Old 12th May 2020, 13:47   #1
Thanked: 343 Times
DIY: Kia Seltos Dash Cam Installation
Hello everyone!
This is my first thread on TeamBhp and I just bought a Kia Seltos. Decided to do a concealed dashcam installation and do a DIY step by step pictures for anyone interested.
I bought this Apemans C860 dashcam from abroad through a friend. It was one of best dual dashcam I could find in Amazon. But sadly the rear camera/cable turned out to be faulty and I'm stuck with the front camera for now.
DIY: Kia Seltos Dash Cam Installation-1.jpg
Package contents
DIY: Kia Seltos Dash Cam Installation-2.jpg
The installation process is as below
DIY: Kia Seltos Dash Cam Installation-3.jpg
DIY: Kia Seltos Dash Cam Installation-4.jpg
DIY: Kia Seltos Dash Cam Installation-5.jpg
DIY: Kia Seltos Dash Cam Installation-6.jpg
DIY: Kia Seltos Dash Cam Installation-7.jpg
DIY: Kia Seltos Dash Cam Installation-8.jpg
DIY: Kia Seltos Dash Cam Installation-9.jpg
DIY: Kia Seltos Dash Cam Installation-10.jpg
DIY: Kia Seltos Dash Cam Installation-11.jpg
DIY: Kia Seltos Dash Cam Installation-12.jpg
DIY: Kia Seltos Dash Cam Installation-13.jpg
DIY: Kia Seltos Dash Cam Installation-14.jpg
DIY: Kia Seltos Dash Cam Installation-15.jpg
DIY: Kia Seltos Dash Cam Installation-16.jpg
DIY: Kia Seltos Dash Cam Installation-17.jpg
jothishX is offline   (27) Thanks
Old 12th May 2020, 14:20   #2
Mr.Boss's Avatar
Thanked: 7,588 Times
re: DIY: Kia Seltos Dash Cam Installation
Any specific reason to cut the cable?
At least in the few cars that I installed dash cams never faced any such issues.
Mr.Boss is offline   (3) Thanks
Old 12th May 2020, 15:59   #3
Thanked: 343 Times
The micro-usb plug was thick and L-shaped (second picture). I couldn't push it from under the glovebox. Could also have used the guide wire to pull it up. But, cutting it seemed to be the easier approach. Moreover, this doesn't have any warranty. And I was sure there would be only two wires inside.
jothishX is offline   (4) Thanks
Old 13th May 2020, 11:08   #4
Thanked: 21 Times
Re: DIY: Kia Seltos Dash Cam Installation
Did you hardwire the setup or connect using the 12V socket only?
madhavabeer is offline
Old 13th May 2020, 11:19   #5
Thanked: 343 Times
Used the 12v socket only.
jothishX is offline   (2) Thanks
Old 13th May 2020, 11:31   #6
Thanked: 21,452 Times
Looks like the dashcam has been connected using the 12V socket (Picture No.: 4).
Old 13th May 2020, 11:45   #7
naveen.raju's Avatar
Thanked: 9,548 Times
Ya, don't think it's hardwired.
The installation is pretty simple and you can easily conceal all the wires. In my Creta, I took the cable through the A pillar, then under the rubber beading on the door sill, then you have a perfect gap to route the cable below the glove box, left over wires are just placed under the floor mat and then on to the car charger. Only the last bit reveals the cable.
DIY: Kia Seltos Dash Cam Installation-hyundaicreta01.jpg
Image Source - Team BHP Creta Review
naveen.raju is offline   (3) Thanks
Old 13th May 2020, 14:21   #8
Thanked: 193 Times
Even I installed a dashcam in my seltos recently, I didn't have to cut any wires. I installed the 70mai pro.
One tip I would give you is install the camera closer to irvm and route the wire inside the irvm plastic holder. The plastic piece just pops off and clips back in with ease.
Turbo yoda is offline   (2) Thanks
Old 13th May 2020, 15:42   #9
Thanked: 343 Times
My power cable is directly connected to the cigarette lighter adapter. Other dashcams like 70mai have a USB A plug which could be disconnected from the adapter and wired without cutting.
jothishX is offline
Old 14th May 2020, 02:20   #10
GutsyGibbon's Avatar
Thanked: 5,112 Times
Great job with the DIY project!
Curious to know what went wrong with the rear camera. That is a bummer. Is rear camera also powered by 12V? Have you tried hardwiring the rear camera to the battery/ or an external 12V source, and see if the monitor is receiving a signal?
GutsyGibbon is offline   (1) Thanks
Old 14th May 2020, 17:55   #11
Thanked: 343 Times
The rear camera is powered by a usb c cable running from the main cam. It is 5V. I tried using other cables - didn't work. This is using different pins than the standard usb 2.0 data pins. As you suggested, I'll try hooking up the camera to a spare reverse camera monitor to see if I'm getting any feed
jothishX is offline
Old 28th May 2020, 01:51   #12
FGP
Do you unplug the adapter after you switch off the engine everytime? Or is that not required since the 12V socket does not have the always on feature?
FGP is offline
Old 28th May 2020, 09:32   #13
Thanked: 343 Times
No, None of those sockets have always on feature. Cam goes off after turning off the engine.
jothishX is offline   (1) Thanks
Old 29th May 2020, 15:01   #14
FGP
Hi JothishX, was there any particular reason why you opened the rubber beading and tucked the wire under the A-Pillar instead of directly tucking the wire below the rubber beading itself?
FGP is offline
Old 30th May 2020, 22:55   #15
Thanked: 343 Times
I wanted a clean and concealed look as much as possible. With the wire under the beading, there is a chance of someone pulling out the cable accidentally where visible (especially my toddler). There was a slight bulge in the beading when tucked under it, could be an ocd though
jothishX is offline
