Old 29th November 2021, 15:37   #16
Ashtoncastelino's Avatar
Thanked: 2,266 Times
re: DIY: Restoring Headlights at home
Regarding sealing with the wax. Wax is not durable and once it wears off the headlights will start becoming yellow since the factory plastic protector coat is removed during wet sanding. Look for dedicated headlamp restore kit(Turtle wax has one IIRC) which has some sort of plastic sealer which acts as the protective top coat that lasts long.
Thankyou for this suggestion . I will definitely try to procure the turtle wax headlight restorer protectant. For the time being , I am currently applying the liquid wax every week till I get the protectant or PPF applied.
Originally Posted by saisree View Post
A nice diy there and hope it helps many here. Those headlamps looks neat and clear
Thankyou Sir.
Originally Posted by viXit View Post
Waiting to do the same. Where did you buy the sandpaper from?
Thankyou Sir, I managed to get the sandpapers from my local hardware store . Luckily he had the 3M branded Sandpaper.
Originally Posted by mohitchalla View Post
Great job! Did you consider applying a later of clear coat? That would ensure longevity and you would not have to do the restoration for a long time.
Thankyou, Although I didn't need to apply clear coat as I already polished the headlights with the orbital polisher. In order to apply clear coat I would need to sand it again with 2000 / 3000 grit paper for the clear coat to stick to the headlight else it would just flake off. This particular method doesn't need clear coat spray.
Originally Posted by AJ56 View Post
Easiest and longest lasting protection for the lens after stripping the old clearcoat would be a quality ceramic coating, again you can get Carpro Cquartz kits off Amazon. Make sure you IPA wipe the lens thoroughly before application.
I did check this option out on amazon but it looks out to be expensive. Thanks for the suggestion by the way.
Wouldn’t recommend without the right equipment and a paint booth. You can use clear but to do it properly you’ll need an HVLP spray gun, and a completely dust free environment to ensure no contaminants stick to the clear while curing.
Indeed you are right. This is primarily the main reason I didn't opt for the clear coat spray method. The method which I opted seemed much efficient although I need to find a good Plastic protectant.
Originally Posted by headers View Post
Awesome job, But applying PPF on it would dull the HL in the long run. PPF does like heat and tends to yellow over a period of time.
Oh, I need to check more on this. Thanks for the heads up ! I've heard people tell about the slight yellowing part when applied on the body of a white car, but it usually happens after 3+ years.
Originally Posted by shankarbn View Post
bought brand new headlight lenses from aliexpress instead for around 15 dollars shipped. Sure, it meant an even harder DIY but I've never had to redo this for 3 years now.
AliExpress option was also considered but it being banned here made me look for alternatives. Thanks for the suggestion!
Originally Posted by Aish_4761 View Post
Wow, the result looks good but as you mentioned, removing the bumper would not obstruct the orbital polisher when buffing. Thankyou
Originally Posted by @og_adi View Post
I remember reading somewhere about WD-40 being used to clean hazy headlamps. Has anyone tried it? Is it an effective solution?
Had tried this earlier on my dads Rav4. It looked good for a minute or two but then when the WD40 wore off, it returned back to how it was initially. Bummer!
I use the Meguiars Headlight restorer. This even protects from future haze. All you need is a towel to wipe it off the surface. My two decade old Zen had a real bad build-up, and this did a great job
Wow, is it possible for you to share a link of the product? I'll see if this available locally, This looks to be a good option for the Headlight protectant.Thanks for sharing!
Wanted to post some before and after shots of an old Sunny’s lights we had recently restored.
The reason PPF isn’t a great solution on lens is cause it adds orange peel (optical distortion) in the finish (just like with paint) and more importantly it yellows out within a year, also you can see the edges around the lens which looks ugly.
I’ll also add that the clearcoat on plastic lens only yellows and breaks down when not cared for over the years, as UV radiation breaks it down. If you apply protection regularly be it sealants or coatings, you car won’t have any yellowing/hazing on the lens. To prove my point you can see my own car below (black Amaze) it’s almost 9 years old and these are the original lens, zero loss in clarity.
Those are some Spectacular before and after shots AJ56 ! Thankyou for sharing. So what do you think about this being applied on the headlights ( Bike Ceramic Coat Kit) ? 1 bottle costs about 1200rs and I feel it should be enough for both headlights. Do Let me know your thoughts.
https://superceramiccoating.com/buy-...c-coating-kit/
Ashtoncastelino is offline   (4) Thanks
Old 29th November 2021, 16:31   #17
AJ56's Avatar
Thanked: 3,233 Times
Thank you for the kind words! I’ve never heard of or used this brand before but from their site and low pricing I’m almost certain it’s a cheap Chinese rebranded coating that is being repackaged and sold, otherwise no quality ceramic kit is this cheap.
Also, they don’t mention the volume of their bottles, how are 2 bottles required for 1 small car? For a mid size car like say an Accord, you need around 18-22 ml of liquid, bottles are either 30 or 50ml for most brands. They claim 3 bottles for a large vehicle, having done dozens of Land Cruisers I can say one 30 ml bottle is more than enough, even for large vehicles. So something is way off, even if I assume they’re giving 2 coats per car, for a hatchback two 30 ml bottles = 60 ml which is enough for 4 coats.
If you don’t want to buy the entire kit from Amazon, you can take it to any good detail shop that specialises in ceramic coatings and have them apply it to both your lens, every shop will have open bottles and it should be much cheaper than buying a 50ml kit. Cheers.
AJ56 is offline   (3) Thanks
Old 29th November 2021, 17:21   #18
Now that you mentioned it , it indeed seems shady. I'll go and ask a detailing shop to ceramic coat the headlights if possible.
Ashton Castelino
Ashtoncastelino is offline   (1) Thanks
Old 28th December 2023, 14:19   #19
Oppanna's Avatar
Thanked: 450 Times
Re: DIY: Restoring Headlights at home
Bumping an old thread. Please let us know how are the polished headlights holding up now?
Did you redo the process again in the last two years?
Oppanna is offline   (1) Thanks
Old 29th December 2023, 11:32   #20
Thanked: 1,816 Times
Hope this DIY helped and I'm waiting to see the before/after photos of your headlight restorations
You didn't clear coat the lense after the restoration? How is it holding up? Kindly update.
Thanks.
Sherlocked is offline
Old 29th December 2023, 13:23   #21
Thanks.
The headlights are still in the same shape and it hasn't shown any signs of aging, did not need to redo the process again. You can either go ahead with the procedure i've mentioned or you can do it the ChrisFix way of using clearcoat after sanding them. I have installed Projector Headlights and have followed the clear coat method on the spare headlights I procured. More updates to follow up on the Swift ownership log
Ashton Castelino
Old 7th July 2024, 21:33   #22
I read this thread and have an update on how to restore headlights from the inside. This is especially useful when you have dust and other foreign particles. So, my Polo GT headlamps started getting dirt and water inside one of the lamps. I asked the SA at an authorized showroom (Elite Motors Bangalore) to help. He asked me to replace the lamp for 8K plus labor. I decided to skip this in the regular service, think about it and then decide.
When I examined the lamp, I found that the lamp cover was inside the engine bay! They overlooked the fundamentals, neglecting a thorough lamp inspection and repair.
I cleaned the cap and installed it. This would prevent new dust / water from going in, but what to do about the dust and the dead spider inside? I decided to do a DIY
Options after googling were:
1. Use a heatgun to melt the glue, remove the clear front and paste it back
2. Use a vacuum cleaner with a small hose
3. Pour some solvent inside and drain out the dust
Did not like option 1 for the hassle and option 2 did not work well. How do you guide the hose to hard-to-reach places? Also, some of the dirt had dried after getting wet, so even a powerful vacuum could not remove it.
Option 3 sounded like a terrible idea, and I decided to skip it. I came up with a new method, which will benefit others here. So here is how it works:
1. Remove the headlamps and get them to a spacious workspace. Removing them in the Polo is a simple affair and there are youtube videos on how to do this. The size of the lamps turned out to be much larger than I had expected!
2. Place them on a surface with cloth to protect the lamp.
3. Remove the indicator lamp to get access inside the housing
4. Wrap a small cloth or wetwipe around a couple of small neodymium magnets and tie it to a thread. Drop this inside the indicator opening
5. Get hold of the magnet from outside with more magnets - wrapped in cloth to avoid scratching the lamp
6. Guide it carefully to its location and wipe with force of the magnet on the outside
7. Pull out the magnet via the string and repeat steps 4-6 as many times as needed
I was quite happy with the results. Its not perfect, but saved 8K and some waste in the landfill. Pics attached to demonstrate how it works.
DIY: Restoring Headlights at home-before.jpg
DIY: Restoring Headlights at home-access.jpg
DIY: Restoring Headlights at home-cleaning-process.jpg
DIY: Restoring Headlights at home-after.jpg
sleeperdash5 is offline   (3) Thanks
Old 21st July 2024, 23:58   #23
Thanked: 3,374 Times
...Look for dedicated headlamp restore kit(Turtle wax has one IIRC) which has some sort of plastic sealer which acts as the protective top coat that lasts long.
I have purchased the Turtle wax headlight restoration kit which consists of a polisher, cleaner, 4 sanding strips, a base coat and a sealing coat pouch.
Waiting for a gap in the rains to carry out the job.
A couple of years back, the headlights were reasonably restored by just using normal Colgate toothpaste (not the gel, but the white one).
Applied toothpaste all over the clear plastic and rubbed it with a toothbrush all over and rinsed the same.
It effectively cleared the headlamps and was simple for a DIY.
To seal and delay the oxidation, applied wax polish over the headlamps and regularly used to wax the headlamps, this provided adequate sealing and delayed re-yellowing.
3) Wetsand with 600 grit sanding discs attached to a short throw orbital sander.
6) Heavy cut compound (Mezerna 400) with 3” coarse foam pad on a rotary polisher.
Do you have any recommendation on a good rotary polisher?
for_cars1 is offline   (1) Thanks
Old 22nd July 2024, 00:30   #24
AJ56's Avatar
Toothpaste does have fine abrasives in it so that explains why it worked (somewhat).
For a good rotary get the Shinemate EP-802-
https://www.google.com/aclk?sa=l&ai=...ECAcQDA&adurl=
AJ56 is offline   (2) Thanks
Old 29th July 2024, 18:50   #25
Thanked: 71 Times
Hey all a quick help on polishing glass lens covers or Plastic lens covers - Don't waste your time or money on this unless you need a quick fix and immediate solution.
The fading will return back very soon in few months, as this happens to most of headlights with High watt Halogen reflectors or vehicle parked outside under sun usually, polishing would thin the lens further and open up more new holes (surface area) for oxidation to happen, OEM Lens have a coating to prevent this and its highly toxic and not usually sold in practice in retails, you can try Waxing the lens frequently but its quite a job.
this effect is accelerated by Sun's or Halogen lamps UV radiation and IR radiation, so unless you fix that first the issues are prominent.
Things to check
*check for proper ventilation tubes installed in the Headlight casing behind, this will make sure the head generated inside the headlamp unit is radiated properly so the thermal load on lens is less
*check if you are running High watt halogens >60W , the effect cannot be typically solved as the thermal watts are high the lens cannot radiate the new higher thermal addition of energy, as there is a Net delta raise, lens will be warmer than before, which would lead to oxidation.
*If your headlamp lens are dust free from inside, the dust either on inside or outside the headlamps absorb the thermal energy and create hotspots in microscopic level and will accelerate the oxidation even more.
Recommendations:
1. In some markets you will get just new lens( outer clear plastic) sold separately where you can ask any headlight cleaning shop to replace.
2.Go for similar luminous LED systems for less thermal radiation so your newly polished lens can last longer.
3.Just get a new headlamp. (OEM if possible), there are lots of aftermarket brands sell for one third the cost, with my experience i would not recommend those like lumax, minda , chinese etc. get a original from Boodmo or local OEM part seller.
prasanth DIYer is offline   (1) Thanks
Old 1st May 2025, 22:30   #26
Finally did this DIY after almost a year.
Was a bit hesitant as I wanted to be absolutely sure of what I'm doing.
Used the same Turtle wax restoration kit but did not use the sanding strips and cleaner/spray lubricant and just used the Lens Clarifying compound (polisher) and a rotary polishing machine and finishing it off with Lens Base coat wipe and Lens sealing wipe.
The sanding strips would be needed only if the fading is a lot and mere polishing won't do the trick. So I avoided the sanding part as the fading was mild and fixable by just polishing.
The process followed:
1. Washed both headlights with water and dried it with microfiber towel.
2. Applied masking tape (Amazon Solimo) around the headlight lens to protect the surrounding painted areas.
3. Applied Lens clarifying compound on both the headlight lens and the rotary polishing foam pad. Foam pad should be dipped in water and excess water shaken off before use.
4. Gently used the rotary polisher at 1500 RPM on the headlight lens repeated about 4 times until the yellowish fading disappeared.
5. Cleaned both lens with water and dried it with microfiber towel.
6. Applied Lens base coat wipe quickly on lens and waited for a couple of minutes to dry.
7. Applied Lens sealing wipe on both the lenses and this one takes about 24 hours to cure. Both #6 and #7 are supposed to seal the lenses and prevent re-oxidation and yellowing for a considerable time.
Let the pictures do the talking now
DIY: Restoring Headlights at home-rotarypolisher_withfoampad.jpg
DIY: Restoring Headlights at home-with_lens_clarifyingcompound.jpg
DIY: Restoring Headlights at home-rightlens.jpg
DIY: Restoring Headlights at home-leftlens.jpg
for_cars1 is offline   (12) Thanks
