I will be getting my civic A/T next week. Is it possible to have a addon steering wheel audio control for the audio system that comes factory fitted with civic A/T. Also do you think it's a good idea to do so as it may screw up the airbags system. I have seen a product from pac audio but it comes with wires. Is there a wireless option available? please advise.
thanks for reading.
Dear Mahesh
Doesnt the Civic A/T comes with Steering audio controls by default? and if you take the PAC, its only the adapter but not the steering buttons.
Originally Posted by MaheshNarayanan
(Post 1765749)
thanks for reading. |
The wires from the PAC SWI unit will cause no hindrance to your airbags/steering, You are only going to connect the wires which are already present from the stock system to the adapter
Civic A/T does not come with steering controls.
sorry i am a noob don't understand abbreviation. so what you are saying is that the switch comes separately. Do i need to buy the adapter from pac and switch from a different manufacturer? Can you please suggest some shop in delhi where I can get these and also the approx price. Also i did not understand the wiring part . Will the wires go through the steering wheel or would they stick out?
Best thing you can do is to source an OEM steering wheel (which comes with all the mounted controls) from Malaysia and connect the steering mounted controls to the HU in place of the rear audio controls.
mkc15 I enjoyed the post you wrote about your honda Civic A/T experience. Congratulations on your dream car!!
I would like to know weather you feel the need for the steering mounted controls. Are they really necessary?
This car is the most valuable posession i have so i would like not to do any major changes like the one you suggested. I will go through it only is it is small change (cosmetic) costing not more than Rs.3000. I surely don't wanna screw up the balance. I wonder why honda misssed out on this. Do they have a valid reason? I don't think they did this to cut cost.
It is possible to just import the switch gear from the US. You have to get a HELMS manual or similar to disassemble the steering wheel and then connect the wiring to the airbag wiring spool. You'll then have to create the wiring on the other side to the stereo. It's generally all plug and play. You just have to do some connector pinning on both sides.
It is not a job for the faint of heart. But it is still a DIY and is pretty straightforward if you're good with electrical/electronic work.
(Post 1766532)
This car is the most valuable posession i have so i would like not to do any major changes like the one you suggested. I will go through it only is it is small change (cosmetic) costing not more than Rs.3000. I surely don't wanna screw up the balance. I wonder why honda misssed out on this. Do they have a valid reason? I don't think they did this to cut cost. |
Thanx. Congrats on your Civic. I miss the steering mounted controls a lot; in fact, who won't? Honda didn't give it for cost factor ofcourse. If HU doesn't support more than 1 ext. control, they could have given a better HU (with steering mounted controls and wireless remote):D
Originally Posted by ImmortalZ
(Post 1766683)
It is not a job for the faint of heart. But it is still a DIY and is pretty straightforward if you're good with electrical/electronic work. |
i have searched lot of threads on civic on team bhp still haven't found someone who has done this successfully ? has anyone done in this forum, if so can you give details of whats what ?
who doesnot want steering mounted controls for audio !!! ? Honda is tight lipped on how they could miss out in their CIVIC, if there is one thing i would like honda india to do in their CIVIC is add the steering mounted audio control first, and provide a option for existing owners to upgrade as well.
Originally Posted by penpavan
(Post 1769629)
i have searched lot of threads on civic on team bhp still haven't found someone who has done this successfully ? has anyone done in this forum, if so can you give details of whats what ? |
Here you go ! Check this link:
http://www.team-bhp.com/forum/modifi...ml#post1428016
As you rightly said, who does not want steering mounted audio controls ? :D The steering in the picture looks so complete !
Search 8thcivic.com for a complete guide on how to do this. Currently the remote audio control connector on the HU is connected to the rear hand rest controls. You have to disconnect this to connect the steering mounted controls. It is not possible to have them both simultaneously.
Honda simply concluded that Civics in India are chauffeur driven more often than self driven.
(Post 1765749)
Is it possible to have a addon steering wheel audio control for the audio system that comes factory fitted with civic A/T. |
I've been searching for the same thing myself.
My pre-worshipped Civic is a 2006 V/AT model - there were no audio controls on the steering at the time.
Honda guys have no clue as to whether they can supply the buttons or whether they can be installed.
But after searching, I came across this -
HondaPartsNow
Can anyone confirm if this is actually the correct part?
If so, is any additional wiring or harness needed for the same - or just the switch will do?
A quick thought - wont the City's steering mounted audio control switch not be a direct fit on the Civic ?
Originally Posted by rr_zen
(Post 2684345)
A quick thought - wont the City's steering mounted audio control switch not be a direct fit on the Civic ? |
They definitely would, thats what I have on my car's steering. :thumbs up
