This is regarding my Xylo E4 2009 model. This car belonged to my dad and was passed on to me to take care of in Jan 2016. At the time the car was mostly only used for road trips and had done roughly 55K Kms.
I got the car and thought i would naturally fix a lot of things to make it road trip worthy again. At the time i didn't realize the car had any electrical issues at all.
I upgraded the head lamps to 90 W bulbs, checked fluids , changed wipers, and also changed a (rear) cigarette lighter port we used to power a Tropicool portable car fridge. At the time i didn't think much of it and got a good quality replacement.
We later set off to Rann Utsav in Gujarat from Gurgaon. On the way around 300 km in i noticed some thing peculiar.
Symptoms
- My instrument cluster would freeze and the check engine like would turn on.
- Along with it the power would spike up, the AC blower would run at a higher speed and the lights would glow brighter.
- But, the car would run smoothly without stalling.
Reference Video (i made recently)
I was recording this while i was driving on a empty road, wanted to show how my instrument cluster would freeze.
At first it felt as if my engine would cease. But because of the normal behavior of the engine and fluids levels okay and engine temperature under control.I natural suspected the electronic system. Possibly the ECU giving some issues, short battery or alternator.
The only issue was this was not a problem i could recreate it would happen for about 1 - 2 minutes and then everything would run smoothly. So, i did what any red blooded Indian would do. I said "gaadi garam ho gayi hai, lets halt for chai or lunch". Like expected, it worked the vehicle wouldn't give me any issues till the next few hundred kilometers.
I showed it to local mechanics, driver uncles who had Mahindra for years. The short but simple solution to it was just ignore it, Mahindra vehicles wont give you any issues, the instrument cluster is just window dressing.
I was not convinced with that and showed it to the Mahindra authorized service at Gurgaon after a 20K bill and about a day + in the workshop. They couldn't find a problem either and said alternator is fine, battery is fine. Nothing more to see or do.
Having the manufacturer give me a green light i just ignored it and felt stupid for spending 20K.
All this while, i also checked on forums for a solution but didn't find the symptoms i was facing.
About a year later, when i moved to Bangalore, the issue aggravated a bit more. My bulbs used to burn out within 5 minutes of starting out. Suddenly the spike would happen and bulb would go off. I got into a fix while driving back from Coorg at 4 am with no headlights.
Then i stumbled across this mechanic who replaced my bulbs. He mentioned its an alternator issue and he could service it for 2.5 - 3 K.
Photo (FIVE STAR BATTERY WORKS, Bellahalli, Bengaluru, Karnataka 560064)
Call it blind faith or a desperate attempt at getting this issue fixed. I took about 4 months to convince my self to give it to him for repair. Not knowing if he would worsen the issue or rectify it.
I sat with him and saw the alternator coil had burnt out
Pictures (here)
He claimed to replace all the parts and charged me 4K. I only paid him 3.6K thinking how i was scammed because i didn't know the local language. However, the bulb burning out issue had gone. But a dim battery light remained. Which i ignored as advised in the past.
After 2 months the issue popped up again, just the spike in power and no bulb burning out. Also, the battery was damp (liquid was overflowing) - again a sign of overcharging. This time i was wise enough to make a video and i also got a voltmeter to be sure what the issue was (because the mechanic has a feeling that i didn't know what i was talking about and he regularly expressed the same).
All i need to do is turn on the car and lightly accelerate for about a minute and the voltage would touch 16 - 17 V.
Video (Here)
I swiftly called the guy and he gave me a ear full on how he went though a big loss and he changed everything and i didn't pay him etc etc. None the less he said get the car he will check it out. He said a cutout would need to be replaced and he might have one lying around.
I went to him he replaced the cutout (TVS Lucas Alternator Regulator (cutout)) with an old one but the issue remained. I had a feeling in my gut that the issue indeed was that very component because the one he replaced with was a old one which didnt seem to have any branding on it. I told him i want to replace it with a new one. He directed my to a near by shop which dealt in auto parts.
Esteem Auto Spares - #482/1, 1St Floor, Kogilu Road, Maruthinagar, above ICICI ATM, Bengaluru, Karnataka 560064
The component cost 650 bucks and took about 5 - 10 minutes to install.
Since, then i have been trouble free. Only issue that remains battery light dim glow remains. Now, given the car is over a decade old that i some thing i can just learn to ignore
