Originally Posted by anandpadhye
(Post 2461559)
While reading the thread on an issue with a Scorpio in Ladakh (http://www.team-bhp.com/forum/techni...stuck-leh.html), I came across the information: "The engine check light does come on at high altitudes and apparently allows the ECM to 'relearn' the oxygen levels being read by the oxygen sensor and change fuelling accordingly." I went over the owner manuals of my Hyundai Tucson and Skoda Laura, but could not find this information in there. May be I overlooked, so will check again tonight. So far, I thought that "Check engine" light means something is wrong and I should pull over and stop at a safe place to investigate further. If the same light, in certain situations, indicates that "engine is relearning, don't worry, please continue driving", what's the way to differentiate between the two? |
Originally Posted by dadu
(Post 2461566)
Check engine comes only as a warning or malfunction not learning. |
Originally Posted by DerAlte
(Post 2461749)
...'relearning' is always 'silent' - there is no indication associated with it. Error / fault annunciation in automobiles (like Check Engine light) are never ambiguously associated with *any* non-error operating situations... |
(Post 2461559)
W So far, I thought that "Check engine" light means something is wrong and I should pull over and stop at a safe place to investigate further. If the same light, in certain situations, indicates that "engine is relearning, don't worry, please continue driving", what's the way to differentiate between the two? |
(Post 2461566)
There is no such differentiation, Check engine comes only as a warning or malfunction not learning. |
(Post 2461749)
^ +1. Altitude 'relearning' is always 'silent' - there is no indication associated with it. Error / fault annunciation in automobiles (like Check Engine light) are never ambiguously associated with *any* non-error operating situations as a policy by ALL ECU makers. The only exception is 'steady' light at start-up indicating 'busy with initialization', but then start-up is not a normal operating state. |
Originally Posted by ssh1979
(Post 2461802)
I saw that discussion on the other thread :) Few notes from the OM of Ford Endeavour (3.0l 4x4): Rev limit is restricted (limit not specified) at high altitudes ~ 16000 ft. This is by design and is indicated by the engine light switching and remaining ON, till when the altitude decreases. No special service is recommended in such circumstances. |
Originally Posted by SS-Traveller
(Post 2461827)
Why does the Scorpio come with two 'check engine' lights - one called the 'engine check/malfunction lamp' (#16) and the other called 'OBD lamp/transmission check/malfunction lamp'? How is an engine check lamp different from an OBD lamp? |
Originally Posted by tsk1979
(Post 2461859)
If something is really wrong, ECU will put engine in limp home mode. So you will not be able to cross 1200rpm. If your vehicle is functioning normally, you can keep driving till you get help. Sometimes bad fuel can get you this "non limp home mode" check engine light. Different manufaturers implement error codes in different ways. Some error codes are "error" situations. For example engine temperature sensor saying that coolant temp is high. It will put your engine in limp home mode. Other error codes, for example in the safari "Rail pressure sensor error" just flag the check engine light, without any performance change. that said, high altitude learning is always silent in the safari. Maybe scorpio is different. It all varies from mfr to mfr. Without knowing the error code (scanning the engine), there is no way of knowing error code. |
(Post 2462008)
Ok, this is good information. And did you come to know about this from the owner manual? My point is, if the owner manual does not mention this, how would the owner/driver know of this (i.e. when to respect the check engine light and pull over and when to ignore it and drive on?). |
(Post 2463048)
Yup, it is from the owner's manual (mine!). It is presented as a "note" and not under the "warning" or "caution" heading. To reproduce exact words: "Engine performance (rev limit) restricted above ~16000 ft altitude due to design intended protection. This would be indicated with engine light ON in the instrument cluster and should be restored to normal operations, once vehicle is operated below 16000 feet. No Special service is recommended in such circumstances." |
(Post 2463048)
Also, if I hadn't read this before and the engine light glows, I would have pulled over to the side too. |
(Post 2463048)
(Post 2463322)
Awesome. Good Ford :). Thank you. Absolutely. That's the point. So if I understand correctly, "check engine" light would mean limp mode above 16000 ft. Below that altitude, it will mean what it's name says - "check engine" (serious trouble). Am I correct? Does Endeavour come with on-board altimeter so that the driver can interprete the "check engine" lamp in the right context and take appropriate action? Cheers! |
(Post 2463322)
(Post 2463048)
(Post 2463737)
The vehicle doesn't have an altimeter. What I can think of is to get to know the altitude of the hills I'm visiting and "ignore, but observe caution" when the warning light comes on while I'm there. But this wouldn't be a very comfortable feeling as I can never get to know if something else has wrong. |
(Post 2461827)
... What happens when an OBD-II scan shows P1000 as the error code? ... |
(Post 2461827)
... What happens when the engine is running rich due to low oxygen availability? ... |
(Post 2461827)
... How is an engine check lamp different from an OBD lamp? ... |
(Post 2461827)
Why does the Scorpio come with two 'check engine' lights - one called the 'engine check/malfunction lamp' (#16) and the other called 'OBD lamp/transmission check/malfunction lamp'? How is an engine check lamp different from an OBD lamp? Attachment 590852 |
(Post 2466872)
Engine lamp shows operation related errors inferred by ECU. OBD lamp (most likely, not sure) shows OBD communication related errors. Who knows, perhaps the MM guys might have faced too many bothersome unexplained intermittent problems on their test bench, and thought best to provide a separate lamp for OBD problems. :p |
