Team-BHP - DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade
-   In-Car Entertainment (https://www.team-bhp.com/forum/car-entertainment/)
-   -   DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade (https://www.team-bhp.com/forum/car-entertainment/236071-diy-bmw-3-series-f30-head-unit-nbt-evo-upgrade.html)
Back in early 2019 - The stock head unit(HU) of my 2014 F30 began malfunctioning - It was stuck on BMW Logo as can be seen in the image below -
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-bmw-logo-stuck.jpg
As the car was out of warranty BMW quoted around 1.5L to replace the unit and rectify the issue. I asked if they could upgrade the HU to something with carplay and to no ones surprise I was told that was impossible - If I wanted carplay then I would have to purchase a new vehicle. I was not willing to pay such a huge amount for simply fixing the basic and featureless system my car came with and therefore decided to deny BMW the repair to look for 3rd party & DIY options that were either cheaper in terms of price for the fix or gave me an upgraded system. Below is a conclusive list of the options I came across over weeks of research -
Options for fix
1. China Android Based System 10.25" - REJECTED This was the first option I came across and it exited me because of the cheap cost of around $300 and the large feature set it offers. Quality may not be very great however seemed very worth it for the price. Rejected because I realized these systems require a working OEM HU to interface with. There is also concern for long term reliability.
Decided OEM was the only way I wanted to go. My car came equipped with an HU_Entry CIC system (OEM Part 65129270363 9281518)
2. Replacement OEM HU_Entry - REJECTED Found this with great difficulty online in china for $75 used (Yes, you read that right) + Shipping/Tax. This would require a DIY install. Additional costs would include professional coding service @ $75, Hardware Emulator @ $50 & OBD Cable @ $10. All in I would be able to fix the system for under INR 20k to factory condition. While this would have been a great option - By the time I found this used part - I was in too deep for option 3 and the itch for retrofitting a better system had already taken hold.
3. Retrofit a newer OEM HU - Realized it is possible to retrofit the latest OEM systems from BMW into my car. The different generations of systems in BMW cars can be seen in following image. I obviously wanted the latest and greatest compatible with my car -
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-bdzhg62apfiqhw6ocsklcop4zywonb_2g.jpg
3a. Plug & Play Retrofit - REJECTED There were only very few international companies that offered a complete plug and play solution for the same. I reached out to them and got some quotes. Please note that these options still requires DIY opening of dash and unplugging/replacing HU/Screen and USB. Includes remote coding thru TeamViewer. One need not worry about VIN emulation / ATM emulation / coding / cable harness pinout or parts compatibility.
NBT Evo ID 5/6 - $2500 + Shipping + Tax = ~ INR 2.5L (2GB Model - Non Touchscreen)
NBT Evo ID 4 - $1500 + Shipping + Tax = ~ INR 1.5L
Rejected this option because I thought the cost was a little on the higher side as individual parts could be sourced cheaper if bought separately. After having done this project and experiencing the technicalities and nuances involved - I believe the cost these integrators charge is somewhat justified.
3b. Complete DIY Retrofit - ACCEPTED Even though I had never worked on a car in any capacity in my entire life (Not even changed a as much as a wiper blade) - As my research progressed- I got more and more confident in doing the entire retrofit myself - Got up one morning and decided I was going to risk it and if things went south then that would just be the cost of learning - Decided on a budget of INR 1.5L (Cost BMW had initially asked) and I would do the best I could within that. After months of scouring for parts that were both compatible and affordable - I finally had all the parts I needed for the retrofit. I even managed to squeeze in an OEM Backup Camera in my budget. Below is the final parts list including Estimated/Actual & Total cost - (eBay - Shades of Blue, Aliexpress - Orange)
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-nbtevocost.jpg
Please note here that there are multiple versions of the Head Unit - There are 2GB/ 4GB and GPS Inbuilt / GPS not Inbuilt - You should look for 4GB with GPS Inbuilt. The additional RAM is great as 2GB versions are known to crash often on ID6 software . It is fine if you plan to remain on ID4/ID5 though. GPS Inbuilt is great to have as one would not need to emulate ATM which adds both cost and complexity. If your car already has an ATM module, this might not be much of a concern. Mine did not.
There are also 2 versions of the screen - Touch and Non Touch.
The Retrofit
Finally one rainy Sunday in July 2019 after all the parts had arrived (took more than 2 months), I went to a friends enclosed parking area to start the retrofit process. Followed several youtube videos and eventually got everything disassembled and then installed, tested & programmed. At the end of the day, I had carplay working however I was unable to get any car information on the Idrive display as I could not update the car firmware as I needed a special cable. I left the car in this state as I didnt really need anything else and didnt have the time.
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-img_5076.jpg
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-399d43677e8949ea9ca973e1a457d1a3.jpg
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-55e7c732bce14f26ae97d53fb7a11153.jpg
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-cf3fafb6927b40a88bc38e2b976fe179.jpg
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-b0bab14f0e6e49b8814b02c0f453daf7.jpg
DIY : BMW 3-Series (F30) Head-Unit NBT EVO Upgrade-img_5106.jpg
Fast Forward to Jan 2020 and BMW refused to carry out maintenance because no DATA - So decided to 3d print and make the harness - Put in the new FW - Attached the OFC and voilla everything showed up. Project was finally complete.
Additional Coding
DRL
Disable Auto Start Stop function in ECO mode
Sport+
No Warnings
Video in Motion
Digital Speed in Instrument Cluster
NBT Sport Displays
cluster M Performance logo
cluster Start logo
NBT Pressure and temperature in tyre pressure monitor
NBT Start animation nbt Connected Drive 1
NBT Volume popup enabled
Convenient Closing
Maximum volume at start-up 2-%
Warning Chime/ Ringtone
Questions I had (FAQ)
Will Connected Drive (Remote lock/unlock) work? No
AM/FM Antennas allready there? Yes
BT/Wifi GPS from Aliexpress work fine? Yes
Do I need to worry about ZGW (Kcan1 vs Kcan2)? No
Do I need MOST Loop for my Combox? No
CIC Pinout, NBT Evo Pinout Diagram? Same
Test Bench available in Mumbai? No
Bluetooth Mic Needed? No
Will USB work? Yes
Touch Controller uses CAN2? Yes
I have been a forum reader here since 2014 and had actually decided on buying this car looking at posts here. Thought you guys may enjoy my journey and it is my hope this thread inspires/helps someone. Please feel free to post any query in the thread or PM me. Will be happy to help all and answer any questions. Started writing this in 2019 and am finally posting now.
The retrofit added a good 3 years of life to this vehicle. I recently upgraded to a BMW 630d M Sport.
This is fabulous! I have the same headunit in a 2014 BMW 3GT and the screen has now developed an ugly splotch in the center. I was just this morning considering contacting the FNG about this - and your post pops up. If you don't mind I would like to take your jelp in this if I develop the courage to go ahead.
Yes of course, would be happy to assist in any way. Feel free to PM me. Furthermore, I think I still may have my old screen somewhere in storage, happy to just give it to you if you want an easy plug and play fix.
Thank you so much. I'm still trying to figure out PM here on this forum. How do I get in touch with you regarding your old screen? (If you still have it).
PM function is not available as you both are still under Newbie membership level. One of you can share your email address by posting here itself. This is what I have observed being done at times.
Whenever you can please email me at doctortraveller at gmail. Many thanks.
Hi Y2S this is a brilliant read. I recently stumbled upon this thread. Are you still using your F30 and how has the experience of the new head unit been? I am planning to suggest my friend using an 118d to do something similar.
Looking forward to your response.
Hi, please feel free to ask any questions on the thread, so that anyone that viws this may benifit.
No, I have recently upgraded to a 630d. The experience with F30 was flawless, pretty similair to my new 2024 car which is 10 years newer. Definately worth it if you plan on keeping the car for the forseeable future.
Thanks Y2S, it would be great if you can share the links/ details buying the new screen/ head unit here. Will try to source from the same place/person.
HI!
I have a 2014 320d F30 with Hu_Entry.
can you please mention from where did you get the replacement head unit?
And other parts too.
Thanks!
Hi!
I have the same problem mentioned in this thread.
My F30 320d 2014 Hu Entry screen is frozen on BMW logo, I recently purchased this car pre owned.
I have purchased a good Xtrons android screen / head unit.
As per my research on various forums, these screen need a function head unit to route the sound through AUX port. Now when the head unit is frozen, I suspect the sound routing wont work (I am yet to fit and check the android unit as it arrived only a couple of days back).
I am not interested in the original idrive functions, my only requirement is routing of the android unit sound to car speakers, can this be done by connecting the android sound output directly to the car amplifier, effectively by passing the head unit?
P.s: I even tried to get a used HU entry on ebay but no luck so far
