Team-BHP > Motorbikes
Old 16th October 2019, 17:46   #1
Thanked: 6,658 Times
DIY: Assembling your motorcycle clutch!
So a few weeks prior I had rebuilt my clutch but due to messy hands I didn't bother with taking enough pictures, though you can see a few if you look up my (Bajaj CT100B - Utilitarianism Redefined!)ownership thread.
Anyhow, I did managed to take a few snaps of the thing being re-assembled, so here goes.
The Clutch comprises of the following parts;
DIY: Assembling your motorcycle clutch!-6uicdzq6uepgllv7lh24k6kcui.jpg
Now most manuals online including the one above for some reason misses to mention the Judder Springs, so here goes;
DIY: Assembling your motorcycle clutch!-xr650r5_img_000184.jpg
Now we get to business!
Step 1:
Make sure you have all the parts required to assemble a clutch and that they've been properly oiled(preferably Friction Plates dipped in oil overnight), also doesn't hurt to confirm with your workshop manual that all components are within their usable limit;
DIY: Assembling your motorcycle clutch!-imag0107.jpg
Step 2:
Install the Judder Springs(see orientation from the shop manual extract shown earlier), followed by the unusually small looking Friction Plate;
DIY: Assembling your motorcycle clutch!-imag0108.jpg
The Springs sit snug within the small plate like this;
DIY: Assembling your motorcycle clutch!-imag0110.jpg
Step 3:
Install a Steel Plate followed by a Friction Plate, one by one, the last plate you'll deal with with obviously be a Friction Plate;
DIY: Assembling your motorcycle clutch!-imag0111.jpg
After your done with the Steel Plates and the Friction Plates make sure to install the Pressure Plate, ensuring that the groves on it slot perfectly in place.
Now carefully turn the assembly over ensuring that the Pressure Plate doesn't slip out of the groves. Using two regular spacer's for 10mm bolts install two of the springs and bolts, like this;
DIY: Assembling your motorcycle clutch!-imag0112.jpg
This is done so that there's enough slack for the friction plates to be realigned while inserting the assembly into the clutch basket but at the same time there is enough pressure to ensure that the Pressure Plate doesn't sit misaligned.
Step 4:
Once the assembly is seated within the clutch basket(for illustration purposes my clutch is still in my bedroom ) you could remove the spacer's and install all the springs and then install the center piece;
DIY: Assembling your motorcycle clutch!-imag0105.jpg
DIY: Assembling your motorcycle clutch!-imag0104.jpg
DIY: Assembling your motorcycle clutch!-imag0103.jpg
Step 5:
Do note that the Center piece is made of aluminum and can crack at the slightest sneeze.
DIY: Assembling your motorcycle clutch!-imag0113.jpg
So commonsense dictates that they should be sequentially torqued evenly in a Criss-Cross pattern, and you're done!;
DIY: Assembling your motorcycle clutch!-imag0102.jpg
Here's a snap of how things'd look inside the motorcycle, do note that the clutch release bearing is inserted in the below photo:
DIY: Assembling your motorcycle clutch!-imag0086-1.jpg
Here's a closer snap of the clutch nut with the release bearing removed;
DIY: Assembling your motorcycle clutch!-imag0089.jpg
Extra Pointers
Here's a snap of the clutch nut tool, remember that the clutch nut is reverse thread, same tool is used to undo the centrifugal filter rotor, though that one is regular thread, do make sure not to mix them up;
DIY: Assembling your motorcycle clutch!-product500x500.jpeg
A clutch holder gets the job done easy, cause chances are you'd be replacing a used up clutch and putting the bike in gear and using the rear brake to hold the basket in place would most probably not work as the clutch would start slipping under load;
DIY: Assembling your motorcycle clutch!-product500x500-2.jpeg
But since mines a Pulsar, I locked the clutch basket using the scissor gear holder for convenience;
DIY: Assembling your motorcycle clutch!-product500x500-1.jpeg
An old biker's tip would be to wrap a 5 Rupee coin in a piece of cloth and jam it between the primary and clutch basket, though not recommended.
As for taking the clutch cover off, I'd advise that you look around the case for support tabs, the manufacturer intentionally leaves them so that the clutch cover can be leveraged off, though make sure to not do anything that'd scar the aluminum.
A rubber mallet would help as well in the event you're not able to spot any of the tabs.
So that's all folks!
Happy DIY'ing!
A.P.
ashwinprakas is offline   (47) Thanks
Old 16th October 2019, 21:26   #2
deepfreak15's Avatar
Thanked: 3,093 Times
re: DIY: Assembling your motorcycle clutch!
Amazing! You should start consulting on this kind of maintenance for big bikes. Could give some service centers a run for their money.
deepfreak15 is offline   (3) Thanks
Old 17th October 2019, 09:32   #3
Thanked: 3,292 Times
Hi Ashwin,
Is there a recommended tightening torque value to be set while tightening the clutch plate retaining bolts ( 4x off )?.
In my honda ( you know it right), the clutch plate bolts got loosened while riding and the bike lost the clutch. Consequently, it lost the kick lever action too.
srini1785 is offline   (1) Thanks
Old 17th October 2019, 16:38   #4
VijayAnand1's Avatar
Thanked: 3,563 Times
Re: DIY: Assembling your motorcycle clutch!
You should probably, share this in xBhp too, probably that's where most Pulsar maniacs hang out. Nonetheless, a good job.
Cheers!
VJ
VijayAnand1 is offline   (2) Thanks
Old 17th October 2019, 18:13   #5
Thank you for the kind words.
Fact be told, the bigger the bike the easier it is to work on. A few of the senior members on TeamBhp who own big bikes and work on them can vouch for it, though I doubt they would take the effort to make a thread considering the lay of the land as maintaining warranty status is critical for the rest.
From where I see the sheer number of support material(its media as in DVD's for some manufacturers!) for these big machines alone would really make us wonder whether these Indian offerings should even be worth the hassle to save some pennies as in most cases everyone except for factory trained mechanics are going in blind and learn things as we go along, which is far from ideal IMHO.
The only upside of working on such pre-historic machines is that they stay true to keeping things simple, even the Pulsar's with their scissor gear which though is a thing of nightmares for the roadside mechanic is in reality merely a pre-loaded sprocket that is designed to avoid lash, uncommon but again simple to grasp.
Ánd as far as the basics goes,
DAN'S ONLINE MOTORCYCLE REPAIR COURSE
is by far the best source(rather Gold Mine!) of consolidated information available online, and its FREE!.
Originally Posted by srini1785 View Post
Hi Ashwin,
Torque value's aren't provided for the spring bolts due to varying nature of spring tension, they should be tightened until they sit snug.
In theory the spring tension should hold the spring bolts in place, you could try replacing springs or if you already have then try using thread lock.
I'm quite surprised that the kicker is linked to the clutch on a Honda, due to the off-road pedigree I presumed it would be otherwise, if it gives you any solace the kicker on my CT100B is hooked up the same way.
ashwinprakas is offline   (4) Thanks
Old 18th October 2019, 01:43   #6
Thanked: 35 Times
Originally Posted by ashwinprakas View Post
Now most manuals online including the one above for some reason misses to mention the Judder Springs, so here goes; Now we get to business!
1. Neat, and thank you !
2. Judder spring info is from Honda Common Service Manual 1995 Ed?
3. Where did you get the special tools?
Originally Posted by VijayAnand1 View Post
You should probably, share this in xBhp too, probably that's where most Pulsar maniacs hang out. Nonetheless, a good job. Cheers! VJ
+1. Even though shop manuals are there, practical aspects are discussed only on forums like these and is always an inspiration for novices like me.
Torque value's aren't provided for the spring bolts due to varying nature of spring tension, they should be tightened until they sit snug. In theory the spring tension should hold the spring bolts in place, you could try replacing springs or if you already have then try using thread lock.
For NS, they recommended Loctite 243 + 1.2 kgf-m in the Bajaj training video, but the mechanic used a "clutch centering tool" to first completely compress the lifter plate and prevent it from breaking.
Suzuki recommends 'snug fit' for GS150R and 0.51 kgf-m (almost nothing!) for Gixxer 155. In Honda manuals, it is usually 1.1-1.2 kgf-m for these bolts.
Bajaj and Suzuki use 5 or 6 bolts, so the load is reduced (?).
P.S. 'Like' of Xbhp = 'Thanks' of TBhp .
ashwanth is offline   (1) Thanks
Old 18th October 2019, 08:25   #7
Red Liner's Avatar
Thanked: 19,374 Times
Great job AP. I want a cheap bike so i can do these things myself just for kicks.
As someone who has done some kind of DIY on an import one owns, i will tell you why many refrain beyond a point.
1. Replacement parts are extremely expensive
2. They are not available off the shelf
3. They take a month or two to reach your hands if not sold by aftermarket suppliers in India.
4. Therefore, god help you if you over torque and break something in the guise of DIY
5. Because then, your bike is standing in your public parking lot with the innards completely open, waiting for parts for a month or more.
So you see, unlike abroad where you can walk in somewhere and buy the part cheap or just order online with one day delivery, that doesn't work here.
And lastly, yes, some of us are so focused on not breaking anything (see 1-5 again) that the last thing on our minds is to take photos or a video for a DIY report
The other issue is mental fear. See, almost every guy who owns an import has not owned AND worked on his own cheaper bikes and then graduated (very normal abroad, its like schooling at home, or should i say tooling at home (fooling even? Alright i will stop). So when you land up with an import, the obvious thing to do is to do what you always did since you turned 18.
Book an appointment with the service center
Red Liner is offline   (2) Thanks
Old 18th October 2019, 10:15   #8
Thanked: 62,243 Times
Excellent post, very well explained.
Would love to see some more DIY jobs shown like this.
Jeroen
Jeroen is offline   (1) Thanks
Old 18th October 2019, 12:46   #9
Good eye! The common manual though a gem was lacking a consolidated representation of the installation and I got the info from an online thread pertaining to the Honda CRF250, hence why the diagram is the exact same as given in the common manual.
The only special tool's(Purchased Locally) I have is the scissor gear holder which I also used to lock the clutch hub in place as well as set timing at the primary, and the clutch nut holder which I literally bought at the last moment as the double sided tool I had was not of the correct size, imagine the chances of that happening and that too with a double sided tool, no less! ;
DIY: Assembling your motorcycle clutch!-imag0088.jpg
Still cracks though if not careful, since I'd bought a replacement assembled unit from Bajaj which coincidentally had to be disassembled due to misalignment, I gave my extra bracket to a friend who is rebuilding his P220 from scratch as he had managed to crack his.
If you can afford a Royal Enfield then look no further than a Cast Iron or at most an AVL, my preference leaning towards AVL's as I believe them to be superior to the CI and UCE's, though any purist out there would hunt me down for making that statement.
If you'd rather perfer buying a new motorcycle then go for the CT100(Kawasaki Origin Block, there's also a Self Start variant with Bajaj Block) eyes closed.
Even though they've managed to introduce SAI to mix, a few minutes of tinkering and you can easily scrap it, other than that this is literally(to my knowledge) the only motorcycle available in the current market that has the CDI powered directly from the stator i.e would keep running even post apocalypse! I believe only the CB Points predates this setup and they've been out of production for more than a decade.
But do hurry! As the Kawasaki block would definitely not make it to BS6 territory, unless Bajaj has some tricks up their sleeves.
You're being too cautious Sir, anyone who can afford to buy a SBK can definitely afford proper tools(read torque wrenches) and having had the opportunity to go through the Haynes workshop manual of the most basic entry the Honda CBR250R, I'd say that unless someone intentionally goofs up it's unlikely that they'd break something as even the slightest of information is provided with respect to disassembly as well as assembly.
In fact so much information that it'd make serial jugaad'ists like myself envious.
True on so many levels, mainly the middle class one.
Still being a teenager when I got my first motorcycle I used to be scolded for even going as far as taking the seat off and I too did stick to ASC for a bit but after I realized the quality of workmanship I simply couldn't let my motorcycle be worked on by someone that I did not trust.
Even a year or two back when I was still a minion of the corporate's, due to lack of time I handed my motorcycle over to the ASC for a front end OH for which they charged me over 4k(Less than 1k for consumables, rest for labor) and still managed to mess up my fork outer tube(Read 1.5k for replacement parts alone, yet to replace).
So to sum it up I go back to the following quote with a little addition of my own;
"It takes more love to share the saddle than the bed, and even more so to share the wrench!"
If all goes well I have a few more DIY Job's planned for the motorcycle, one thing unique about the Pulsar is that it sports a dry stator which is uncommon on motorcycle this side of the globe, so I presume I will have an easier time clicking pictures when simultaneously working on the motorcycle.
And it goes without saying, I do envy your man-cave and hope to work up to something similar in the years to come.
Cheers,
A.P.
ashwinprakas is offline   (3) Thanks
Old 22nd October 2019, 10:36   #10
Have tried replacing the springs already and measured them to check if their free length is as per manual and found ok. I am not a fan of thread lock or locktite as its not for those parts which require regular maintenance.
I have in the past suspected the threads and bought me a new clutch set and have no better results. Here's how the clutch side of the CD185 looks like. Pretty much a standard pulsar or CBZ type. I have since tightened the bolts as much as i can and have put the side covers on. As you can see from the pictures of the side cover which i have marked, the nuts came clean off before breaking a part of the pusher rod mechanism ( donno where that part went). It was a near catastrophic failure but somehow held through. I am pretty sure that even before this event i tightened the bolts pretty hard for snug fit.
Kick pedals of all motorcycles are connected to the crank shaft through the clutch plates. Same is with my caliber 115, suzuki supra and also my jawa which has the same shaft for both kick and gear.
I noticed a pronounced play between the main crankshaft drive gear and the clutch gear. Is that normal in a bike?.
DIY: Assembling your motorcycle clutch!-20191019_165550.jpg
DIY: Assembling your motorcycle clutch!-20191019_165535.jpg
srini1785 is offline   (2) Thanks
Old 22nd October 2019, 20:34   #11
adrian's Avatar
Thanked: 1,273 Times
There are several strength specified products from loctite. You can use medium strength loctite for parts that require periodic maintenance.
https://www.tryloctite.in/products/t...rs/loctite-242
You should always use a medium strength thread locker while reassembling the engine sprocket nut as it is known to loose up and damage the clutch casing.
adrian is offline   (2) Thanks
Old 22nd October 2019, 23:08   #12
As adrian has guided you, thread lock comes in different forms, the blue-one is used for parts that require regular maintenance.
That would depend on how the kicker is set up.
On a Primary Driver Kick Starter, the kicker turns the primary drive via the clutch basket, in effect enabling it to bypass the transmission completely.
DIY: Assembling your motorcycle clutch!-kickstarters_primary.jpg
I have used such motorcycles but I do not exactly recall the motorcycle so a bit of Googling and I found that the Fiero and Pulsar had the setup.
Though as far as ownership goes the CT100B is literally my first kick-only motorcycle, hence the surprise as the first time I figured that out what when stuck on an uphill trail where the motor stalled on me.
There is no play between the actual sprockets as its a snug fit, I doubt it would be any other way.
If at all play would be there then my first suspicion would be the clutch basket dampers, but I have a feeling you would've already inspected those.
Do keep us posted.
A.P.
ashwinprakas is offline   (2) Thanks
Old 23rd October 2019, 09:52   #13
I guess i'll give it a try. Its anyway better than trying to re thread a OEM part in a un professional lathe shop.
Attachment 1925915
Do keep us posted.
Just did not understand where the clutch plates go. Sure this set up is different from most motorcycles that i know in which the kicker is connected to the drive shaft pinion through the clutch. If the kicker is able to kick start your engine even when the clutch is held ( as when you change gears) then its a different setup. Probably, you can test this in your pulsar. Just hold the clutch and try kick starting the motorcycle.
The play is not on the clutch bolts ( sprockets??) . Its rather on the complete clutch assembly and the main drive pinion. By that i mean the play between the main drive gear ( from the crank shaft, Primary pinion gear #5) and the clutch gear ( outer gear , Large primary gear #4 ). I will try to make a video over the week end and post.
Old 23rd October 2019, 21:16   #14
Mines the P220 i.e Self Start Only, here's a picture of the engine.
DIY: Assembling your motorcycle clutch!-img20191019wa0014.jpg
Though its not mine, this block has way more than twice the mileage mine has clocked, its a friends block that was rebuilt from scratch recently, not definitely due to wear and tear but due to his professional curiosity as he is a company(car) trained mechanic by profession.
But I did ask a fellow enthusiast who owns a UG3 Pulsar 180 and it has a primary drive kicker as expected;
A video would help clarify the doubts.
The play I was referring to is caused by the following dampers wearing down;
DIY: Assembling your motorcycle clutch!-clutch-basket.jpg
To access them the hub has to be disassembled(done at lathe), not the recommended means of getting the job done as a complete hub replacement is the most ideal way of doing it.
Anyhow if these dampers wear down then there would be substantial play of the clutch hub.
ashwinprakas is offline   (1) Thanks
Old 28th October 2019, 19:56   #15
pixantz's Avatar
Thanked: 1,025 Times
All great. Only, it's not really as easy as it looks for all brands/models of bikes because for the higher spec models like 250cc and higher, mostly Japanese brands, there are certain markings on the various components which have to be aligned in a particular way or direction(like tyre's, for example), which 95% of "mechanics" who work on bikes everyday too don't have a clue about and only the more hardcore guys know who have info on assemblies for bigger expensive bikes etc k
The funny thing is, if assembly is done without knowledge of these markings, you would still end up fitting the thing and the bike would run too. But performance, reliability and longevity could have vast differences from what it should be.
Some example of problems can be like:
1) less than normal pickup and/or juddering and vibration even though clutch is new
2) premature and rapid wear out of the plates(sometimes as fast as within 500kms or less, or one month)
3) clutch failure
I can't give a whole list of which bikes have these markings on the components but I have seen premature clutch failure due to incorrect assembly in some bikes like older models of Pulsar 150/180, Pulsar135(now discontinued), HH Karizma.
Sometimes it takes a while to notice something is not right.
Just my two cents.
pixantz is offline
