Esteem - Carbs to FI
https://www.team-bhp.com/forum/modifications-accessories/28643-esteem-carbs-fi-2.html)
Originally Posted by rd Its a simple straight forward job.
A complete mpfi esteem engine, ecu, wiring and instrument cluster should cost you anywhere from 50k to 80k. Its a bolt on to your carb esteem. |
Confusing karthi.
Are u referring to an engine swap here?
If it is increase in performance you are looking for you could do a lot with your current carb setup. Refer to dinars post. You could rejet, get better carbs, etc.It would be a lot cheaper as well.
Originally Posted by veyron1
(Post 561270)
If we're just looking at going FI, why look at multiport? Why not TBI? Simpler, cost-efficient, and minimal alterations required, in terms of wiring, manifold customizing, labour, etc.... |
You mean go for throttle body injection instead of of multi point ?
Where is he going to get this type of a TB ?
Can we get one off the shelf ? Or you are suggesting he should fabricate one ?
First-gen Astras came with one. You could theoretically salvage one of them. Mating it will be less of an issue than fabricating a whole custom throttle body.
Someone on this forum has already done an 8v carb conversion to MPFI. ;)
