Team-BHP > Motorbikes
Old 31st December 2018, 12:27   #1
Thanked: 56 Times
Bajaj Avenger 220 | Engine cutting off after a cold start.
Hello! I need some help regards my Bajaj Avenger 220. I find that every time when at cold start or idling immediate after a cold start, the engine cuts off.
Even whilst riding the bike say for five minutes if I hold the clutch briefly and roll, the engine cuts off. This is scary as twice I have got caught in a near accident situation as the engine cut off just when I needed power.
I have to keep fiddling with the throttle screw to adjust the fuel. I gave the bike to the Bajaj Service center at Mahim in Mumbai about 3 weeks ago and now that the Mumbai weather has turned little cool (Mumbai winter), the problem persists. And this just does not happen because its cold but also happens during summer.
I have tried to have this sorted with different mechanics in the past but this issue just does not get resolved. Do I need to get the carb replaced.??
Any advise welcome.
Seacat
Last edited by Axe77 : 1st January 2025 at 06:51. Reason: Multiple clean up edits for spacing, paragraphs, caps etc.
Seacat is offline   (1) Thanks
Old 31st December 2018, 12:35   #2
adrian's Avatar
Thanked: 1,273 Times
re: Bajaj Avenger 220 | Engine cutting off after a cold start.
Originally Posted by Seacat View Post
I have to keep fiddling with the throttle screw to adjust the fuel .
Seacat
Lean pilot circuit in your motorcycle (assuming it not to be EFI). Identify the fuel screw (not the throttle / idle adjustment screw) in your carburetor and give it 1/4 a turn in the anti clockwise direction. Posting a picture of the carburetor can help us pinpoint it for you.
More help in the following thread
https://www.team-bhp.com/forum/motor...-properly.html (How to tune your carb properly)
adrian is offline   (1) Thanks
Old 31st December 2018, 12:56   #3
Thanked: 56 Times
Thanks Adrian,
I will try this for sure. Was hesitant to mess with the carb but now I think I have no alternative but to do so. Will keep you updated.
Regards/Seacat
Last edited by Axe77 : 1st January 2025 at 06:52. Reason: Caps where needed. (i —> I, etc).
Old 31st December 2018, 14:15   #4
swissknife's Avatar
Thanked: 1,434 Times
The fuel mixture may be a little lean. You could try using the choke. If that helps, you may want to increase the fuel in the mixture by a little bit so that it isn't starved during cold starts.
swissknife is offline   (2) Thanks
Old 31st December 2018, 14:28   #5
Thanked: 4,101 Times
Don't worry about messing the carb setting. It is simple to tune, just watch some youtube videos. This is very easy to fix, infact you will fix it better at home by using both air and fuel screw, than a mechanic who may adjust only one screw.
ani_meher is offline   (1) Thanks
Old 31st December 2018, 15:40   #6
Thanked: 6,658 Times
Hello ! I need some help regards my Bajaj Avenger 220
First determine what the issue at hand is, for that first you'd have to ensure that all consumables have been adequately replaced.
If the issue still persists you should determine whether the tuning is off;
Determining whether Rich:
Starts up easy, but runs like crap once hot, fails to idle when hot, at higher rev's you'll notice black smoke from exhaust.
Determine whether Lean.
Hard to start, but runs nice for a while when hot, then RPM starts to stick/float i.e when you blip the throttle it would rise and then come down slower than it would ideally do, the motorcycle would also be idling higher the hotter it gets, when it gets really hot the idle RPM would be noticeably erratic.
If Rich, you should suspect the Air Filter and Air Filter box, if lean you should diagnose for an air leak.
To diagnose for an air leak you need to raise idle and then spray carb-cleaner/WD40 on the intake route and observe for the RPM to spike, the RPM would spike when you spray on the part that has the leak.
The manifold between the carburetor and head is the usual suspect, so personally rather than do a leak test I directly replace the manifold and 2/3 times that solves the issue at hand.
You should never mess with the carburetor unless it is being rebuilt.
Can't say, as you've let many people mess with your carburetor.
Any advise welcome.
As a lot of hands have worked on your carburetor it would be best to reset things to factory settings or rather re-tune to optimum, to do that you would have to replace all consumables i.e SP, AF etc and then re-tune the carburetor going by the following steps I'd shard in an earlier post;
Originally Posted by ashwinprakas View Post
Good call, never let anyone touch your carburetor, first rule of Fight Club!
Ideally a CV's optimum range is 3~3.5 turns, you can set it at 3 turns blindly or you can re-tune it once you have a new spark-plug and air filter in place.
The procedure is simple, with the motor moderately warm and SAI temporarily disabled with a ball bearing, start at 0.5 Turns with the idle raised, open the AFR screw 0.25 turns at a time and stop at the point where you get the highest RPM, then fine tune it such that you reach the spot just after the RPM is the highest and it settles to a lower speed and you're good to go after setting idle back to normal and unblocking SAI plumbing.
Once AFR is set it should not be fiddled with unless the carb goes for a complete overhaul.
You should not worry about SAI if your motorcycle is a BS3 variant as Bajaj motorcycles only came with SAI recently after the BS4 mandate unlike the rest.
Had also shared the reason why you should not fiddle with the carburetor;
These carburetors have a Fuel Screw for controlling AFR(Air Fuel Ratio);
Attachment 1829222
Which is the only brass screw on the carburetor, the ideal setting is 3~3.5 Turns for a factory dialed setup.
The screw is sensitive and hence should not be fiddled with for no apparent reason which is the usual case with local mechanics, if you do fiddle with it frequently then it will develop a really inconvenient air leak which if you're lucky would get resolved my replacing the AFR screw;
Attachment 1829223
As for SAI, it is the Secondary Air Injection system used for emission compliance, on your manifold/sleeve/(Word Starting with 'D' which I cannot recollect at the time) is a small port on which a tube is connected which goes to the SAI unit, when tuning the AFR it is recommended to temporarily disable it, either by pulling the tube off and plugging the hole on the manifold end with your finger or by introducing a ball bearing into the tube and reconnecting it, I'd recommend the ball bearing as manually blocking it would be one more thing to be bothered about.
The reason for temporarily blocking the SAI is so that you get a more accurate read as with the SAI system connected you tend to get a more erratic idle which makes it hard to fine tune.
That's all as far as the basics go, and yes, unless an actual need arises I'd suggest you ignore the carburetor, as on the 220 which is about 4 years old I've yet to touch either the AFR or Idle Screw to date, reason being if an issue arises out of the blue then blindly playing with the AFR screw is not the right way to resolve the issue as it is simply a band-aid fix which would simply be inviting unnecessary inconveniences in the future.
Then again, a carburetor is like your privates, you don't let another man touch it unless a life-altering need arises and its being worked on by someone whose simply a specialist.
YouTube videos are mostly made by people who seek attention and hence they lack the adequate know-how of what affects what, I've seen a good number of videos on YouTube regarding carburetor tuning and none of them is any better than what you'd expect from a road-side mechanic, so I'd suggest you keep safe distance from such jokers.
Originally Posted by ani_meher View Post
Don't worry about messing the carb setting. It is simple to tune, just watch some Youtube videos. This is very easy to fix, infact you will fix it better at home by using both air and fuel screw, than a mechanic who may adjust only one screw.
I would suggest you not go ahead with what you know, simply because a Carburetor does not have both an Air Screw and a Fuel Screw, it has either one depending on the carburetor type.
You'll find more info on the following quoted post;
Carburetors are more or less the same in function with minor differences depending on type.
The type on your Shogun was a cable operated round slide carburetor like the one on my CT100B,
Attachment 1829216
Which as the name suggests has the throttle cable directly attached to the slide, on these carburetors you have an Air Screw for tuning the AFR(Air Fuel Ratio), the ideal setup for these carbs is between 2~2.5 Turns for a factory machine, unless its a Bajaj(Don't ask!).
On your UCE Bullet 350, you have a CV(Constant Velocity) carburetor as in most modern motorcycles, here's a snap of the Keihin CVK 30 on my ZMA.
Attachment 1829218
On these carburetors the slide is operated by vacuum which is modulated with the help of a butterfly valve which is controlled by a pulley on which the throttle cable is connected.
Attachment 1829222
For those who'd like to know more about carburetors I'd suggest you go through the following post of mine;
Carburetor Types (The Drama of buying & owning a Royal Enfield Bullet 350ES (Electra))
ashwinprakas is offline   (5) Thanks
Old 7th January 2019, 12:04   #7
Thanked: 56 Times
Hi Ashwinparkas,
Many thanks. Much appreciated. Going through your post I feel mine is still a Lean mix.
Just so that there is clarity please be guided I had got the air filter and spark plugs renewed when I last took it to the bajaj service center.
The bike is running much better after I adjusted the idle screw myself but what I notice is that after a moderate run of about 5- 7 kms and when she is nice and hot, the idling is little erratic. So I feel it may still be a case of too lean a mixture. Not too certain if I should adjust the idle screw further or the Fuel screw (Brass one).
The problem is the Avenger 220 DTSI does not have a tacho so difficult to get a exact RPM readout. The manual says idle rpm is 1400 revs.
Im learning :-)
Seacat is offline
Old 8th January 2019, 00:20   #8
Hi Ashwinparkas,
Im learning :-)
That is a good start, now that we have determined that the motorcycle is running lean, we need to find what is causing the lean state.
The carburettors AFR setting would not go out of tune without anyone fiddling with it, hence the reason why its adviced against tweaking the AFR setting unnecessarily, so you have two alternatives;
1. If you feel the carburetor has been fiddled with, properly retune the carburetor as already advised.
2. If you feel the carburetor has not been fiddled with then do an air leak test as already advised.
A new carburetor costs you around 2.5k and would solve all concerns in one go, provided that you replace the manifold as well if your motorcycle is about 5 years old, or simply replace it for the heck of it as it costs peanuts to begin with.
If you're not into spending the moolah, then you'll learn a lot at the expense of time and patience, and would only spend about a few hundred to replace the manifold if a leak is found.
Ideally it is recommend to replace all plumbing including the manifold once in a couple of years, the fuel line, more frequently due to obvious reasons.
The choice is yours, power to the rider!
Cheers.
ashwinprakas is offline   (1) Thanks
Old 13th December 2024, 16:38   #9
NavBHP's Avatar
Thanked: 40 Times
Is there a chance that this issue might be caused due to ethanol blending rather than purely being a carburetor cleaning/tuning issue? When do a cold I start my Splendor Plus bike, it starts on the first kick and idles ok. But if I increase the throttle (gear still in neutral), the engine stops. If I start the bike, turn on the choke, shift to 1st gear and ride the bike for 2 seconds and then switch off the choke, I'm able to ride it for around 20 meters. Then it struggles to move forward because it isn't getting enough of petrol. At this point if I reach down and turn on the choke and accelerate for 2 seconds, the bike roars back to life and after the 2 seconds I turn off the choke and the bike goes ahead for a while again. I repeat this procedure around 5 times. After that the bike works fine. There's no need to use the choke. Even if I park it somewhere for half an hour, when I return, it starts on the first kick and there's no need to use the choke either. Since I've heard that ethanol absorbs moisture from the air and the water accumulates at the bottom of the petrol tank, I've started keeping the petrol tap/petcock on reserve while riding the bike. I was wondering if it could be water which might be causing the cold start issue. I don't use the bike regularly. I only use it once in 3 or 4 days for short rides to shops. After parking it at home, I turn the petrol tap/petcock valve to the off position.
Is this method of switching the choke on and off during the initial 5 minutes of the ride ok, or should I go to a mechanic and do a carburetor tuning/cleaning? What worries me is that many of the local mechanics don't have the right equipment to do the tuning accurately. The authorised service center has the equipment, but they were the ones who did the tuning which is causing the existing issue. My worry is that if the carburetor is tuned to have a fuel-rich mixture, the spark plug might get covered in fuel and/or petrol consumption would be higher.
NavBHP is offline
Old 13th December 2024, 19:53   #10
vrprabhu's Avatar
Thanked: 1,186 Times
I am facing the same issue as you, NavBHP. And, I follow the same routine (very accurately described!) after a cold start. Mine is a 15+ year old Gladiator, BTW. I use it only once or twice a week. Using the choke intermittently is the only solution that works, as of now, to keep the bike running.
I too suspected ethanol as the culprit. So, I had the carb dismantled and cleaned thoroughly. There was a little water droplets in the float bowl. Guess this is inevitable - but the quantity is too small to make any significant difference, is my opinion. I also emptied the petrol tank and refilled with fresh petrol. Problem persists.
Since the carb was dismantled, I am in the process of fine tuning the pilot screw, after every ride.... yet to get the setting perfect, nearing three turns out. The spark plug shows no sign of soot or oil deposit.
vrprabhu is offline
Old 13th December 2024, 21:39   #11
Thanked: 1,009 Times
How old is the engine oil?
Before messing with the carb tune, I'd suggest to start with addressing the simple potential issues. Unless you've recently messed with the carb tune, or unless it required too frequent adjustments during services (leading to worn off threads), I think the mixture your engine is getting is probably fine.
Engine oils lose their ability to get up to operating temperature- among other issues- over time. And at lower temperatures, they can be too viscous for the engine to idle. So, if the issue gets lower and lower as you ride more, it's probably the oil.
Last edited by BullettuPaandi : 13th December 2024 at 21:42. Reason: added about the viscosity
BullettuPaandi is offline   (2) Thanks
Old 13th December 2024, 21:48   #12
Gansan's Avatar
Thanked: 5,924 Times
Guys, mine is a 2000 model Splendor. It runs just fine with the ethanol blend, never has any problem. So petrol can't be the issue with your bikes, especially if they are carb models.
Check the spark plugs. If the plugs are going bad they can have an issue when more current comes in, that is, while accelerating. Just change the plug and see, before proceeding to further steps.
Gansan is offline   (3) Thanks
Old 14th December 2024, 20:17   #13
vrprabhu's Avatar
Issue persists even after oil change (6 months ago, ridden hardly 500 kms since). Used 20w40 HP Racer 4 (which is the recommended grade). Planning to shift to 15w40, as I too had similar thoughts as you.
Changed the plug when changing the oil. The plug tip appears to be ok (between brown and white colour).
Is there is a need to check the HT coil and the cable (I had changed the plug cap, as a matter of precaution)? Since there's no problem when the bike is warmed up, I ruled out a bad coil or cable....
vrprabhu is offline
Old 14th December 2024, 20:54   #14
Since the oil is new and of the recommended grade, it's not likely to be the issue. Also, not advisable to switch to different non-recommended grade; it can cause other issues, like excessive wear, in this case as you're going for a lighter oil.
I think the coil could be a potential issue (not because you changed the cap; just in general). You can test the coil yourself: see if it generates blue sparks on the plug. Orange or yellow sparks indicate lower temperature sparks, which is less than ideal for proper combustion (refer manual or articles for detailed info). I know it can be tested with a multimeter as well, but don't know how. So, may be get it checked with an electrician or mechanic.
If the ignition coil is fine, I guess that only leaves the engine oil. Can't think of anything else on an old bike that could cause this issue (newer bikes have many sensors that may be faulty and muddle up the ECU). So, if you are sure it has to be the engine oil, I suggest to look for different oils of the same grade. Depending on the quality, synthetic/semi-synthetic etc. the characteristics of two different oils of the same grade can still be significant enough to cause this issue, which only gets more apparent in colder weather. So, compare your current oils' spec sheet with competitors'. Of the specs listed, lower 'Pour point' I think is a good indicator of an oils' cold temperature performance. It is basically the lowest temperature where the oil would still flow (not sure if under gravity or a specific force). So, if a different oil has a significantly lower pour point and a higher 'Viscosity Index'- which is basically how adaptive an oil is throughout different temperatures- it indicates that it might perform better under cold weather.
BullettuPaandi is offline   (1) Thanks
Old 15th December 2024, 20:15   #15
vrprabhu's Avatar
Thanks for the tip on the spark colour - will check it out.
My R&D on various brand of engine oils (Yamalube, Motul, Elf, Eni, Shell, Castrol, Gulf, Valvoline, HP, BPCL et al and usage varying from pretty cold weather - single digit temp, early morning ride - to very hot temps >40, peak summer, afternoon) led me to conclude that Valvoline was the smoothest in the 20w40. But, it's problem was the oil would degrade very fast i.e. within 1000 kms.
Getting 20w40 is tough, because the most commonly stocked is 15w40 grade and shops aren't keen to stock slow moving items.
vrprabhu is offline
