I'd start with a little about the first service experience.
I had the first oil change done at 250kms and then we got it replaced again at first service schedule. I have little information about it while my son went for it. Nothing special done to improve dampening at fuel tank or foot peg area which I read or heard somewhere on internet. They did not even change the engine guard bolts since they did not have them in the stock. We'll have to be visiting again to get those replaced and also get the fork-seal installed which I understand helps prevent dust. Overall, KTM Khivraj at Indiranagar was just an average experience.
My son reported him about a weird issue, rather an error message he spotted on TFT console during his ride to work, check engine light was ON and cruise control not working, he tried to press info button to see if he could see any warnings, but he did not, except 'cruise control' briefly flashed on the screen and disappeared. He reported this to the service manager, he wasn't very clear on that and said he shall take a look at it during the service (may be they would look at the err codes via OBDII interface!!) and came back stating nothing found.
We thought this can be linked to the coolant temperature, once my son just turned engine off in traffic and coolant temp warning was displayed. Following video can indicate how effective and quick, the radiator fan could be to keep the coolant temp within limits.
We've got HSRP registration plates fixed almost post the 1K kms mark. We decided not to use plastic casing to avoid the vibration over long run. Hopefully, it's a right call.
- We are of an opinion to not load it much with the accessories, especially heavy ones. We have got Viaterra luggage loops/hooks that helps tying the tail bags at the rear while the current design of grab rails doesn’t do the job 100%. We may add trail pack / handlebar bag type of soft luggage in future to add the weight around center of the motorcycle. Top box should be last on the priority.
https://viaterragear.com/collections...se-strap-hooks
- We've added a motorcycle carplay from Aoocci, it's a C6Pro that we have installed and have used it only for one ride so far, should be able to get some inputs from this one ride experience. We may have to get a better ball mount (currently used the one comes with C6 pro and it seems to interfere with the TFT a little) though. I have not found it to be vibrating/rattling much, very little on lower RPMs. It has some good application if one is used to gmaps for going around. I've some GRIT routes mapped on gmaps, now I can use this device to ride those routes, although a Garmin/Tom-tom type would have been better to navigate using a gpx file. This also adds front and rear camera for continuous recording and TPMS. We are not so convinced about adding cameras and too many wires, we may remove them if don't find it great and more of an overhead. However, it has done well to capture some decent footage for the trip I just did.
https://aoocci.com/products/c6-pro-motorcycle-dash-cam
Decided to go take it on a bit longer ride last weekend. I figured a longer route from Bangalore to Nilgiris, about 12 hrs to Manjoor/Kinnakorai where I'm planning to stay, passing via a few WLS/NPs/forest stretches and also includes a short ferry ride over Mettur reservoir.
Adding some of the observations and experiences I have. I found mostly positive ones since still going through romanticism phase, hope to have consistent and better experience over longer term.
Found it to be very nimble on twisties and winding roads. It was even more fun climbing the hairpin bands. It feels so light and leaning is so quick and powers through the apex so neatly, it feels quite lighter and lot more punchier at the same time compared with other motorcycles I owned earlier. This one gave me more confidence, with the crawl function, even when I slowed down more than I should, it continued to remain tractable to complete the turn.
I have not used this much during the break-in period. Even during this ride, I have used it less, only around the ghats and it was a good experience overall. I needed to slot up and down very quickly over the ghat roads and this was so helpful in saving that time to clutch. Upshifting from 4-5 and 5-6 is rather smoother. I used downshifting/autoblipper even lesser, only remember using it down the ghat roads on hairpin band when I have to use more engine breaking and did that at high RPM range so it didn’t feel too harsh but again not as smooth as 4-5 and 5-6 upshifting with quick shifter+
I feel it may be slightly better after the first service and two oil change cycles we have gone through so far! Can't prove it though. I usually avoid riding in the city so I hardly have an opportunity to see the temperature rising much. However, the gears I was using during this trip was an off-road riding bottom (short one) + ankle length boots (socks too), leaving part of my shins exposed (a small portion below my internal knee guards). I felt the heat on left foot, exactly at the shin portion which is not covered by riding pant nor boots. I started to feel it when coolant temp goes above 91-92 degrees Celsius and 95 degrees is when I really feel it. My ability to stand cold or heat beyond uncomfortable zone is better than many or most and hence I just noticed it but it wasn't a big problem for me, once I start accelerating a bit the coolant temp would surely go below 90 degrees. For someone who's much sensitive, would need to make sure the riding pant and boots are going to cover the shin.
- Noise, Vibrations and Harshness:
I guess I mentioned earlier that I have observed only a narrow band of RPM where the vibrations go very high that it'll be felt on foot pegs, handlebars and tank in that order. This is typically between 4800-5000 or 5001. Recently I have found that this band may have narrowed further down slightly. At the top gear, it converts to 84-88kmph.
I observed, I got used to shifting up as soon as I hit this RPM range and found myself attempting to upshift even on 6th gear when I hit this range, took a while to unlearn that habit and remained aware of it, consciously skipping this narrow range to avoid that high vibration levels. I hope it goes away completely in future. Otherwise, it's not a deal breaker for what it offers.
Engine harshness is there, not so annoying when the helmet is ON, I have not found it to be so troublesome as some did.
Noise levels were more or less fine for the speeds I was doing this ride. During my return leg, I was pushing it beyond 90-95kmph and that’s when I had this loud humming noise. I need to figure out if it's really tire noise and nothing else, need some suggestions on ruling out things here.
One of the best stock ones I have ever seen on a motorcycles. The low beam is really good at the short throw it has, but the way the front oscillates up and down on the roads, it's been kept quite low and I feel its kept at optimum level else, it'd continue to blind the oncoming vehicles. This same feature, leaves it ineffective at speeds higher than 70-80kmph on highways, one has to turn on high beam at these speeds and I had to keep turning it off for oncoming vehicles and to be able to flash it so oncoming vehicles reciprocate too, most do not though. I'm waiting to see if KTM comes up with the power parts shown on 390 Adventure R edition and if we can get that aux lights, it'll be better than adding aftermarket ones. But this is something that needs attention asap if one is riding high speeds at night.
- Adjustable forks and shocks:
Seem to be doing a good job with the adjustability. We have switched forks and shock both to the comfort settings and it was apt for this trip. Riding some of those broken, backcountry roads was not at all a problem. I found it to be more comfortable and plush compared to the basic/stock settings. Recommend it for the touring while it can be changed when/if the surface and/or riding style changes.
I had a very short stretch of about 2-3 kms that I rode with deep ruts and rocks in and around an estate to get to a view point. At one place, front tire lost the ground and jumped off the line, I was saddling and impact was minimal, I could easily ground the feet to prevent further leaning of the motorcycle and lifted it back up. I feel the weight of motorcycle and the way it's felt/distributed is going to be less challenging and easier handling it in such a situation for most riders. This was confidence inspiring.
I'm so used to the high handlebar position on my Xpulse 200 4v pro that this one feels lower when I'm saddling. We want to wait till a good option for handlebar raiser is available in the market. We shall get used to the motorcycle dynamics in the meantime.
It's more or less in accordance with what is advertised by manufacturer. My ride was mostly through backcountry roads and lots of ghat sections. On trip meter, I see it at around 28kmpl average for the entire trip. While my tankful to tankful calculation for my refills averaged around 26+kmpl (avg speed 45kmph). My last stretch was on non-divided double carriageway roads where I managed to use cruse control at 90kmph for a few long stretches and the tankful method reported 28kmpl for this stretch. It's a decent return for the fun one gets with this machine.
○ Noise/Vibration: I observed some whirring noise in the front on deceleration, found only at the very last few kms on return stretch, it could be some fiber part vibrating, we need to figure out. My son had to tighten one of the nut/screws where windscreen is mounted which kept coming loose more than a couple of times. So, these are some of the things where we expected a better overall fit/finish/experience.
○ Riding mode glitch: I rode 70% of my return leg on rain mode while it continued to rain at regular intervals on my return. Towards the end of the ride, I tried to switch back to Street mode, it does show the green icon, confirming the mode is changed, but back on the main scree, it continued to show the Rain mode. I tried for offroad as well and same behavior. However, I felt that the change in throttle response was taking place, so its just that screen was probably not showing the mode change, this got fixed on its own by the time I reached home.
Palar, MM Hills stretch
Germalam Stretch
Around Ooty
Towards Kinnakorai
Returning via Manjoor-Geddai-Mulli route
Geddai Dam
Geddai Waterfalls
Bhavanisagar & Dhimbam
