Old 20th June 2012, 10:20   #1
Thanked: 51 Times
Honda Civic burning smell problem
I own a Civic V AT since May 2008. Right from the first service till the last time my car visited the service center over the last 4 years, I have been complaining about one problem persistently. If the engine speed crosses 3500 rpm, a burning smell creeps into the cabin and stays for around 5 to 15 minutes. Last year at one instance, I got so fed up with this problem that I refused to take delivery of the car without this problem being rectified. After 20 days of diagnosis (yes, twenty whole days) and going back and forth, they said it was a cooling coil problem. I said I will not pay for it as I have been complaining from the time the car is new. They said they will get approval and change it under good will warranty but God only knows if they actually did change it.
For a few days it was fine. But again started to appear. A friend said it smells like the clutch is burning. I've given up on the service center guys to fix this problem. In the last 4 years if they couldn't fix the problem, I'm sure they can't fix it forever. In a Civic AT it is very difficult to overtake without the car touching at least 4k rpm. The car is in Chennai and the service center is Sundaram Honda. Experts here can you guess what the source of this problem could be?
deepakchan is offline
Old 20th June 2012, 10:39   #2
Thanked: 126 Times
Re: Honda Civic burning smell problem
Is the car dragging in anyways? Is there a engine responsive till atleast 3500rpm?
If the car is dragging get it checked thoroughly, it could be the clutch settings are off & are chewing off more than required, similarly with the disc brakes, The adjustment error can be so minute that you wouldn't hear a screeching noise neither any dragging, but the disc brakes will be working overtime.
It could also be the wiring in the dashboard, I've had this issue in my previous car, & then suddenly one day I noticed smoke coming out of the dash. It was a short!
I recommend you get the car thoroughly checked by a competent mechanic, not at Honda A/S/S though.
The existing issue will just snowball into other bigger issues. Overall it is a potential hazard driving around with a burning smell. Take care. Let us know what it was after you've gotten it checked.
mb_jg is offline   (2) Thanks
Old 20th June 2012, 10:47   #3
Thanked: 51 Times
If the car never crosses 3500rpm ever nobody would ever notice there is anything wrong with the car. The disc brakes have worn out recently but after a healthy 48k kms. They didn't have discs in stock during the last service. It should be with them in a week and I will be getting them changed. And the car doesn't lag in anyway. I'm quite a quick driver in the city and without pushing the car beyond 2.5k rpm I get to 70 quite easily. So I do not suspect the brakes at all. Clutch it could be. But who would be competent enough to diagnose an AT clutch. Anyone from Chennai could help in this regard please?
Old 20th June 2012, 14:54   #4
Thanked: 321,786 Times
Can you describe the burning smell? For example, electrical burn? Exhaust Leak?
Since you mention this is only happening above 3.5k rpms, I'm wondering if there is a belt that's slipping at higher rpms.
Your Honda dealer appears incompetent. Best you look for an expert independent garage (my recommendation)
GTO is offline
Old 20th June 2012, 15:13   #5
Thanked: 126 Times
Big possibility that the belt's slipping. Also check for any minor oil leaks under the hood. Do a thorough check in board daylight.
Also, please try & isolate the type of burning smell, e.g. the clutch burning smells very metallic, whereas a wire overheating & burning slowly will smell of a bit of rubber, oil leaks burning on hot areas will smell a bit smoky.
mb_jg is offline   (1) Thanks
Old 21st June 2012, 10:44   #6
Thanked: 51 Times
Thanks GTO. The burning smell is like a metal burning smell only. Not like an electrical burning smell. I shall try this person in Wallace Garden.
There are no leaks as the car is parked inside the house only and there are absolutely no stains on the floor. Yes as quoted above, the smell is metallic only. No rubber or electric burn smell.
Old 21st June 2012, 11:09   #7
comfortablynumb's Avatar
Thanked: 3,626 Times
This place in the forum directory has also got quite a few positive reviews: http://www.team-bhp.com/forum/chenna...e-chennai.html
Cheers,
Vikram
comfortablynumb is online now   (1) Thanks
Old 29th June 2012, 07:07   #8
Thanked: 76 Times
My car (2010 V A/T which has run 46200 Km) also has started giving out a burning smell under the hood after 45K service.The smell does not creep into the cabin, emanates out of the driver side from under the bonnet (even after a sedate run of 5-10 Kms).Whitefield Honda said it might be due to some oil which was used for cleaning and polishing (which I did n't believe) and washed off the residues, but the smell still persists.I could not hear any abnormal rubbing noise during running either. Nor could I spot any smoke under the bonnet.So am unsure what the cause could be.
There was no eveidence of any leakages as well and oil ,coolant levels are all OK.There was no warning sign in the Dash as of now.
I did check the most probable place whether the tyre is rubbing somewhere.But that seems to be OK.What could be the issue here? Could it be timing belt rubbing somewhere or something else?
Thanks.
ramanak is offline
Old 29th June 2012, 08:41   #9
1self's Avatar
Thanked: 334 Times
I think you rae having an oil leak somewhere above the exhaust manifold & that is falling on the manifold causing the smell. Kindly get this checked. It could be the tappet cover. Also since your car is A/T, no clutch issues to take care of, so that can be ruled out.
1self is offline
Old 2nd July 2012, 09:10   #10
Thanked: 76 Times
Thanks 1self.No.There is not a single drop of leaking fluid anywhere on the floor where the vehicle is parked.Whitefield Honda said this could be due to polishing oils used under the bonnet (Frankly, I did not believe this) and they washed under the bonnet with Soap solution saying that the smell should go away. But even now the smell persists.After running a few Kilometers, I checked in Basement parking (so that there is no wind draft) whether there was any smoke below the bonnet.But I could not spot any. As of now am clueless what could be the issue.The smell comes with/without AC.Other than the smell, Car runs very smoothly, Acceleration is normal and I dont notice any kind of rubbing noise.
ramanak is offline
Old 2nd July 2012, 18:55   #11
R2D2's Avatar
Thanked: 5,852 Times
ramanak, since you say this has started after the 45K service..please check your service invoice for all the services and replacements performed.
If some parts have been adjusted or replaced, those are prime suspects as technicians are known to slip up on proper fitting and adjustments. Check ALL moving parts for proper functioning and if they are touching or rubbing against any other part of the engine.
Since yours is an AT I'd rule out a clutch related problem but 2 things definitely do jump out at me - the one of the brakes is sticking ever so slightly OR something under the hood, for e.g. the alternator/AC belts need to be adjusted again.
Your best bet is to examine each part that was touched during the service. Take the help of a knowledgeable friend or another technician to carry out this inspection.
R2D2 is offline   (1) Thanks
Old 2nd July 2012, 22:12   #12
Thanked: 76 Times
I also feel Alternator could be a suspect since the smell comes from around that area.Brakes were touched during service as well.Thanks for the pointers.
ramanak is offline
Old 3rd July 2012, 13:56   #13
R2D2's Avatar
You are welcome. Assuming you are comfortable and know your way around your car in detail, inspect the car after every major service, focus on the areas that have received a replacement part or an adjustment.
I do that everytime I get my car back. And before I drive back home a small test drive also helps me spot any anomalies.
I am curious to know what the reason for the smell is. So if you do manage to trace it please do post on TBHP. It will help other TBHPians.
Cheers!
R2D2 is offline
Old 3rd July 2012, 16:29   #14
the.city's Avatar
Thanked: 229 Times
I had a similar burning smell when I was driving up the steep Nandi Hills roads on my City AT with four passengers in car. For my case it was obvious that the transmission was heating up because of slope. (No issues elsewhere)
I'm wondering if your friend is right and the issue is genuinely at the transmission.
the.city is offline
Old 4th July 2012, 08:40   #15
Thanked: 76 Times
In my case, Smell comes even after a few kilometers of sedate driving on flat roads.I am heading to service center shortly.Will post if the issue is
fixed.
AT oil change is due in 60 K service which is still 14 K km away.Engine oil change was done at 40 K service just before my long trip.My Nov 2010 car has seen really tough driving conditions during my recent trip to Gujarat-Rajasthan -Shirdi and back to Bangalore like several hours (22-23 hours) of continuous driving at 100 plus speeds most of the time thrice during the trip in extremely hot weather with A/C in full blast all the time (thanks to sun film rule). Car has also done Bangalore-Chattisgarh-MP trip, trips all over Kerala,Tamil Nadu. Nothing has been changed except for Engine mount under warranty. Stock Bridgestone tyres are also nearing the end of their life.So reason of smell could be anything.
Cheers.
ramanak is offline
