Team-BHP > Motorbikes
Old 4th July 2018, 14:43   #16
Thanked: 6,658 Times
Re: DIY: Scooter Engine & Transmission oil change
Originally Posted by Crankpin View Post
Engine oil ( 10W40/ 20W40) is not recommended to be used in the scooter gearbox.
Hence, you should buy gear oil separately
Which scooter is this data in referrence with?
Asking as I've worked on the Honda Aviator and TVS Wego and for these motorcycles the recommended oil to be used for the transmission was regular 4T engine oil, not sure which but on one instruction manual they even had a caution box advising against the use of using ATF.
ashwinprakas is offline
