Originally Posted by SolidusSnake I have a month old Virtus Topline AT. The car was amazing to drive during first 1200 kms. But then it suddenly developed a left pull and to keep the car straight, i had to pull steering to the right, the whole driving pleasure was gone. I took the car to service center, they checked the air pressure, it was correct. They took a road test and acknowledged the issue. They raised the car and there was no damage whatsoever. Then they did alignment, but the issue persisted when they again took the road test, so alignment was done again and again for 4 times, but issue persisted. I asked for the reason behind the issue and they admitted that they have no clue. Then they raised the car on lift and performed subframe shift. After that issue again persisted, then they again performed subframe shift and told me that issue is resolved. However when I drove the car, the issue is lessened but not gone completely and moreover the entire steering feel is gone, the steering feels heavy when turning left and light when turning right. However after spending 4-5 hours, they said no sir, steering is like this only, but I am sure this has to do with subframe shift they have done. I have no clue what to do now. The whole new car experience has turned into a horror story. @GTO and mods, if you can make it a new thread, kindly do it. Also @GTO, mods or any member can share contact details of senior VW people, kindly share, as I think only VW technicians may be able to identify and correct the issue, as asc people are clueless |
I can completely empathise with your situation. I know how frustrating this can be on a brand new car.
Few pointers if they may help you in any way :
1)Firstly, the Subframe has to be put back to its original factory fitted position. The Subframe correction does not apply to this situation where a Wheel Alignment (WA) was messed up most probably because, the " WA Specified Ranges" for VW Taigun & VW Virtus haven't been updated with many dealerships yet.
Most of them still use the values of VW Vento/Polo to perform the WA which is absolutely incorrect given the completely different Platforms of Vento/Polo vs Taigun/Virtus. For some reason, dealerships are still very careless about Wheel Alignments/Balancing which plays the most important role in ride and handling of the vehicle. The technicians aren't bothered about sitting in the vehicle, locking the Steering Wheel (SW) at the right position before making the toe adjustments nor bother to look if correct values required for Wheel Alignment for that particular vehicle are used for alignment. Most of them are absolutely careless and over confident.
2)Secondly, Do not allow the dealership to touch your steering wheel, i.e; removing the SW and allowing them to adjust the position of SW on the splined shaft of the Steering Column. This is the easiest way chosen by the inexperienced, lethargic, inefficient technicians at the dealerships. As long as the SW turns equal number of turns on both sides from center, your SW is absolutely fine and do not encourage anybody to touch the SW .
3)Finally, please go to a good Wheel Alignment shop and make sure they have values of VW Virtus and not that of VW Vento. For Example, Wheel Alignment on a Hunter equipment along with Hunter Road Force Wheel Balancing is the first step in solving your issue.
And the most important next step is getting your 'Steering Angle Sensor" calibrated after a WA at a VW dealership which is absolutely necessary on cars equipped with ESC (Electronic Stability Control). This is to match the steering angle to the vehicle's new thrust line. Unfortunately VW dealerships in India do not have enough knowledge about this and they don't consider this to be a necessity. Be adamant and get this crucial step done. It's done with a VCDS. Otherwise, your Steering Wheel will never give the intended feel and feedback with respect to the tyres. All the above steps will hopefully help in reducing the pull to a great extent on your vehicle. Check this link if it could be of any help.
https://www.hunter.com/media-center/...-sensor-reset/
Unfortunately, The Vehicles coming out of VW Factory, Pune are missing out on attention to detail and precision off-late. This shows the lacklustre side of the technicians and management in the factory. 7 out of 10 cars coming out of this factory have seen increase in issues related to Wheel Alignment, Balancing, Calibration and other serious quality issues on the vehicles. Most of the Vehicles are not Aligned properly and Steering Wheels not calibrated before being rolled out of factory. Gone are the days that you don't bother about Wheel Alignment on your brand new car that has just rolled out of factory.
Hope something helps out for you ! Good Luck
