Re: Intriguing study on Tyre emissions | Tyres are responsible for more pollution than the tailpipe Quote:
Originally Posted by whitewing The whole study is focused on particulate emissions, and does not factor in CO2 and other noxious emissions (which over time, with greener fuels, will be the biggest plus point for EVs).
I could not understand on how you were able to conclude that this is against EVs, can you please share the reasons why you think this is rigged? |
The report does not add anything new except extraordinary claims and I support any regulation on tyre wear or chemicals used in manufacturing.
Yes, the CO2 and other noxious emissions are not factored, now for a normal person the study is a click bait, the "particle" is somewhere lost, all that left is EVs are heavy and tyre wear emissions are more than tail pipe emissions, raises a question whether this transition to EVs is necessary. Already there is a catchy sentence which is not nearly true "15 ships pollute more than the entire car fleet".
Not all EVs are +500kg then their ICE counterparts, since tyres on EVs last for same kms as on ICE cars, the wear is the same, how could the study almost double tyre wear for EVs.
For the study they collected tyre particles from the rear of a mercedes, and test conducted on public roads, how do they know it's only tyre particles from the test car and not disturbed particles from thousands of cars which travelled before. That's the reason a peer reviewed studies are considered.
2 years prior similar study by Emissions Analytics showed tyre particles are 1000 times worse, now they are saying 1800 times worse, how can one trust this study, may be after 2 years they will say 4000 times worse.
“Tailpipes are now so clean for pollutants that, if you were starting out afresh, you wouldn’t even bother regulating them” - pure FUD nonsense, forget all other emissions.
Please read below: Quote:
1/12 The @guardian has an unfortunate story on tire wear.
theguardian.com/environment/20…
a thread.
2/ I have been working on tailpipe emissions measurements for many years, so let me put this into perspective.
Particles, unlike gases, can be mesaured in many different ways. For gases you just measure concentration (e.g. 412 ppm CO2), because all CO2 molecules are identical.
3/ But particles are not all identical. They have different sizes, different shapes, different chemical compositions - so some particles behave very differently than others. Also regarding toxicity for humans.
4/ "Very large" particles, bigger than about 10 micrometers, won't be inhaled deeply in our body, so they don't do much harm. They are basically cleared out the next time you wipe your nose. That's why we have a PM10 limit value, limiting the mass of particles < 10 micrometers.
5/ But, PM10 has a problem when it comes to ultrafine particles (UFP) like the carcinogenic soot emitted from Diesel vehicles (and other combustion processes). One 10 micron particle weighs the same as *1 million* 100nm particles.
6/ The smaller the particle is, the longer it will remain suspended in the air. That single 10 micron particle will be removed much faster than the 1 million 100 nanometer particles. So from a human health perspective, you are less likely to encounter that 10 micron particle.
7/ Those 100 nanometer particles get to the deepest parts of our lungs, and easily enter the bloodstream - and end up in all parts of our bodies. That's why people usually count ultrafine particles instead of weighing them, to take their higher toxicity per mass into account.
8/That's where the @guardian article goes wrong. By far most of the tire wear particles are very large, so irrelevant for human health - we don't inhale them. That's not to say they are no problem, but linking them to "air pollution causes millions of deaths per year" is wrong.
9/ Tire wear particles can be in the ultrafine size range, and thus in a similar category as tailpipe exhaust or brake wear particles. Such particles are however not emitted due to mechanical wear, but when the tire gets hot, e.g. due to spinning/slip
10/ But those hot-tire-ultrafine particles are just a tiny fraction of the tire wear particles (on mass basis). This tiny fraction is the one that concerns air pollution and human health, and they are certainly not 2000x more than tailpipe emissions, probably much less instead
11/ Microplastics from tire wear is a real issue. But it's much more an issue for the environment in general, than for air pollution and human health. Apparently, there is a lack of good studies.
dora.lib4ri.ch/empa/islandora…
12/ If you want to know more about particle generation from tires, see for example:
| https://twitter.com/naneosCEO/status...55IiZ72vw&s=19 Quote:
Originally Posted by vinya_jag In my mind, it simply doesn’t add up, tyres causing more pollution |
Tyres causing more particulates by weight, not overall pollution, not to say that you should not worry.
