Re: DIY: Bigger Intercooler Install for Fiat Linea T-Jet Quote:
Originally Posted by Abhishek3001 Being sold in the tropics might be the very reason Fiat opted to give a smaller intercooler to the car because in the tropical climates the higher moisture content in the air causes enough condensation to build up in larger intercoolers that it can cause other problems.
Very good point. That Ford IC seems to be massive. I have only upgraded from a 6 core IC to a 8 core IC. Logically the efficiency would have increased by 25%. I hope it will not cause condensation issues. Will keep an eye open for that. Thanks for pointing this out. Quote:
Originally Posted by Dr.Naren There are many dyno centres in Coimbatore. It would be great to compare there. Just check the power drop after couple of runs in cars with stock and upgraded intercooler. |
That would be the best way to actually come to a conclusion, but sadly, it costs money to do that. I for one really cannot afford to spend that kind of money, just to prove that my claims are right. I mean, why do I have to prove it to anyone? I have done the mod and am sharing only what I am seeing. Tomorrow, if the engine blows up due to this mod, I will post that too. Quote:
Originally Posted by DRIV3R Stock IC yes, but out of those 90k kms, 85-90% or even more of those kms are after remapping the car, right? Also, we started data logging only very recently. |
The car was remapped when it had done 40K Kms. I think that is a tad more than 10-15% of 90K Kms. Lets not assume too many things here. You might have started data logging recently, but I have been logging / monitoring ever since I bought the car. Lets also not forget that the car has switchable maps and I mostly use stock map in city conditions Quote:
Originally Posted by DRIV3R Also some tall claims! |
I did not make some of those claims. So, I cannot answer them. Also, I do not see the point of discussing claims made somewhere else, by someone else here on my thread. I definitely drive more in 3rd gear than in 2nd post the IC mod. I am also seeing a consistent improvement in FE. Around 1.5 kmpl more than before, in the same driving conditions.
You don't have to trust these claims. I am not here to prove myself to the world. I just shared what I am seeing. Take it or leave it. Quote:
Originally Posted by dhanushs Following which...
The graph is plotted, using the Intake Air Temperature sensor.
This particular sensor is located before the turbocharger, after/before the air filter box.
An intercooler is fitted to cool the compressed air from the turbo, which gets hot as a result of compression. The role of the intercooler begins only after the turbo plumbing.
So, not sure how the readings from this sensor is changed after fitting an intercooler?! |
I am not sure how you came to that conclusion. The temperature/pressure sensor is right on the throttle body.
Bottom line -
I am really not interested in proving any of my findings to anyone here. That said, I am open to doing a side-by-side drive with a stock car and help log data and compare.
EDIT - Quote:
I was meaning the graphs with missing vital parameters, like GPS/OBD Speed, which are used in this very thread to portray that the stock IC is doing a bad job, specifically since vehicle speed is proportional to the airflow, and airflow is vital for an ICs efficiency.
All the graphs I have shared in this thread show speed. What am I missing?
Reason: Quoted post edited
