Old 25th June 2012, 08:14   #1
ACMohan's Avatar
Thanked: 1,063 Times
DIY: Headlamp Bezel Painting (Maruti Swift)
I've painted the headlamp bezels of my Swifty in black. The pictures will explain this DIY. I'm a newbie here. Suggestions and comments are welcome.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0661.jpg
The bumper was first removed.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0662.jpg
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0666.jpg
Headlamp assemblies are removed.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0668.jpg
I used hot air gun to soften the silicon gum and a screw driver to open the assy.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0669.jpg
The bezel was screwed on to the case with two screws and they were removed.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0670.jpg
Bezels were cleaned and rubbed using fine grit sand paper. Indicator reflector was masked (using masking tape). And the first coat was given.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0671.jpg
After the second coat.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0672.jpg
After the third coat.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0673.jpg
Headlamp assy. resealed by melting the existing silicon gum.
And it looks like this.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0813.jpg
This is the Hot Air Gun, I used.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0814.jpg
And here's the Spray can.
ACMohan is offline   (15) Thanks
Old 25th June 2012, 09:58   #2
Thanked: 20,625 Times
re: DIY: Headlamp Bezel Painting (Maruti Swift)
How is the end result like?
Also, due to the assembly being painted black, do you notice any loss in illumination? (I believe the assembly would play a small part in reflection)
libranof1987 is offline
Old 25th June 2012, 10:12   #3
ACMohan's Avatar
This is how my car looks now.
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0812.jpg
Didn't notice any loss in illumination. But of course, there will be some loss in reflected light. But not too much, I suppose.
ACMohan is offline   (9) Thanks
Old 25th June 2012, 10:58   #4
ninjatalli's Avatar
Thanked: 17,793 Times
Attachment 946640
Not at all a bad job. But can you post an un-processed closer look of your headlights? Can give us guys a better idea on the end output.
Also any changes done to the rear lights? I feel they'll really come out with the above/similar setups!
ninjatalli is offline
Old 25th June 2012, 11:16   #5
srishiva's Avatar
Thanked: 2,260 Times
Great work. Can you post the headlight without reflections?
Guess the loss will be minuscule and there might be a reason why you see such things on projectors or reflectors that are ahead of such areas.
Hope they are still water tight !
srishiva is offline
Old 25th June 2012, 11:29   #6
97_Octane's Avatar
Thanked: 93 Times
Very nicely done ACMohan! Gives a meaner look to the car.
I don't think there should be any difference in illumination since the reflectors have not been altered right?
97_Octane is offline
Old 25th June 2012, 12:14   #7
ACMohan's Avatar
Thanks ninjatalli. Here's another picture, unprocessed one.
And nothing is done on rear lights.
Yeah, Still water tight (I hope ).
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0680.jpg
ACMohan is offline   (2) Thanks
Old 25th June 2012, 12:58   #8
ryan_wheelz's Avatar
Thanked: 41 Times
WOW ! they look amazing,the alloys go really well with the headlamps !
How much time did it take you ? & can a hair blower be used as an option in place of the hot air gun.
This kind of job will cost around 1500 bucks here .
Plz post some more pics taken in the shade.
Thanks for sharing.
Rgds
Ryan
ryan_wheelz is offline
Old 25th June 2012, 15:52   #9
dZired's Avatar
Thanked: 8,000 Times
Re: DIY: Headlamp Bezel Painting (Maruti Swift)
Thats a great job done. Gives a masculine look to the swift.
Kindly post some more pics without any reflections on the headlamps clicked preferably from the height of the bonnet.
I am quite concerned though that the headlamps may have a leakage now.
dZired is offline
Old 25th June 2012, 16:12   #10
Thanked: 396 Times
Hey, good job on that, but there is a possibility that you might have to open the lights all over again because the paint may start flaking off. There are 2 things that you should have done :
1. After the sanding, you should have used a plastic primer coat before the paint.
2. You should have used a high temp paint if possible.
I had tried similar stuff when fitting projectors onto a friend's car. The paint starts flaking off soon.
Also, since you have not put in projectors, the reflected light and hence hear will be a bit more in the painted area (as against projectors), so the paint will start flaking off.
So, you can either wait for a few days to see how it goes or take precautionary measures right away!
keyur is offline
Old 25th June 2012, 17:43   #11
ACMohan's Avatar
Thank you 97_Octane.
I don't know if a hair dryer can be used in place of hot air gun. Temperature of 300-400 degree is needed, I think.
Thanks dZired. Yeah, will post the picture without reflections later.
I've driven the car in heavy rains after that. And still there's no leak.
Thanks keyur for the valuable input.
I asked the same questions to the paint dealer and a local painter. They said that this paint is heat resistant and will not flake off. I even asked about the plastic primer, but they said there is no need for that.
So let's wait for some time and see whether it goes.
ACMohan is offline
Old 25th June 2012, 17:51   #12
mayankk's Avatar
Thanked: 8,618 Times
I dont think he needs to worry.
Did the same thing a couple of months ago, with practically no sanding, and very el-cheapo paint, as was pointed out to me.
nothing's flaked off till now.
I think there was another BHPian who wanted to do this for his swift on my thread.
Will point him here,I think he'll be happy to hear of this.
mayankk is offline
Old 25th June 2012, 18:13   #13
Schoudhury's Avatar
Thanked: 483 Times
I also got the headlamps smoked few months back for my Ritzy , though it was not DIY , the paint looks fine till date, don't see any issues with it .So i dont think you will have to worry about it .
DIY: Headlamp Bezel Painting (Maruti Swift)-dsc_0009-custom.jpg
Schoudhury is offline   (2) Thanks
Old 25th June 2012, 19:26   #14
ACMohan's Avatar
The fiesta headlamp painting thread,right?
That was a source of inspiration for me.
The headlamp looks nice. How much you have paid for that?
And did they use any primer before painting?
Old 25th June 2012, 21:44   #15
Schoudhury's Avatar
Thanked: 483 Times
Paid 2k for the same , not sure if they used primer or not .But as i posted earlier also ,the paint looks fine till date ( touchwood).
Cheers.
