Re: QJ Motor @ Auto Expo 2023 The SRK range features naked as well as faired bikes.
The SRK 400 is a naked bike powered by a 400cc, twin-cylinder 8-valve, liquid-cooled petrol engine that develops 40 BHP and 37 Nm. It comes with a 6-speed transmission:
Measures 2080 mm x 820 mm x 1085 mm (L x W x H) with a wheelbase of 1425 mm, ground clearance of 150 mm and seat height of 785 mm. Kerb weight = 186 kg:
13.5L fuel tank:
Telescopic upside-down suspension and side-aligned monoshock at the front and rear respectively. 260 mm dual disc brakes at the front and 240 mm single disc at the rear. Gets dual-channel ABS:
The SRK 400 RR is the faired version of the SRK 400:
The SRK 700 is a naked bike powered by a 698cc, twin-cylinder 8-valve, liquid-cooled petrol engine that develops 71 BHP and 67 Nm. It comes with a 6-speed transmission:
Measures 2070 mm x 790 mm x 1130 mm (L x W x H) with a wheelbase of 1410 mm, ground clearance of 135 mm and seat height of 790 mm. Kerb weight = 196 kg:
Telescopic upside-down and telescopic coil spring oil damped suspension at the front and rear respectively. 320 mm dual disc brakes at the front and 240 mm single disc at the rear. Gets dual-channel ABS:
15L fuel tank:
