A few dig outs from the net :
Just shows that a slight change to the design of the rear bumper with a spoiler would make a huge difference to the so called bland looks ..
Guys heres something from me, the no.plate section has been made bigger and a chrome strip has been placed.other things are stock
A small suggesion, a suzuki logo (big "S" in chrome) placed at the center in between "maruti-suzuki" and "baleno" letters on the back side will improve looks, just like swift or zen.
Regarding the number plate, a wide plate (as in post #89) looks better rather than sqare like. The chrome strip over it definitely looks better. A different shape for the strip instead of uniform height (like slightly tapered towards both sides) may look even better.
this is just my personal opinion/taste, need not match with others!
I'm an amateur at this n i did this using paint software so pls pardon me for the quality which is quite pathetic in comparison to the others posted in this thread
KP
i want rims like these..
the prob is that ive got 13" tires.. so im looking for a good set of 13" rims..
i also wanted to know what rim width should i look at 6j or 6.5j? im running 206/60/13 falken ziex ze502 rubber
cheers!
cheers! |
U can get those rims in 13" but not sure if those would be 6j or 6.5j....
small paint job on rear black strip
Ok bit of work on the balenos rear has transpired into this ...
Currently running on two balenos .. Both mclaren's and mine ..
Sneak pics , not even regulars like psycho and v1p3r have gotten to see them yet ..
Pic without the lights on ..
Pic with the lights on ..
Originally Posted by memo45_m Pic without the lights on ..
Pic with the lights on ..  |
Wat done on this Baleno's Tail Lights...
Can someone put some more info on this...
tints on the taillamp i suppose, this setup will look wild with an LED kit!
sorry they are not tints and tints do not sit on plastic........ it is masked paper used for that purpose only............. we are still working on the proper installing of the paper
What colours do these masking paper come in? Maybe a matching one covering part of the tail lights would look better.
memo doest that effect the lighting??
I think there are these spray paints for lights available..how about that???
Hi all...... as an immediate improvement....... can add bulbs to the inboard side of the tail-lights where Maruti has given blanks but no lights. All it needs is a coupla bulbs and coupla metres of wire. With dual tail-lights, the whole look changes....... try it and see. Then you can sit back and admire the brighter tail end while you ponder on how to make it look even better..... :-)
Originally Posted by bikirao Hi all...... as an immediate improvement....... can add bulbs to the inboard side of the tail-lights where Maruti has given blanks but no lights. All it needs is a coupla bulbs and coupla metres of wire. With dual tail-lights, the whole look changes....... try it and see. Then you can sit back and admire the brighter tail end while you ponder on how to make it look even better..... :-) |
Yepp.. have the extra bulbs on my Baleno... But it doesnt make the tail lights look any smaller when the lights are off :)
