Old 16th August 2022, 10:38   #1
Thanked: 12 Times
How to carry a backup car key when travelling
I was a duster owner(for 9years) and always carried my backup key inside the car, the reason being in case my main key doesnt work for any reasons like getting wet etc., wanted to be ready with my backup key whichever part of the country I am.
I upgrade to compass a week back and it has a keyless entry which makes me wonder how to do the same? If I carry my backup key in the car, its not gonna lock or unlock as the same is in the proximity.
Any ways to avoid the same happening ?
sudheendrasp is offline   (11) Thanks
Old 16th August 2022, 16:38   #2
AdityaDeane's Avatar
Thanked: 4,099 Times
Re: How to carry a backup car key when travelling
What will be the use of the spare key fob inside the car? It should be on your person, to be taken out when the main key fob battery is dying or the key is lost!
On the other hand, I had the same issue with the spare key card of my Triber RXZ! I had to take the battery out and stick it on with a paper tape, and we used to keep it in my wife's purse for emergency need. Helped with the car locking when I walked away, and as the battery was out of the card, it lasted longer compared to having it installed and emitting constant signals.
Hope it helps!
AdityaDeane is offline   (10) Thanks
Old 16th August 2022, 17:12   #3
condor's Avatar
Thanked: 16,901 Times
While I am still on the older type of keys (not keyless entry), Aditya's post gives an idea - a key fob without the battery in it ? Will this work ?
condor is offline   (5) Thanks
Old 16th August 2022, 17:21   #4
haisaikat's Avatar
Thanked: 5,495 Times
A faraday pouch should be used to store a keyfob and block all its signal beacons when the accidental use or misuse is to be prevented. But the best place to store is on person as bags etc can still be left or forgotten inside, imagine if someday they become small like a ring or watch or a pendant.
haisaikat is offline   (4) Thanks
Old 16th August 2022, 19:07   #5
Dr.AD's Avatar
Thanked: 22,778 Times
Well, carrying the spare key inside the car, when the car is locked is pointless. The spare key has no value unless you take it out with you every single time you lock the car and step out of the car. And that is often not practical anyways.
Coming to your specific question, I do not think it is a problem to keep your spare key inside the locked car. I have tried that experiment and the car gets locked properly (if you use the lock button on the other key that you take out with you) with the spare key still inside. However, apart from academic experiment, I find no value in this since the spare key locked in the car has no utility to me. So why carry the spare key?
If you are worried about the main key not working due to battery or any other issues, remember that it has a mechanical key included that you can use to open the car in the emergencies. I find that as a good enough "Plan B", and I carry only one key with me in all my travels. I keep the spare key safely at home.
I do not know specifically about Jeep Compass, but most keyless key fobs have a small mechanical key blade that you can pull out of the key fob and use as a manual door opening key in emergencies. That is what I am talking about as a safe Plan B without carrying a spare key.
Dr.AD is offline   (11) Thanks
Old 16th August 2022, 19:21   #6
Thanked: 328 Times
Wife has the spare key in her handbag. Out city trips are almost always with family and she never leave her purse in the car.
attinder is offline   (15) Thanks
Old 16th August 2022, 19:23   #7
Thanked: 12 Times
Because of engine immobilizer, there is a chance that key can be used to open the car but engine won't start. So, in those cases carrying backup key in the car will make sense.
Coming to compass, it does have a mechanical key but will end up with the same problem if chip in the key is damaged.
Old 16th August 2022, 19:27   #8
itwasntme's Avatar
Thanked: 14,277 Times
Same with us. She always has the handbag/clutch with her at all times. Never faced any interference on our Cruze, Creta, Polo, Octavia or 330i.
itwasntme is offline   (6) Thanks
Old 16th August 2022, 19:41   #9
Aiel's Avatar
Thanked: 599 Times
When travelling, the car's spare keyfob is always in my wife's handbag, which she always carries with her.
Aiel is offline   (2) Thanks
Old 16th August 2022, 20:32   #10
Hope it helps!
This is how it was in my Triber, I am sure all these high end cars with true keyless entry will have such a touch point inside the cabin where the card needs to be kept and then the car can be started even with the battery out of the key fob.
And yes, the Triber also had a physical metal key inside the card to unlock manually!
AdityaDeane is offline   (3) Thanks
Old 17th August 2022, 11:04   #11
Thanked: 322,575 Times
The better half's handbag is the best option .
If there are 2 (or more) cars travelling, you can keep the duplicate in each other's car.
GTO is offline   (22) Thanks
Old 17th August 2022, 12:00   #12
KrisTvpm's Avatar
Thanked: 716 Times
Like most pointed out, while on long-distance travel I have one key on my person + other is with the missus - in something she calls "clutch bag" (pretty un-intuitive for me! why would a clutch need a bag, it's supposed to be stepped upon!) which she always carries around in her hand!
Both key-fobs being keyless entry type for my Ecosport, what I do is - I also keep one physical key (pried open the fob & extracted out of it) within my wallet. So just in case battery dies out, I can open the car and still start it even with a dead key-fob as described neatly here (Ford EcoSport DIY: Replacing the Smartkey's Battery).
KrisTvpm is offline   (2) Thanks
Old 17th August 2022, 14:37   #13
chinkara's Avatar
Thanked: 778 Times
Same with us. One with me, one with wife. Pocket, handbag, whatever.
chinkara is offline
Old 17th August 2022, 16:02   #14
Thanked: 320 Times
As I understand from your question, you want to carry the spare key inside the car while travelling. The only problem with that is that if you lose your key, then the spare key is useless. So the best option is to have your co-driver carry it. If you don’t have one and have to keep the key inside, what i do is to keep the battery out of the keyfob and keep it in my luggage. I got this idea as i found that the car will not lock let you lock it if the spare key is inside the car. And as i do long distance tripping from my home town to workplace and the car stays there for long, i have to get the spare key too.
robby0707 is offline
Old 17th August 2022, 16:46   #15
BoneCollector's Avatar
Thanked: 11,380 Times
If I'm traveling out station, I carry both the key fobs with me (for keyless entry). If I'm alone, both key fobs are with me on person, and if wife is traveling along with me, the 2nd key fob is always in her handbag.
Carrying both the key fobs on person is not actually difficult if you're not using bulky key rings.
BoneCollector is offline   (3) Thanks
