Old 15th April 2012, 19:05   #1
Thanked: 1,557 Times
Why do Rolls Royces "lean back"?
I cannot tell if it is the design at the coach line.
The ride height definitely seems to be lower at the back. And I have seen Phantoms in motion so it's not just the picture effect or the angle of the camera .
I'm guessing the rear suspension must be very soft for comfort(obviously), therefore, perhaps when it's loaded the rear drops a bit?
Or is it a Rolls Royce thing that is part of their design philosophy? Or could it just be an illusion?
D33-PAC is offline   (2) Thanks
Old 15th April 2012, 19:13   #2
Catalyst_delhi's Avatar
Thanked: 174 Times
Re: Why do Rolls Royces "lean back"?
I think it has an air suspension or at least magnetic, which maintains ride height no matter the load. Further more it is chauffeur driven (mostly) so hardly matters if the back droops. I may be wrong but i have noticed this bit too.
Catalyst_delhi is offline
Old 15th April 2012, 19:37   #3
DevilsCry's Avatar
Thanked: 507 Times
I'm not claiming that I know the reason but here's my assumption- it's to liberate more window area while still retaining aerodynamics. Take Swift for example-
1. Suzuki Swift
2. Roof slants towards rear to help in aerodynamics
3. Door also slants upwards leading to poor window area resulting in claustrophobic feel in rear seats
4. Rolls Royce Phantom has both roof and doors slanting to rear to help in aerodynamics and still avoid small windows
5. It indeed does look like that Rolls Royces have lower ground clearance at rear whenever I see one on roads. Not sure if it's true or not.
DevilsCry is offline   (1) Thanks
Old 15th April 2012, 20:36   #4
Thanked: 1,723 Times
Rolls Royce cars do not lean towards the back. This is because all Rolls Royce cars have self-levelling rear suspension systems. This means that regardless of the load, the same level would be maintained.
They originally had self levelling at the front too, but that was discontinued.
The picture only appears to show that it is slanting towards the rear, but in actual fact it is level to the ground.
VeyronSuperSprt is offline
Old 15th April 2012, 22:55   #5
v12
v12's Avatar
Thanked: 7,569 Times
I guess its more to do with the design rather than the technical aspect. The roofline and the boot slope downwards and hence the lean back impression. If you compare the new Rollers to the older models - the design is similar to the Rolls Royce Silver Cloud.
v12 is offline   (1) Thanks
