Team-BHP - DIY: Paintless dent removal via the Glue gun method
-   DIY - Do it yourself (https://www.team-bhp.com/forum/diy-do-yourself/)
-   -   DIY: Paintless dent removal via the Glue gun method (https://www.team-bhp.com/forum/diy-do-yourself/191666-diy-paintless-dent-removal-via-glue-gun-method.html)
Few weeks back, I took the car to a car cleaning place and parked it at the entrance. Some biker (while taking his bike out) reversed into my car's rear door. There was a small dent/ding on the door. I looked around on the interwebs and found this glue gun method to remove a dent. Found this pop-a-dent kit on Amazon. It was just 498 rs + shipping, so thought of trying it out.
Amazon product link - http://amzn.in/4O6VmxZ
I have made a video of the whole process.
https://youtu.be/ZVkUld3pSyU
The kit comes with the following things:
First clean the surface with acetone and water to remove oil/wax.
Select the right size of pulling tab and apply glue on it.
Press the pulling on the dent, leave it to dry for 2-3mins, no longer than 8 mins the box said or it may damage the paint.
Then use the pulling bridge and turning knob to pull it out.
Its a long process and you will need a lot of patience, I did it around 25 times and left when the dent was reduced to the size of a pea. But it does work!
It may not work if the dent has a strong crease. If the paint has chipped off, then don't try this method, you might end up damaging the paint more.
Originally Posted by Rahulkool (Post 4292200)
Few weeks back, i took the car to car cleaning place and parked it at the entrance. Some biker while taking his bike out, reversed into my cars rear door. There was a small dent/ding on the door. I looked around on interwebs and found this glue gun method to remove dent. Found this pop-a-dent kit on amazon. It was just 498rs+shipping, so thought of trying it out.
It may not work if the dent has a strong crease. If paint has chipped off then dont try this method, you might end of damaging the paint more.
Interesting Rahul. I think we should meet. I am sure it needs a lot of patience. I have a small dent caused by an oil can that was kicked up by the car in front of me.
Thanks for sharing this Rahulkool.:thumbs up
Seems promising.
Just one clarification,What is the amount of glue that gun can disperse and also how to replenish the glue.
Further, how long did you take for this 25 iterations.
Thanks in advance.
Maverick79
Seems promising.
Thanks in advance.
Maverick79
Hey Maverick79, It took me around 2.5 hours.
The gun comes with one glue stick, i used half of that in whole process. If needed you can buy more glue sticks.
I have seen some advertisements and videos for such products on websites. But this is the first time its an individual (Rahulkool) who has tried and tested the product. It gives confidence to us all to try the product for our DIY jobs.
Rahulkool, since your's is a Fiat it has taken 25 efforts to try and remove the dent and ultimately reduce it to the size of a pea. But I am sure Maruti, Hyundai, Toyota, Nissan owners may find the going easier, given the sheet metal quality. The flip side is that such cars in most cases would also suffer a greater dent with the same impact.:)
For bigger dents (read the bird bath sized dents) it is simpler to open the inside panel and push it from inside. A gentle nudge is usually enough. I have tried it on my Alto a couple of times when the kids in the society decided to push the car for reasons best known to them.
However for smaller dents, the glue gun may be useful.
For bigger dents just use the plunger from your bathroom. Use something simple to protect the paint and plunge the dent way out.
If all does not work, get yourself a racing DNA sticker and cover it.
Good job Rahul. Considering your schedule and break from active riding/driving it is good to see you finally get into some action with your rides. Price vs Result, this is no brainer to try and it looks fairly safe. Just needs patience. Good to see you record this and post it for us as i would have never bought this and would have simply said gimmicks.
Thanks Rahul. For a long time I have been searching for something similar to get rid of the ugly dents that I have on all 4 door creaselines on my Punto. Thanks to the parallel parking I have and the careless adjacent car owners. But do you think it will serve the purpose for my car as the dents are not on the flat surface, but rather the crease lines just below the windows?
Maverick79
The glue sticks are available in most stationery shops. The POP-A-DENT that I had purchased came with 3 sticks and none of them were good enough to hold the pullers in place. I then got a new set of glue sticks (available at Odyssey in Chennai) and those were strong enough to hold the pullers in place till the dents were pulled out.
That white 'pencil' like stick is to remove the glue from the pullers after it pops out, especially to clear up those 4 holes.
Couple of dents that I got rid off using this. Had to repeat the procedure around 4 to 5 times on each dent.
On the rear.
Happened when the TUV had to be pushed after it got stuck in some beach sand. Had to drop 2 wheels off the road to allow another vehicle pass by on the narrow road along the beach, and the rear wheel in the sand started spinning. Now have got a MLD on the rear axle.
DIY: Paintless dent removal via the Glue gun method-rear-1.jpg
DIY: Paintless dent removal via the Glue gun method-rear-2.jpg
DIY: Paintless dent removal via the Glue gun method-rear-3.jpg
On the right fender.
Happened when a Scorpio moving parallel, on my right, suddenly realized that he has to turn into the road on the left, and did not want to miss it.
DIY: Paintless dent removal via the Glue gun method-sides-1.jpg
DIY: Paintless dent removal via the Glue gun method-sides-2.jpg
DIY: Paintless dent removal via the Glue gun method-sides-3.jpg
DIY: Paintless dent removal via the Glue gun method-sides-4.jpg
Given the price tag, it is worth having one at home.
Nice DIY Rahul and Captain Rex.
IIRC, the famed Trend Automobiles in Bangalore use this too.
Which is why the car is taken away from sight into a closed area, when being worked upon.
Good DIY Rahulkool and CAPTAIN REX. This was one thing I always saw on teleshopping. Now I know that some teleshopping ads can be actually true :)
They do use it; I've seen them doing it on some car. But I didn't understand the context of your last sentence.
If you are saying that they do it because they don't want the customers to see it, then I don't think it is true. The before and after photos here do not suggest the exact amount of effort involved. As Rahulkool mentioned, it is a time consuming activity and also needs a lot of patience. There are not many people who are good at DIYs or do not want to risk doing it for the fear of paint peeling away.
Also we must understand that of the many dent removal techniques this is one of the very basic techniques. Trend being a body shop will surely have this and many more tools and methods to remove it
I have used a similar product in my dad's Santo which had a major dent when a coconut fell on the right fender.
post 4-5 tries, the dip was reduced from a coconut size to a tennis ball size one. I am sure that with more patience, could make the dent non recognizable, but ran out of patience.
Note: Felt that a heavy duty vacuum puller would do a better job than this
George V
I had used the same kit on my Alto, some 5 yrs back. It was purchased from ebay and I managed to remove some big dents but also some paint on repainted surfaces.
Advantages :
- DIY way to remove dents on your own.
- Simple to use and un-glues itself, once a big dent is popped.
- Save a lot of ₹ instead of conventional tinkering and painting.
- No fiddling with door pads for dent removal, hence, no rattling after work.
Disadvantages :
- Not possible to remove dents on hard metal area, like the runner board.
- Not recommended for use with repainted surfaces.
- Cannot remove dents on edges.
- Leaves a small ding after pop, if, the dent is caused by sharp objects.
Recently my bro, gifted a dent on my car, on the driver side door and the rear door, even some paint was lost exposing metal.
I did not wish to replace or repaint due to loss of NCB. Hence went to a road side tinker; he used grease and a plate like hammer to hit on the dented portion. Though the work did not give a perfect finish, overall I'm happy. clap:
You could see, small tinkered dents, if you observe carefully over reflections below handles . :Frustrati
DIY: Paintless dent removal via the Glue gun method-img_20171025_111700.jpg
For a normal eye, it wont be visible but driver side door (zoom in) is an eye sore, but yeah, will have a teambhp sticker
DIY: Paintless dent removal via the Glue gun method-img_20171025_111641.jpg
Rahul, this post is right on time for me. Thanks for sharing this to begin with. I have looked at various pop a dent videos on youtube recommending products available on Amazon in the US. When i try to find similar products on Amazon.in, i mostly find ones that look like a knockoff of the original one and the reviews are not confidence inspiring either, mostly complaining about missing items or the glue gun not working etc.
The second question i have is, can we remove the smaller dents? I have couple of small dents on my car.
Yes removing the panel and pushing would be easier but if you dont have the right tool you might end up damage the panel more. I guess a rubber mallet would do the job, again you have to be really careful.
Post some pics if you have, but i doubt if those can be pulled out.
Wow! thats some neat work you have done there.
thanks man
Thanks, i didn't knew it was available on teleshopping, i came across while googling to repair the dent.
Removing smaller dents is difficult than bigger ones because surface area is smaller, it will take longer time.
