As some of you guys know, i have an accord v6 running a k&n typhoon. Its shoes have been upgraded to 225/50 r17 Yokohama Advan Sports.
Now, the accord has 2 weaknesses 1) the soft suspension 2) the brakes
The suspension is very soft, offering excellent ride quality but at the expense of handling. The brakes, are terrible from high speeds, too much judder.
I think the only reason i can afford to have some fun with the car is because of the brilliant grip from the Advans.
Brakes
Now what do i want? better braking, and handling, but of course at a price.
The price is around $400. ive decided to postpone my ICE upgrade for all this *runs away from audiophiles* (My music is the Typhoon screaming at 7000rpm)
What i intend on doing -
Ive done a bit of reading around, and ive come to the conclusion that the stock rotors are crap, too much judder, luckily they stop the car well enough inspite of the judder.
So i want to do a relatively cheap upgrade to my brakes without spending a huge amount on a big brake kit etc.
Brembo Replacement Rotor
These Brembo replacement rotors are a perfect fit, 50$ a rotor and are supposed to be quite a bit better than the stock ones without any juddering. This is because these are one piece, and the stock ones are made from 2 pieces of steel.
I think i will upgrade the rotors only up front. Do you think i should upgrade the rear too?
And to compliment the Rotor Upgrade im thinking of getting these brake pads, front and rear.
Akebono Street Performance Pads
All the reviews ive heard have said that these Akebono pads are better than EBC, which are overrated. And that they provide good bite even when cold.
I cant loose out on practicality with these mods, i need the braking in traffic to have good bite too, i should have to floor the brake pedal to get it to stop. Im not looking for crazy braking, but i want better than stock, with a better brake pedal feel.
Coming to the
Suspension
The car handles like a boat around corners and is no match for the V6 engine. I need to do something about this soon. Very soon.
I cant pay $1200 for coilovers, so im looking for a cheaper solution in which my handling will improve at least marginally.
Eibach Pro-Kit Spring Set
These eibach springs are what im thinking about. now the golden question.
Will only these springs give me any improvement in handling?
The lower the front by 1.5" and the rear by 1". i can live with that, there are never more than 4 people in my car, normally 1 or 2. And i can drive carefully if the ride becomes a little stiffer.
My car has done only 10xxx Kms so i dont think i need a shock change. But there are shocks such as Koni which are like $150 a shock and other ones like KYB which are $70 a shock.
KYB GR-2 Shock Now do you guys think any of these will make any sense at all? or will i just be wasting money? Remember i dont expect it to handle like an F1 car after these, i just want a noticeable improvement. And an increase in safety.
