Originally Posted by kunalsingh Hi OSH, that owner might very well have been me |
Hi, all I remember is that it was a white City which was painted and serviced. Tried finding that thread but couldn't locate it in the ownership reviews section. If it was yours, has it been moved elsewhere ?
These are the official grade of oils recommend by Honda for my particular car
I have a 3rd gen City facelift myself and am aware of this chart however one point of consideration has to be that our cars are international models and hence different regions(countries) may be getting different grades of oil filled from the factory depending on their driving conditions and climate temperatures.
If you read my post again; I have not mentioned that this is a wrong grade of oil for our engine. I have just mentioned that is a thicker grade than what Honda has used for our cars.
I have a few reservations on the below quoted points keeping in mind what I was told by a very old/senior engine rebuild specialist of my ASC few years back. This talk was when Honda was moving on from 5w30 to 0w20.
5W-30 will be able to flow better when the temperature is low. So at a lower temperature, it will be the best oil to protect the engine. This is for engines running in cold places which see longer winter seasons.
While you are right about the ambient temperatures, another important aspect which has been missed out is how easily the oil has to get pumped throughout the engine when you cold start (first start of the day). As you must be aware, a lot of wear and tear occurs during startup because the oil over-night settles down in the sump and very little oil remains elsewhere. When you crank the engine in this condition, it is very important that the oil reaches all the places very easily and quickly. I am told, an oil with a lower viscosity will be better in this regard.
10W-40 will be able to hold onto the engine parts better than the 5W-30 at higher temperatures as it becomes thicker when the engine is running during hot weather conditions.
I just hope that the source of this information is trustworthy because using lower viscosity oils has become a trend across manufacturers round the world and while one reason is FE, the other is how engines are built today. Tight tolerances on the inside will demand for thinner oils so I am not sure if changing to a thicker grade is the best thing to do. Just considering the ambient temperatures may not be the best way to choose a grade of oil.
Many mechanics who are experienced will recommend you to shift to a velocity which is higher when it comes to motor oil as the engine becomes older in order to compensate for these imperfections.
I have personally never read/heard of this nor has anyone told me this till date. I have a '07 City with over 115k kms on the clock and face no such problems after sticking to the same grade of oil. If this was true, wouldn't the manufacturers be the first ones to mention this in the manual ?
Gone are the days when engines were built that way. Modern engines have such tight tolerances that nowadays so many manufacturers don't even care about running-in a new engine. Not to mention today's engines go strong for lakhs and lakhs of kms without needing a rebuild if taken care of.
going for a 10W-40 engine oil was an informed decision on my part
I happened to mention this so that someone reading that post should not assume that 10w40 is the oil grade that Honda is using in the City. Hope you have not taken it in the wrong sense. As a fellow City owner, I loved how you have given your car a new lease of life. Really liked it.
Originally Posted by TheGearBox I don't think the clutch is worn out as it hasn't become hard and has plenty of bite. |
If you are on a steep incline and change gears, do you feel a heavy jolt ?
Should I even bother asking what this means ?
Strut RR both sides- 1200
Balance rod bush RR- 400
The strut is a suspension component which can be found inside the coil spring. This is what gives you the dampening effect. You will be able to see them even without removing the tyres. By 'RR' he means rear according to me. So in short he is telling you that both the rear struts have to be replaced.
The balance rod, I think is the street name for the stabilizer bar or anti-roll bar which is again a part of the suspension. The 'RR' again most probably means rear. If at all you go ahead with this repair, do it from a very reputed place as it is not a easy job. You can very much land yourself in an accident if this component is not repaired/replaced correctly following the correct procedure. This bush he is talking about will be part of some 'kit', if its not Honda genuine stay away.
Because I am no longer keen on giving my car to them.
Take the car to the ASC for service and get the works estimate first. It is FOC with regular servicing AFAIK.
Only one thing I did not understand is, if your FNG found the problem components to be at the rear, why are you getting noises while turning the steering wheel.
