Old 16th September 2023, 12:52   #1
MAKMADDY17's Avatar
Thanked: 173 Times
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross
Hello All,
Few days ago I started observing a rattling noise coming from the center console area of the dashboard (Central Ac Vents / Infotainment System).
The strange part was the sound was not constant rather it was intermittent, hence it became hard to find exactly when it was occurring.
I started noting down the conditions which were triggering it, mostly it was on 3 occasions -
- When i was driving at lower speeds while at higher gears: like uphills, flyovers, at some traffic conditions etc. [Intermittent]
- When one of the tyres hit the reflector plates on the road partitions at medium speeds. [Intermittent]
- On bad patch roads or continuous small speed breakers. [Intermittent]
I decided to open the central console section and started searching for articles/videos around it. Took following two references -
  1. YouTube reference :
  2. Leoshashi's thread on similar issue :
    https://www.team-bhp.com/forum/test-drives-initial-ownership-reports/225356-my-first-car-2020-maruti-suzuki-xl6-alpha-mt-review-11.html#post4891571
    https://www.team-bhp.com/forum/test-drives-initial-ownership-reports/225356-my-first-car-2020-maruti-suzuki-xl6-alpha-mt-review-11.html#post4892355
Sharing few images of the work below -
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-acventopen.jpg
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-acventopen2.jpg
After the vents were opened
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-opnvent.jpg
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-opnevent2.jpg
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-fram.jpg
After opening i was searching to see any hanging coupler which was making sound or any frame but everything looked good. On a sad note I was about to repack everything then I saw the AC vent section. I tried to shake the left one, there was no sound; it had a good space to avoid hitting the surrounding portion.
I tried the same approach on the right one, BINGO I have the culprit !!
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-culprit.jpg
Same sound when you shake the right one. It was hitting the dashboard when I was shaking it.
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-closerlook.jpg
I added extra foams around all the sections of the vent and re-packed everything. I wrapped paper tape on all the locks and tied up some wires to avoid future rattling.
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-finalpacking.jpg
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-papertape.jpg
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-tie.jpg
Infotainment check before final packing -
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-hucheck.jpg
Repacked -
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross-finalpack.jpg
1 week observation - No sounds on all the three conditions observed above. So far so good.
Note - Re-packing of AC vents needs a bit of trick and hard. Be careful around it.
Thank for reading
MAKMADDY17 is offline   (24) Thanks
Old 18th September 2023, 10:06   #2
Thanked: 29,553 Times
Re: DIY: Stopped the AC vent rattling noise in my Maruti S-Cross
DIY: Stopped the AC vent rattling noise in my Maruti S-Cross - Post moved to a new thread.
Omkar is online now   (2) Thanks
Old 18th September 2023, 11:57   #3
Thanked: 61,722 Times
Excellent job. I hate rattles, they just drive me nuts. I will take my whole car apart to find and fix a rattle.
Just a bit of advice, when you start taking bits of trim of the dashboard you should consider disconnecting the battery.
Jeroen
Jeroen is offline   (8) Thanks
Old 19th September 2023, 12:53   #4
MAKMADDY17's Avatar
Thanked: 173 Times
Jeroen
Thanks Jeroen, I had that in back of my mind as prerequisite and somehow missed it. Will follow this for sure next time, if required.
MAKMADDY17 is offline   (2) Thanks
Old 19th September 2023, 18:07   #5
Thanked: 164 Times
The timing of this post couldn't have been better. Been having this maddening low rattle with identical symptoms for almost a month now on my 2017 scross, more noticeable since I mostly drive with windows closed & engine for music...
Checked and tightened every screw I could spot starting with the tweeters, glove box and everything to the left - thats were it seemed to be coming from. Surprising how many screws and press-fit items were somewhat loose, but no matter what I did, the noise persisted. And the sympathy filled 'poor guy's gone off his rocker' reactions from others while I fretted over a non-existent rattle didn't help.
Never thought of opening up the AC vents - weekend calendar blocked
isiv is offline   (1) Thanks
