Old 26th December 2008, 12:25   #31
rkbharat's Avatar
Thanked: 724 Times
Actually this method is very useful for depression dents on places like on doors, at places behind which there are crash protection roads. very difficult to push it from behind.
Also I used this method once in my Indica. but with a difference. If you use these suction hooks, you will have to initially press a bit to create suction pressure, which might put more deep dent.
I used my HTC car holder which has this clip to create suction pressure. So just put and pull the clip.
rkbharat is offline
Old 26th December 2008, 21:51   #32
hell boy's Avatar
Thanked: 25 Times
Thank you for sharing this method. I'll try it out on my car as well.
hell boy is offline
Old 9th October 2009, 18:58   #33
k_shanz's Avatar
Thanked: 75 Times
Hey riitz!
Am using a zen and i have dents on my top(Roof). I banged on the dents from inside, some dents disappeared but some are still left, though they are not sharp.
Please help.
Last edited by Dippy : 31st May 2010 at 11:06. Reason: Avoid quoting a long post when replying to a topic. Thanks.
k_shanz is offline
Old 9th October 2009, 19:32   #34
anjan_c2007's Avatar
Thanked: 22,957 Times
Quite an innovative idea! Wish it works for me too as my Scorpio has a small dent on its rear.Will try and report the matter here.
anjan_c2007 is online now
Old 9th October 2009, 19:44   #35
vivekiny2k's Avatar
Thanked: 212 Times
I have done the same on my galant's (now sold) door, where the door metal was not easily accessible even after removing the door panel. I used the GPS suction mount and it easily came out, but went back in with the smallest tap. it sounded hollow while the other door sounded solid, must have been missing some filling inside.
vivekiny2k is offline
Old 30th May 2010, 22:28   #36
Thanked: 40 Times
Wow, I have this kind of a hanger at home, I will use it asap and report back.
What an idea sirji!!
abhipuru16 is offline
Old 30th May 2010, 22:46   #37
echo77's Avatar
Thanked: 130 Times
it got a dent with just a man sitting on it??
Its a maruti
All metal plates are very flimsy.
echo77 is offline
Old 30th May 2010, 23:54   #38
Thanked: 2,557 Times
Originally Posted by echo77 View Post
Its a maruti
Quite true
These methods do work only on certain kinds of dents. Not always.
The dent causes inward depression, if removed it will cause outward bump
PAVAN KADAM is offline
Old 31st May 2010, 15:28   #39
deepclutch's Avatar
Thanked: 164 Times
There are Vacuum Pullers available on Ebay India.
puller, Cars, Bikes CVs items at low prices on eBay India
deepclutch is offline
Old 10th August 2013, 13:49   #40
Thanked: 268 Times
Re: DIY Car Dent Removal Total Cost Rs.12
Anyone used this - http://www.tradus.com/motor-pops-den...?src=cat-10139
Is this effective or a marketing hype ?
mithun is offline
