Old 10th February 2020, 13:40   #31
saket77's Avatar
Thanked: 14,781 Times
Re: Sound when the clutch pedal is pressed?
Originally Posted by balenoed_ View Post
As per initial talk with ASS, they say it could be cylinder and charges would be around ~4K for replacement as it is counted as wear and tear and does not come under warranty. This is as what is told to him, but now I also have a feeling that it should be covered under warranty whatever the issue is.
Okay, release bearing could be another suspect too.
As per my experience, I don't think a bad cylinder (master/slave) will make noise even if faulty. And clutch plate, I understand that they may not cover under warranty, but cylinder? If faulty, it should be replaced under warranty.
Saket
saket77 is offline   (1) Thanks
Old 16th December 2020, 17:49   #32
saisree's Avatar
Thanked: 2,529 Times
My 66K run Jazz started squeaking when I depress the clutch pedal. The sound was so irritating, that I couldn't manage it for a couple of days. Took it to my FNG. A dash of WD-40 and some lubrication to the clutch spring in the inner side and into the cable at the engine bay solved the squeaking. Hope it stays there and the squeaking sound doesn't comeback. Meanwhile my mechanic had a test drive and confirmed no issues with the clutch plate and the assembly.
This is how it sounded from the engine bay.
saisree is offline   (1) Thanks
