Old 23rd December 2023, 21:37   #61
Thanked: 231 Times
Re: My negative experience with a water softener for the entire house
Originally Posted by balenoed_ View Post
I looked up a little more this DCAL. What it avoids is only scaling of water, not to bring down the TDS levels.
But I am not sure if scaling and high TDS levels are inter related. Is it so?
Did you check the TDS levels of your raw water and after DCAL immersed water?
Yes you are right DCal reduces the effect of the hardness producing compounds such that they do not deposit on pipes/ heated surfaces and pass through with water, thus there is no scaling.
TDS (Total Dissolved Solids) and Hardness are related, higher the TDS higher is the Hardness. As per IS 10500 standard for Drinking water, TDS levels of 500 mg/l are desirable and upto 2000 are permitted, similarly the limits for Hardness are 300 desirable and 600 permitted.
The only way to reduce/remove TDS is by Reverse Osmosis, Distillation and De-ionisation are some other, but viable for only industrial or medical purposes.
You can get the water tested and see how it compares with IS: 10500, if it does not have any other contaminants and the TDS is not very high, DCal should solve the problem of scaling and other problems associated with hard water in domestic use.
sudhirjaipur is offline   (2) Thanks
Old 10th January 2024, 13:22   #62
Thanked: 910 Times
I'm looking for a water softener for my flat in Bangalore.
Most of the bathroom resin/salt based softeners seem to be in the range of ~ 12k for manual regen, and ~ 22k for automatic regen. This is including installation, plumbing material if any would be extra.
So far, I've reached out to companies EcoWell, Abisol Aqua and few others.
Another company I reached it to installs some magnetic/alloy type conditioner which they claim to reduce staining and hairfall etc. They gave a demo, but honestly I didn't find much of a difference before and after. Price is around 6k per unit incl installation.
Is the resin based solution the best in this price range? 3M Automatic system is some 1.3-1.4L, out of my budget, and I don't think the plumbing system in my flat will support a common unit for the whole flat.
For those using an automatic resin based system, how difficult is it to manage? Do I just have to re-fill the salt every 1-2 weeks and the system will do what it needs to?
varkey is offline
Old 15th January 2024, 13:04   #63
Thanked: 231 Times
I would recommend DCal (www.dcal.co.in) as the best and economical product for your case. Please see my previous posts on this thread on this subject. Ion Exchange type softeners are not required if otherwise water is okay and only hardness is the problem. Cheers
sudhirjaipur is offline   (1) Thanks
Old 21st January 2024, 12:35   #64
Thanked: 910 Times
Thanks, yes I did see the earlier posts recommending DCal, however this is in an apartment society with 150 flats, so I don't think its something that I can do on my own as the overhead water tank is shared. I guess I will need the consent of at least the residents of my block and of course the sharing of expenses.
Their website seem to mention about a solution for apartment complexes as well, I have reached out to them to understand the costs.
varkey is offline
Old 21st January 2024, 13:13   #65
Thanked: 231 Times
In that case you can also consider this product from 3M
It would be good to find out the hardness of incoming water to your flat, the above works well when the hardness is below 200/300 ppm.
Alternatively the society maintenance team could consider a central system where a magnetic/electrical conditioner could be installed before the overhead tank.
Old 5th April 2024, 12:23   #66
Thanked: 54 Times
Folks, Any inputs on the Enviro water softener? It doesn't require electricity, maintenance which looks like a good option. I was informed the lifetime of the unit is 15 - 20 years.
Planning to install the same as I am not a fan of traditional water softeners occupying large space and requires lot of maintenance. If the Enviro water softener can achieve at least 70% of the traditional ones, I am completely okay with it.
Thanks in advance.
prabhu789 is offline
Old 7th April 2024, 16:09   #67
Thanked: 231 Times
Thanks in advance.
What is the problem you are facing with the water at present, have you got the water tested?
Old 8th April 2024, 11:20   #68
Thanked: 54 Times
Sudhir, Please find the water test results below
TDS : 450 ppm
Hardness : 375 ppm
Turbidity : 5 ntu
Calcium: 80 ( above normal scale)
Magnesium: 45 (above normal scale )
Iron : 0.03
Bacteria: present
The main issue is that water contains nice white sand like powder and its deposited on the bathroom floor tiles.
Old 8th April 2024, 11:41   #69
sagarpadaki's Avatar
Thanked: 6,846 Times
You need a pre-filter and a filter to trap the white sand particles irrespective of whether you use softner or not.
sagarpadaki is online now   (2) Thanks
Old 10th October 2024, 12:57   #70
Originally Posted by gypsyFreak View Post
Yesterday, i had Sales rep come over and give a demo. Eureka Forbes/Kent/ZeroB all use the same technology (Ion Exchange). Basically this removes Calcium and Magnesium and adds Sodium (Salt). It needs regular (weekly) salt topup for regeneration and once in 5 years resin replacement.
Cost is EF : 20k, Kent : 18K and ZeroB : 22K + Maintenance ( Salt : 300 and Resin 4k)
Sales rep of Waterizer was also invited. Their system is different, instead Ion exchange, it simply breaks up and makes them inert, incapable of bonding. So no scales are formed. Checked with two references in our apartment who gave positive reviews. It's more of a conditioner.
Cost : 14k + Maintenance (Soil filter replacement : 200)
I am thinking of taking the dive on Waterizer and see how it works in one bathroom.
But still curious on other options like dcal mentioned above (no overhead tank for us ).
Anyone has any idea about ECO CRYSTAL softener, IFB recommends and sells this, costs about 2k. If it can be used in Washing machines, it might work on Geysers too...
Have you tried using the waterizer, and do you have any updates now? I have recently contacted 3M for the softener and waterizer for the conditioner. The 3M costs around 1.3L but does the job nicely. I feel it's very expensive. The waterer is alternatively low price, but I'm priced. See your quote for around 14k, whereas I received a quote for 47k (which seems abnormally high). Could you please help me here with the dealer contact? I am looking to go ahead with the waterer; any help/guidance would be much appreciated.
imjafr is offline
