Hi everyone,
I am a newbie in this forum. I have been reading the threads in this forum for a long time but this is the first time I am creating a thread. You guys are doing a wonderful job helping each other. I really learned a lot from this forum. :)
I own a 2000 model Maruti Esteem VX MPFI which has done around 90k kms. I have purchased this car second hand 6 months back.
Let me get to the problem which i feel is regarding the suspension of the car. The suspension of the car is not bottoming out or anything but the car seems to be sliding around while taking corners (maybe bodyroll). It also feels like the car is rocking like a boat when there are slight undulations in the road.
What could be the problem? What can i do to fix this? Please help.
Originally Posted by BaCkSeAtDrIVeR
(Post 527331)
1. Drive a different esteem (if you have not driven another esteem before) and check that it is not a car handling problem. 2. Take the vehicle to a water servicing station, get the underbody washed, and look for gaps between suspension and the body. There may be gaps / cracks someplace. |
Originally Posted by kpzen
(Post 527351)
Is it running on 155/80-13 tyres?? |
Originally Posted by esteem_lover
(Post 527377)
It is most probably something to do with your tyres, if not the suspension. how old are your tyres & what size are they ? |
Originally Posted by nitrous
(Post 527380)
I have one word for U. Pedders! |
Originally Posted by n_aditya
(Post 527395)
Hi Toretto, Esteems generally have some amount of body roll. To figure out if the body roll on your car is more, drive another esteem and you will know if the suspensions are due for replacement. At what speeds (during turns) do u feel that the body roll is high? If there is too much rocking even with normal potholes then the suspension may have gone kaput. If all is fine and the body roll needs to be reduced, invest in a good set of strut braces. P.S. Since you are from blore, consider consulting our member psycho. He will be able to give u correct advice. |
Originally Posted by toretto
(Post 527485)
1. What is Pedders? Is it suspension? How much does it cost? 2. What are strut braces? Can u please shed some light on this? |
(Post 528569)
Hey Toretto, Below links will help you understand how suspensions and strut braces work. Car Bibles : The Car Suspension Bible Howstuffworks "Dampers: Struts and Anti-sway Bars" Link to pedders : Pedders Suspension - Straight advice, specialists you understand and... No Bull The pedders suspensions are imported by Electra Automotive in Chennai. |
(Post 528671)
I called Psycho today and he has agreed to look at the car next week. |
