Re: Compatible adjustable levers for my Apache 200 I would generally stay far away from after market brake and clutch levers. They do look pretty good, have to admit. But the risk of front wheel locking up because of an improperly greased nut is something that I can't live with. There is a nut near the joint which has to be cleaned and lubricated (or at least it was the case when I last looked at these levers, don't know if the design has evolved since then). And the tolerances for that joint are pretty high. If you get some dirt or grime in there which restricts free movement, locking up the front wheel is a very real scenario. |
