Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 27,956 views |
31st August 2021, 01:49 | #1 |
BHPian Join Date: Jan 2020 Location: chennai
Thanked: 314 Times
| My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Hi, this is my first thread in team-bhp, I would like to share my experience on how I converted Bajaj Discover 125 to electric with lithium ion battery pack. Phase-1, Electric Scooter: I had some lithium ion cells, tools and accessories to build battery packs in home. With some cells in hand, there isn’t any application that comes to my mind other than a two wheeler. Started looking for used electric scooters with reasonable top speed and acceleration. I wanted a vehicle without battery because I didn't wanted to pay extra for old lead acid batteries. After some long search, finally bought a BSA Roamer scooter with 800W motor and controller. The outlook of the scooter was terrible with rusted metal parts and faded plastics. It started immediately with some temporary batteries and drove well. Ride quality was horrible, it felt like a cycle chassis. Pickup was fine but bike is not stable at 35kmph and most important thing is its brakes, nothing at all, even cycle brakes are better. Reluctantly bought it as there isn’t any other options available at that time. BSA Electric Scooter with 800W Hub Motor I bought the bike without battery, so I couldn’t able to take it to my home. Fortunately seller’s shop was within couple of km from my office, so I told him to keep the bike with him for two more weeks after the sale. Measured space available in bike for battery pack where the original lead acid batteries were kept. Started working on battery pack build. But I was not 100% convinced with the BSA Roamer scooter. Phase-2, Electric Bike with 40kmph speed and 50km Range: Reluctantly initiated battery pack build for BSA Roamer scooter. Planned to build a 1.2kWh 50.8V 23.4Ah small light weight battery pack with 126 cells in 14S9P configuration. The whole pack will weigh less than one of 4 lead acid batteries that came with the bike. BSA roamer scooter with 800W motor will do 40kmph top speed which is equal to an efficiency of 20Wh/km without including any losses. With a 1.2kWh battery pack I can easily do approximately 50km range every charge with 15% to 20% buffer. 1.2kWh 50.8V 23.4Ah Pack Couple of days later, seller called and told me that he wanted to buy the bike back from me and I agreed immediately without any second thought. Started searching in OLX again, this time I increased the search range all over Tamilnadu. I found a 750W motor and controller with inbuilt reduction gear. Till then I did not considered a retro-fit project since its time consuming, labour intensive and requires a garage or good place to execute the same. I reached out to my friend who has a shop near welding and fabrication shops. With everything is in place, finally bought the motor and controller. 750W Motor & Controller When I purchased the 750W motor and controller I wanted a decent bike with 40kmph top speed and 50km range with the lithium ion cells I had, strictly no additional purchases. I wanted a light weight small commuter bike suitable for city application. Now comes the most important part, base donor vehicle for this project. Started to plan the build and prepared the list of tasks starting with the search for a suitable donor vehicle which will decide the design and process. The donor vehicle should be light weight and easy to work around. Not much two wheeler conversion threads available on forums with Indian commuter bikes. Only few Youtube conversion videos were there which is of no use. Then started downloading bike frame pictures form internet and shortlisted Splendor, Super Splendor, Passion, Discover (OLD <2010 125CC/135) and Pulsar 150. After some detailed study eliminated pulsar 150 due to its weight and Super Splendor due to its limited availability in Chennai. Also not many SS were available on sale for less than 20k rupees in Chennai, so dropped it from the list. Now it between Splendor, Passion and Old Discover. 1st Generation Bajaj Discover 125CC Found this picture online, it looked like Bajaj has designed this vehicle with an electric variant in mind back in 2005 itself. Finally it struck, Bajaj Discover 125 is going to be the base vehicle for this project. Searched used discover in OLX, unfortunately not many available within my budget. In the end purchased the bike from a local used vehicle dealer. It was not in great shape, just another 12 year old vehicle. I specifically wanted that particular variant so went ahead with the purchase. Took it to my friends shop and that is its last few km's with its original heart. Phase-3, Electric Bike 40kmph, 125km Range Once again there is a change in specification. This time I got a weird idea to use all the cells I had for this single pack. I had close to 3.5kWh cells from different makes which I bought for different applications. It is not recommend to mix and match cells with different capacity which will create imbalance in the pack and reduce pack capacity and performance. Technically the lowest capacity cell will dictate the total usable capacity of the pack. Its risky because it is difficult to manufacture two identical cells from same batch of production. Still it is not an impossible task, if cells are matched and grouped together properly then it is achievable. Building a battery pack is a onetime process, there is no second chance. Once it is welded to the busbar, it is impossible to remove and rearrange again. Keeping the risk in mind, started the process to finalize the number of cells for the project. Target is to use as many cells as possible which will give longer range. Since motor and controller were already purchased, voltage is fixed but the number of cells in series is yet to be decided. I had both 13s and 14s options open because I do not know how the cell grouping is going to turn out. The main reason to go with Discover 125 is it has long flat seat and offers lot of space under the seat. Instead of going with regular box type battery and motor assembly like revolt and other bikes, I decided to put the battery pack under the seat. The pack is going to be a long and narrow one which will sit under the petrol tank and seat. Motor, controller and DCDC will be installed below the battery pack in the front. Measured the space availability and started battery pack drawing. Ordered Battery Management System, additional sensors for pack level voltage, current and motor temperature with wireless display, 12V 240W DCDC converter and some more accessories required for the project from China. Surprisingly everything reached within 2 weeks. Removed Silencer, engine, rectifier, air filter, LV wiring harness, petrol tank and everything that is not required on the vehicle including saree guard. Chassis is widened a bit on top to accommodate two deck pack. Due to this I was forced to cut out the bottom part of the petrol tank. Anyhow the fuel tank is not functional anymore and it is there for aesthetics only. Modifications in Chassis Petrol tank cut-out Welded the mounting plate for motor and installed the same after aligning it with the rear sprocket. Its a low RPM motor with inbuilt reduction gear for high torque. Hence we chose M80 sprocket (36/17) and chain which does not affect our top speed much. Once motor is installed in its place started working on the sides fairing to protect the packs and motor from stone, dust, etc. This is the most important part of the fabrication after chassis modification. It protects battery pack, motor, controller and DCDC from dirt, stone and water splash while on road. Also this would avoid unwanted attention towards vehicle while on road or in parking. I asked for a simple functional cover on both sides and in front with a cutout for motor cooling on the right hand side cover. But fabricator included some pattern near the hole and prepared similar circle on the left side panel for symmetry. Metal Fairing Battery Pack When it come to electric vehicle, Tesla is the inspiration for everyone and I am no different. I wanted to build a battery pack like Tesla modules and decided to fabricate an enclosure and cell holder with clear view acrylic. Only clear view acrylic is used for complete construction with adhesives, no bolt or screws in pack construction. I even tried to incorporate single cell fuse but couldn't able to do it with spot welder and I don't want to solder on cells. Hence settled with nickel strip and spot welding. Atleast it has couple of similarities to Tesla battery pack - 18650 cylindrical cells and raw look of the cells and busbar from outside. Battery Pack Specifications: Pack Nominal Voltage - 50.8V Battery pack is split into two modules. Small module (6S21P configuration) is kept on top of big (8S24/26P configuration). Top module weight is equally distributed on the bottom module. Cylindrical cells are structurally strong and since weight is shared equally across all cell, there is no stress on cells in the lower deck pack. Instead of regular ABS cell holder, multiple clear view acrylic sheets are used as cell holders. Acrylic shop guy suggested a special adhesive which is super strong and transparent. The low viscos adhesive is dielectric and will react only acrylic and some plastics. While spot welding, accidentally pressed the pedal twice and it punctured the cell. Luckily it was on the positive side, if it had happened on the negative side it would have been an early Diwali. Just a reminder how dangerous the lithium ion batteries and pack building process. Extra care must be taken for safety to avoid any accident or blast. Spot Welding Mistake 14s 60A BMS with bluetooth and PC connectivity option. Never used PC software as mobile application is more than enough to configure and read parameters. Mobile APP has electronic lock feature to turn ON/OFF battery pack. It has cell balancing feature with multiple strategy, user can configure using mobile app based on their requirement. 14S 60A Battery Management System Vehicle Assembly Washed the chassis and painted the whole chassis with spray can and installed battery tray. Installing the pack in vehicle was the trickiest part in the project. Initially I thought the fully built pack can be installed by sliding the pack from the rear of the vehicle. Unfortunately the pack was heavy and clearance was too tight to execute the plan. Fortunately I figured our the problem while trying out with outer enclosure without cells. Only limitation to split the pack into two is the BMS LV connector (voltage monitoring and balancing lead) in BMS which is a single 15-pin connector. After sorting the connector, prepared two independent modules and installed them in the vehicle. Two temperature sensors one in each module was also connected to BMS. Acrylic adhesive is used to secure the second module to first module. For secondary protection, a thin metal clamp was installed on top of the pack to firmly secure it to the battery tray. Fully Assemble Electric Discover Took the vehicle out for a ride, pickup was on par with petrol vehicle even with a pillion rider. Its top speed was only 35kmph due to RPM limitation which was 5kmph less than the expected speed. After driving it for 150 more km within the city, I felt the top speed of 35kmph is not enough for a vehicle like discover. Phase-4, Electric Bike 80kmph, 125km Range Finally convinced that this battery pack and vehicle deserves a powerful motor and decided to double power with a 1.5kW Motor and controller. Space was not an issue as it can easily fit a larger motor and the measurement confirmed the same. I purchased a 1.5kW motor and controller set with low voltage switchgear set including multiple power mode, forward and reverse switch. 1.5W Motor and controller Removed the existing motor and controller. This 1.5kW motor does not have reduction gear and can do a maximum of 3000 RPM. Used original discover 14T sprocket on motor side and TVS XL super chain 50T sprocket in the rear. It worked perfectly and reached a top speed of ~90 km/h on speedometer and 77 km/h in GPS. Pickup is on par with 125CC petrol bike. Overall the second version with updated motor and controlled felt more like a 125CC petrol bike in city and average speed is almost similar to ZMR average speed in most of the city routes. 14T Sprocket on Motor Side Also replaced some old faded plastic parts, completely new 12V wiring, replaced both front and rear tires. Painted the alloy wheels and petrol tank for fresh look. New 1.5kW Motor The new controller was longer than the 750W controller, hence installed it below the petrol tank. Also moved MCB on top of controller for easy of access. Motor Controller In the updated version, installed wireless display unit in the console to monitor pack voltage, motor temperature, pack charge and discharge current. This reduced the dependency on mobile phone. Also included a second throttle without release spring on the left hand side to maintain throttle input for highway rides. It is a simple cruise control method to maintain constant throttle input and proved very effective in highway trips. The bike can be charged in 4 to 5 hours with a 10A charger. With 20A charger it can be charged in less than 3 hours. Updated eDiscover Range Test-1 After successfully completion, took the vehicle around the city al lower speeds around 40kmph to build confidence. After some 400kms, decided to do a proper range test. Selected route with 50% city and 50% highway. Charged the pack to 100% upto 4.1V/cell (~92 to 95% of total pack capacity). Maintained 40kmph speed throughout the trip. At the end of the trip, pack reached 48V with 20% SoC available for further use. 150km Range Test Average Speed Test - 2 There is some perception that electric bikes are not suitable for weekend trips due to range and speed limitation. So I did back to back ride in identical route with eDiscover and ZMR. Agenda is to maintain maximum possible speed in ZMR and maintain 65kmph speed (speedometer) in eDiscover. Surprisingly the average speed difference is only 14kmph even tough I reached upto 110kmph top speed in ZMR. I could able to complete this trip with 35% remaining SoC left in the pack. Average Speed Comparison Range at high Average Speed Read some articles regarding 110+km range at 24kmph average speed in Ather forum(Link here). I was curious to check if I can achieve 100km range at 40kmph average speed in my eDiscover. With some confidence from previous 65kph cruise speed trip, I decided to do this trip at 55kmph cruise speed for 100+ range. Once again its in the same tried and tested ECR route. And the trip ended exactly at 99.9km in GPS data-log and 103km in ODO meter. 100km Range at 40kmph average speed Since Aliexpress site is banned in India, most of my update plans were stopped including 20A fast charger and new BMS. Thanks |
(192) Thanks |
The following 192 BHPians Thank efuture for this useful post: | 2himanshu, @og_adi, abhi802, ach1lles, AdityaDeane, aeroamit, aim120, Aish_4761, akash_v12, Akshay6988, AKV10, Altima, am1m, amit_purohit20, amods, amol4184, amrutmhatre90, amvj, anandhsub, anumod, Arvi95, arvind71181, asbshyam, ashpalio, ashwinprakas, athalaga, audioholic, auto_enthusiast, av8er, AZT, a_chelat, badboyscad, Balaji31582, bikertillidie, blackasta, BlackPearl, BLACNWYTE, BoneCollector, BopsKA12, brownkaiser, callvvijay, CARDEEP, carfreak7, CarML, catchjyoti, comfortablynumb, corvus corax, CrAzY dRiVeR, createrkid, dailydriver, deepakr82, deep_bang, demonoider, Desmosedici, DevilzzzzOwn, DH82 Tiger Moth, drrajasaravanan, Eddy, ego4evr, Everlearner, Fiestaboy, FloatingCanvas, Gaur, gauravdgr8, girishkamath, girishv, GJ01, gjnnbagal, Glifford, GTO, harshithkashyap, hdman, hemanth.anand, Hemi6.2, HumbleBee, ilangop, inclmal1, InControl, Indian2003, Inline_3, Jaguar, Jakku, JayKis, Jhinchak, jithin23, JithinR, JLS, John316_WRC, jomson13, jothishX, KA18, Kams_cars, kap04, karanddd, Karthik Chandra, KK_HakunaMatata, K_Drive, Living2Drive, livyodream, mac187, maddy42, Mahesh Prasad, mallumowgli, manubg92, mh09ad5578, mobix, MOUNTAINMAN, mvadg, myavu, nairrk, ndnesh, neerajdan, neil.jericho, NG_EV, nimz_blr, NirmalK, nivatakavacha, OPMaurya, parathmaniraja, pkulkarni.2106, Potatopoco, pradeepkc, PraNeel, pritanshchandra, psispace, pun337, quantobigboot, RaceHorse, raghu.bramha, rahulsenapati, rahulskumar, Rajeevraj, raksrules, ramnaresh_2000, ramsudhir, Rehaan, Reinhard, Rennjit, RiderZone, RoboCop13, Rocky_Balboa, RohaNN_kWh, roshithr, Rshrey22, RunSam, saikarthik, saikishor, sainyamk95, saisree, sajaijayan, saket77, sandeepmohan, sangam_mm93, sanjaykk, satishv1987, Scarlet_Rider, Shubhendra, SKC-auto, skyocean, Slick, SnS_12, somspaple, sramven, Sran, sri_tesla, SS80, StepUP!, SuhairZain, sujithsidhardha, sukhbirST, sukiwa, superguy282, SUPERSPORT, sureshkumar, Tgo, Thatautoguy46, The Great, The_Outsider!, tikku.dk, turboNath, turbowhistle, Victor-whiskey, VijayAnand1, vishegde, vsaravind007, warrioraks, WhiteSierra, WizSatish, XRoader_001, yesyeswe, ysjoy, Zinda |
31st August 2021, 08:25 | #2 |
Team-BHP Support | Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Thread moved to the Motorcycle section. Thanks for sharing! Will go to our homepage tomorrow |
(1) Thanks |
The following BHPian Thanks GTO for this useful post: | efuture |
31st August 2021, 09:09 | #3 |
Distinguished - BHPian Join Date: May 2010 Location: Bangalore
Thanked: 12,026 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery What an amazing build! Hats off to you sir, I am in awe of this! You have amazing skills. |
(7) Thanks |
The following 7 BHPians Thank am1m for this useful post: | efuture, mvadg, neil.jericho, sajaijayan, Scarlet_Rider, Sran, sri_tesla |
31st August 2021, 09:09 | #4 |
BHPian Join Date: Mar 2020 Location: KL 01
Thanked: 339 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Wow! What a thread. This is how electric bike conversions should be. Clean and inconspicuous. The integrated display looks fab. Does your controller support regen? I had a BSA Diva scooter lying around with a dead battery and a 250 watt motor. Had plans to upgrade it to 1000w minimum with a Li Ion pack. Good that you went with a 1.5kw motor, that's a must for these kind of upgrades. Would you able to share where you sourced the Samsung 18650 cells? I've trying to procure genuine ones online, but the prices quoted are astronomical (in the 500-700 range). I had a ordered a spot welder from banggood couple of months back. Lost all hopes of receiving it when it arrived out of the blue last week. Thinking of building a 24v battery pack. |
(7) Thanks |
The following 7 BHPians Thank jothishX for this useful post: | FloatingCanvas, InControl, KK_HakunaMatata, mvadg, neil.jericho, parathmaniraja, Scarlet_Rider |
31st August 2021, 09:14 | #5 |
BHPian Join Date: Dec 2005 Location: bang
Thanked: 3,117 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Let me be the first to congratulate you on this wonderful project. Its the most complete conversion project that i studied in detail. It would be great if you can share with us the following. 1. Wiring diagram 2. Schematics of the battery bank - If possible Elegantly done. All the best. PS: I've always had the feeling that we are doing the wrong thing by adapting the battery and motor to a bike frame. Its time we thought of the reverse, adapt the frame to the battery. The frame was after all built for an ICE not motor. Last edited by srini1785 : 31st August 2021 at 09:38. |
(6) Thanks |
The following 6 BHPians Thank srini1785 for this useful post: | anandhsub, FloatingCanvas, mvadg, neil.jericho, parathmaniraja, Scarlet_Rider |
31st August 2021, 10:05 | #6 |
BHPian Join Date: Mar 2012 Location: KA03
Thanked: 2,855 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Wow! Nice detailed post. And congratulations on neatly transforming the bike into an EV. Please post the exact links to the parts or the names, brands and specifications of the parts; all the design tools you used to size and configure the batteries, control units and the motor. It's really difficult to source good lithium batteries at a decent price. I am now wondering if Indian businesses faked a war with China to prevent us from sourcing cheap parts from Aliexpress |
(3) Thanks |
The following 3 BHPians Thank mvadg for this useful post: | InControl, neil.jericho, Scarlet_Rider |
31st August 2021, 13:40 | #7 | |
Distinguished - BHPian Join Date: Aug 2009 Location: Cochin
Thanked: 19,328 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Quote:
I would suggest that you recheck the frame of the battery stack and how it is mounted to put pressure on the chassis. There will probably be some further strengthening of the frame and chassis that is needed, to take the long term impact of the battery stack in its current placement. Last edited by GTO : 2nd September 2021 at 12:53. Reason: Quoted post deleted | |
(12) Thanks |
The following 12 BHPians Thank neil.jericho for this useful post: | amods, audioholic, deepfreak15, FloatingCanvas, InControl, nitninja, RaceHorse, saikarthik, Scarlet_Rider, SnS_12, sri_tesla, TorqMaster |
31st August 2021, 16:03 | #8 | |
(6) Thanks |
The following 6 BHPians Thank neil.jericho for this useful post: | audioholic, deepfreak15, FloatingCanvas, mvadg, SnS_12, SUPERSPORT |
31st August 2021, 16:15 | #9 |
BHPian Join Date: Oct 2014 Location: Punjab
Thanked: 3,185 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Absolutely fantastic work mate! For mechanically challenged people like me, looking at projects like this is always a pleasure, mixed with some jealousy . Just love how you've iterated slowly to better and better looks and functionality. Keep up the good work! |
(5) Thanks |
The following 5 BHPians Thank RiderZone for this useful post: | astrodex, InControl, mvadg, Scarlet_Rider, VijayAnand1 |
31st August 2021, 16:25 | #10 | |
BHPian Join Date: Jul 2009 Location: Bangalore
Thanked: 598 Times
I have two questions to quench my curiosity, 1. What is the total weight of the battery pack? Can you give the weight of the bike altogether to see the difference between electric and ICE versions. 2. Do you feel any change in the handling of the bike as the CG due to the weight of the batteries are placed higher? How do the bike handle with a pillion rider? I hope you can take/create many more such systems. I wish you all the very best. | |
(4) Thanks |
The following 4 BHPians Thank girishv for this useful post: | FloatingCanvas, mvadg, RiderZone, Scarlet_Rider |
31st August 2021, 17:04 | #11 | |
Distinguished - BHPian Join Date: Jun 2012 Location: BengaLuru
Thanked: 19,433 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery It was an amazing read for me to go through your journey and quite interesting to see the different iterations of your project. Someday I might want to try such a project on my Dio if time permits. Just for the heck of it and the experience of doing such a project. Your thread gives some good information on the configuration and setup and would greatly help. Could you explain in detail about the battery configuration Quote:
() Thanks |
31st August 2021, 17:45 | #12 |
BHPian Join Date: May 2007 Location: BLR MCT
Thanked: 900 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Fantastic and inspiring work! This is better finished than some of the e-bikes from dedicated factories What is the final weight of the motorcycle? |
(2) Thanks |
The following 2 BHPians Thank Mafia for this useful post: | Scarlet_Rider, VijayAnand1 |
31st August 2021, 20:27 | #13 | ||||||
Thanked: 314 Times
Unfortunately I couldn't able to retrieve links from Aliexpress for BMS, DCDC, wireless display unit, insulators and adhesive. Yes, also market is flooded with fake cells and heavy 32650 LFP cells which are suitable for energy storage applications only. Quote:
Yes, there is huge difference in handling due to CG shift, it is worse at lower speed(<5kmph) and better than regular version while on the move Not much difference with a pillion rider with respect to petrol vehicles Quote:
Thanks, Final bike weight is ~120kg which is 4kg less than the petrol version | ||||||
(18) Thanks |
The following 18 BHPians Thank efuture for this useful post: | AdityaDeane, am1m, audioholic, FloatingCanvas, InControl, jomson13, jothishX, K_Drive, Mafia, mvadg, OPMaurya, pun337, RiderZone, RohaNN_kWh, Scarlet_Rider, SnS_12, The_Outsider!, ysjoy |
1st September 2021, 09:46 | #14 |
BHPian Join Date: Jul 2021 Location: Pune
Thanked: 139 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Wow! that's a amazing modification. congratulations to you. this will be a great commuter bike. the display is really nice. only one confusion, is this road legal to ride on road? dose this require any endorsing on RC? I think our RTO dose not have any such retrofit endorsement facility. if you decide to use it regularly on public roads then what about legal compliance and insurance? |
(2) Thanks |
The following 2 BHPians Thank aneesh2M for this useful post: | AdityaDeane, efuture |
1st September 2021, 10:00 | #15 |
BHPian Join Date: Sep 2010 Location: Hyderabad
Thanked: 1,658 Times
| Re: My Electric Discover | I converted my Bajaj Discover 125 to electric with a lithium-ion battery Amazing conversion efuture! Congratulations! Curious to know whether you had to get any prior approval from the RTO for this or do they update the fuel type in RC later? |
(2) Thanks |
The following 2 BHPians Thank Scarlet_Rider for this useful post: | efuture, mvadg |
