Team-BHP > Motorbikes
Old 18th March 2020, 12:53   #1
Thanked: 3,292 Times
Ways to detect the source of an engine case oil leak
I have been grappling with an annoying oil leak in one of the motorcycles that i am trying to restore. Its a 78 model honda cd185 twin. The problem is simple. While on center / side stand there is no leak whatsoever, when the engine is started, it leaks close to the mid section of the center stand.
I am reluctant to remove the engine from frame as i have already done it 3 times and it weighs a ton. Fixing it back to the frame is a 2 man job and yeah absolutely no question of splitting the cases. No, not at this point.
What are your suggestions to locate the source of leak? and how to remedy it?.
srini1785 is offline
Old 18th March 2020, 13:24   #2
Thanked: 6,658 Times
re: Ways to detect the source of an engine case oil leak
Isn't that where your crank case breather is located?
If so could it be that your rings are weak which is resulting in oil being discharged when the motor is running? Or simply cause you'd overfilled oil?
If it were the shifter seal, sprocket seal/collar or the neutral switch then the motorcycle would leak when kept on its side stand:
Ways to detect the source of an engine case oil leak-img_20200112_191602.jpg
On the CRF's and CB's of yesteryear they have a kicker stopper that sits under the crankcase, on the Unicorn etc it extends to be forward set pegs, the mounts are prone to crack and at times would result in leaks, but that is usually noticeable even when the motorcycle is left idle.
A.P.
ashwinprakas is offline   (1) Thanks
Old 18th March 2020, 13:57   #3
No. The breather hose entry ( don't know the exact tech term) is located on the top side of the case and the leak is on the bottom side ( am pretty sure of it).
You mean piston rings?. could you please explain?.
No. Filled as per manual 1.5 Lts.
Checked all of them and no sign of leakage. Besides, it does not leak when put on side or center stand.
Quite see what you mean but the leak is almost at the center of the case. The kicker stopper is at the right side so i doubt it.
Old 18th March 2020, 16:53   #4
If the rings are weak this would result in excessive combustion blow-by being transferred to the crank case, as a result oil would come out from the path of least resistance i.e ideally the breather.
The stopper extends from one side to the other.
Ways to detect the source of an engine case oil leak-whatsapp-image-20200318-4.50.46-pm.jpeg
Don't know why but that is how it is on the older CRF and CB series, but yours is older than the ones I've seen so do make sure.
Cheers,
A.P.
ashwinprakas is offline   (2) Thanks
