Old 30th January 2008, 14:46   #1
nishantgandhi's Avatar
Thanked: 156 Times
Amplifier questions
While researching about amplifiers on WWW, I came across this article on ebay
Car amplifiers boost the signal your stereo sends to your car speakers, driving your speakers with an independent power source. There are three types of car amplifiers: mono, two-channel, and four-channel.
  • Mono car amplifiers: Mono amplifiers power a single speaker.
  • Two-channel car amplifiers: Two-channel car amplifiers boost the signal to two speakers and a subwoofer.
  • Four-channel car amplifiers: Four-channel car amplifiers boost the signal to four speakers and two subwoofers; two speakers and a single subwoofer; or any configuration in between.
Just out of curiosity, whats the need for mono amplifiers if they power a single speaker? Theoretically speaking, speakers come and are installed in pairs. So why would you need to install a mono amp?
Another question - if I go for a 2 channel amp, instead of boosting the signal to two speakers and a subwoofer, can I use it to boost signla to ONLY 4 speakers? (Front+rear), as I have no plans for a SW.
nishantgandhi is offline
Old 30th January 2008, 16:11   #2
Bass&Trouble's Avatar
Thanked: 137 Times
Thats quite a lame explanation of amplifiers even if intended for the absolute novice.
Some people want to power a single speaker sometimes, like a subwoofer. A sub is also a speaker na?
Bass&Trouble is offline
Old 30th January 2008, 16:33   #3
shuvc's Avatar
Thanked: 359 Times
Yes you can.
8 chars.
shuvc is offline
Old 30th January 2008, 16:46   #4
Thanked: 321 Times
Even a 2 channel amp will power all your 4 spekers but you wont be able to use the fader and for that function you need a proper 4 channel amp.
Ajaybiz is offline
Old 30th January 2008, 17:00   #5
can a 4 channel amp power 4 speakers and a sub and still have an option of fader??
deepak_ms is offline
Old 30th January 2008, 17:18   #6
shuvc's Avatar
Thanked: 359 Times
No.
2 channels of the amp would ideally be joined (bridged) to drive the sub.
That leaves 2 other channels free. These can power the 2 front speakers.
OR
One of the channels can power left side speakers (front & rear)
Another channel can power the right side speakers (front & rear)
In these cases, the wires for the front and rear speakers of a particular side are connected to the same +ve & -ve output channel of the amp. Since the same output is driving front and rears, fading is not possible.
That's as far as my understanding goes.
shuvc is offline
Old 30th January 2008, 17:32   #7
Thanked: 156 Times
Originally Posted by shuvc View Post
One of the channels can power left side speakers (front & rear). Another channel can power the right side speakers (front & rear)
Is this the usual setup? I used to think that Front speakers and Rear Speakers are powered, as a PAIR by 2 channels of the amp, rather than Left and Right being powered as a pair.
Hence fader option would work!
Old 30th January 2008, 17:38   #8
Thanked: 156 Times
A quick question - does it matter WHAT is the type of speakers? I mean, is it NECESSARY to use an Amp for Coax speakers? Or is it necessary for component speakers only?
I have read in other posts on the group that front components were powered by a 2 channel Amp while rear coaxs were powered by the HU. Any specific reason for such a setup?
Wouldnt an IDEAL setup require ALL speakers to be powered by Amp(s)?
Old 31st January 2008, 11:01   #9
DerAlte's Avatar
Thanked: 2,920 Times
Yes, it would.
Powering the rear-fill coaxes from HU saves money without compromising on front SQ.
And no, both components and coaxes do better with an amp.
DerAlte is offline
Old 31st January 2008, 11:33   #10
Thanked: 306 Times
Because the HU amp is not capable enough to drive the speaker to its max capacity.
low_bass_makker is offline
Old 31st January 2008, 13:38   #11
shuvc's Avatar
Thanked: 359 Times
What I mentioned was 1 pair (L+R) amp output channels driving 2 pairs of speakers. Whether you pair LHS/RHS speakers or Fronts/Rears fader will still not work.
Because fader from the HU works on the, how shall I say it, input to the amp. The Amp gets 2 inputs from the HU. One of them for the 'Fronts' another for 'Rear'.
Now if you have connected the sub to the 'Rear' output and the 2 pairs of speakers to the 'Front' output , then your fading will be between
1. All 4 speakers playing, no sub
2. Only sub, other 4 speakers khamosh
shuvc is offline
Old 31st January 2008, 14:22   #12
Thanked: 156 Times
So if I dont have any sub in the setup, then the fader option should work, right?
Old 31st January 2008, 15:55   #13
panky12345's Avatar
Thanked: 172 Times
Opt for a 4 channel and Pio 7950 HU (or any HU with a sub out) and faders would work good with an option of turning the sub off.
panky12345 is offline
Old 31st January 2008, 19:18   #14
adityamunshi's Avatar
I have another question about amps, Other than making the music louder, how does the amp help ?
In the context of my setup, (four speakers running off the HU) what will be the difference at the same volume ?
adityamunshi is offline
Old 31st January 2008, 21:04   #15
jkdas's Avatar
Thanked: 1,497 Times
its like adding a Pete's box. More headroom.
and loves people with good bank balance.
To feel the difference, listen to a good setup.
jkdas is offline
