Old 24th April 2009, 11:48   #31
Invinsible's Avatar
Thanked: 62 Times
Originally Posted by Bass&Trouble View Post
You competed in the amateur group or professional?
Dont exactly remember which category, i guess it was both. My car was presented by Umanath Shetty.
Invinsible is offline
Old 24th April 2009, 11:52   #32
Technocrat's Avatar
Thanked: 2,705 Times
Invinsible: Great explanation thanks Btw which car was this setup in?
Technocrat is offline
Old 24th April 2009, 11:54   #33
amps in the same class, whether monobloc or 2 channel (bridged) - output (if same rms) is the same (cleanliness, power etc)
the advantages of a monobloc are
it has a bass control
it's built for powering subs thus has a higher 'safety cut-off'
guns666 is offline
Old 24th April 2009, 11:55   #34
karankapoor's Avatar
+1
great you came 3rd, what all equipment you used.
karankapoor is offline
Old 24th April 2009, 12:13   #35
As for as Monoblocs are concerned, 2 mojor differentiators I found are:
1) Usually monoblocs are class-D amplifier, hence great power efficiency.
2) Subsonic filters, meaning more fine tuning of sub with enclosures. Especially, very useful in Ported Enclosures. It avoids distortion caused by subsonic frequencies (the ones that we can never hear, but feel and many subs fail to reproduce those freq.) by setting the pass filter on enclosure's tuning frequency and thus cutting the frequencies below that.
Other advantages can be, as the monobloc is designed for purpose of powering the sub, they usually have good Bass Boost circuitry. Apart from these, I don't feel any other edge monobloc gets over bridged 2-channel amp.
And also, as LBM rightly pointed, damping factor should make lot of sense at low frequencies. But, I am yet to experience it.
Raghu-A4U is offline
Old 24th April 2009, 12:14   #36
Invinsible's Avatar
Thanked: 62 Times
Originally Posted by karankapoor View Post
+1
Had blaupunkt in dash cd/mp3 player, velocity comps at front and coax at rear with Alpine 4 & 2 channel amp, with Alpine Sub. I suppose there was certain condition to enter where one needed certain amount or certain equipments of blaupunkt. All this was in a Lancer.
Old 24th April 2009, 12:41   #37
valhallen.282's Avatar
Thanked: 196 Times
frank sq honestly is a personal professional opinion and varies from judge to judge. but the idea is to get the sound image, tonal balance and harmonics right. where positioning as on a stage while retaining instrument clarity is important. lets take a cliche example. if i were to listen to the eagles hotel california on either studio monitors or headphones you would be able to tell each instrument's PRECISE location. the idea is to emulate that as much as possible in your vehicle while not losing track of the tonal quality. another thing if i remember right is to get just enough bass and treble into the picture while not making it too emphasised or overpowering. but as i said it varies from person to person. imaging is by far the most important.
valhallen.282 is offline
Old 24th April 2009, 18:58   #38
hydrashok's Avatar
Thanked: 19 Times
As others have pointed out, Class AB amps are more musical. Class AB amps concentrate more on detail and musicality, while Class D amps concentrate more on putting out raw power.
Originally Posted by frankmehta View Post
...How does one measure SQ? and how does the scoring for the SQ go? i know dB readings are like the score for SPL competitions. How does it go for SQ?
Here is the USACI rule book for judging SQ Competitions: http://www.soundoff.org/supportfiles/09sqrules.pdf
The USACI scoring sheet for SQ competitions: http://www.soundoff.org/supportfiles/BASICSQ09WEB.pdf
These two together should give you an idea
No idea about the IASCA rules -- had tried earlier on to get a copy of the rulebook off the 'net, but I couldn't find it.
hydrashok is offline
Old 24th April 2009, 20:27   #39
frankmehta's Avatar
Thanked: 3,668 Times
thank you guys! thank you hydra ji!!
frankmehta is offline
Old 24th April 2009, 20:46   #40
govigov's Avatar
Thanked: 1,222 Times
so a good 4 channel AB class amp gives better SQ than a class D mono (and)
a good class D mono is better in SPL than a good 4 channel class AB amp.
am i correct?
govigov is offline
Old 24th April 2009, 21:01   #41
frankmehta's Avatar
absolutely! thats the general consensus.
Old 24th April 2009, 21:08   #42
abhinav.gupta88's Avatar
Thanked: 341 Times
Um.
There are some 2 channel and 4 channel amps which are better than many monoblocks.
Of course no use posting the names of Steg / Genesis/ DLS etc as they are way above the list.
As per my hearing ability too, a 2 channel amp bridged is more musical than a monoblock
abhinav.gupta88 is offline
Old 24th April 2009, 21:23   #43
Thanked: 4,910 Times
between a class AB mono and bridged setups, I'd think the mono would be more musical
greenhorn is offline
Old 24th April 2009, 21:27   #44
frankmehta's Avatar
greenie, have some more details? would love to see the equipment you compared.
Old 24th April 2009, 21:28   #45
Thanked: 341 Times
I was talking about the Class D.
Should have mentioned
