
Old 29th March 2006, 19:44   #4
thanks guys
will goto car decor (bangalore) and get those guys to work on it
xtr21 is offline
