Old 15th August 2006, 14:04   #1
~ H O N D A ~'s Avatar
Thanked: 9 Times
ICE for OHC
I have a JVC DVD player HU im my OHC.
I had a pioneer im my car which i removed and installed this JVC DVD HU.
The front speakers are company fitted. had installed a 10 inch woofer and pioneer rear speakers...
Im planning to change all the speakers including the Ampli as i had bought this when i was in college 5 years back.
Guys plz suggest which configuration should i go for...
Which Ampli ???
Which Woofer ???
Wat Size ???
Which Component ???
Which Rear Speakers ???
Plzzz help me out guys....
Cheers !!!
~ H O N D A ~ is offline
Old 17th August 2006, 01:15   #2
amit_sound's Avatar
Thanked: 11 Times
According to your signature please allow us to make you "go broke methodically"....
amit_sound is offline
Old 17th August 2006, 01:25   #3
iraghava's Avatar
Thanked: 281 Times
^^^ Apart from that please describe what kind of music you like eg. Pop, Rock, Reggae etc. & also whether you are interested in SQ ir SPL or are you a bass head or a combination of the above??
iraghava is offline
Old 17th August 2006, 09:08   #4
prince85's Avatar
Thanked: 123 Times
And how much are you willing to spend??? Ur budget bro???
prince85 is offline
Old 18th August 2006, 13:02   #5
Thanked: 9 Times
im very much a HIP HOP listner
Im planning to spend around may be 10 - 15 K for the ICE as i already have a HU....
Old 18th August 2006, 13:53   #6
Thanked: 29 Times
Originally Posted by ~ H O N D A ~
Which Ampli ???
Which Woofer ???
Wat Size ???
Which Component ???
You cant buy all these with the above mentioned budget. Changing one or two at a time will suit you fine I think.
Does your HU have 3 pre-outs?
If yes, get a nice 4 channel amp and a set of component speakers. Hertz is my choice for compos. If it wont fit in your budget then get JBL 507. Bang for the buck!
You said you have a 10" Subwoofer. Stick with it for the time being. You can power it using your old amp. But what amp it is? I think it should be a 2 channel. If you think it has done it's job and it's time for burial grounds, then power the sub from 2 channels of your new amp and the other 2 channels for compos.
Get Hertz co-axials for rear. 6.5" will be sufficient.
4 channel amp = 6k (Sony)
5.25" Hertz compos = 5.8k
6.5" co-axials = 3k (Hertz or JBL)
This will keep you in budget and later you can go broke methodically!
speedzak is offline
