Old 31st March 2023, 14:58   #1
Thanked: 496 Times
Kad-kad-kad noise from the rear wheel
My 10k run Polo (MPI Comfortline) has suddenly started making kad-kad-kad noise from rear right wheel. It is noticeable when stereo is off. It sounds like something is stuck in the wheel. The noise gets louder as speed increases, not very loud but you can notice it if stereo is off. I did not go through any major potholes, only regular ones. The noise comes from rear on driver's side.
I am thinking of getting it checked out at VW Gurgaon workshop. But wanted to get expert opinion here first about what could be the issue.
cryptarchy is offline
Old 31st March 2023, 15:12   #2
Rajeev1's Avatar
Thanked: 464 Times
re: Kad-kad-kad noise from the rear wheel
Originally Posted by cryptarchy View Post
My 10k run Polo (MPI Comfortline) has suddenly started making kad-kad-kad noise from rear right wheel. The noise comes from rear on driver's side.
Possibly the brake pad is misaligned or some foreign matter has entered the brake drum. I dont think for a low run car like yours there should be a bearing issue.
Rajeev1 is offline   (1) Thanks
Old 31st March 2023, 15:28   #3
scorpian's Avatar
Thanked: 1,321 Times
My 10k run Polo (MPI Comfortline) has suddenly started making kad-kad-kad noise from rear right wheel. But wanted to get expert opinion here first about what could be the issue.
There is a stone stuck in your tyre thread which is making the noise as the speed increased the wheel rotation becomes faster making the noise appear more quicker.
Check the tyre once.
scorpian is online now   (1) Thanks
Old 1st April 2023, 13:12   #4
Thanked: 496 Times
Re: Kad-kad-kad noise from the rear wheel
Checked both tyre treads for stone. I did not find anything just the usual very small stones. Today I was listening to the sound more carefully while driving and it sounded metallic.
Old 2nd April 2023, 08:30   #5
Thanked: 3,257 Times
Some times small pebble may get between the tyre and brakes. Please get your car to a tyre shop to remove and inspect.
thanixravindran is offline   (1) Thanks
Old 2nd April 2023, 08:57   #6
Thanked: 3,584 Times
There could be loose silencer assembly; stones lodged in tyres on the run may be hitting the wheel arc, this happens on newly laid roads a lot.
The mud flap may be hitting the tyre randomly.
MT_Hyderabad is offline   (1) Thanks
Old 2nd April 2023, 19:56   #7
Check for any tyre budge. I had similar issue with my ameo. Another chance is wheel bearing or suspension issue
arunchandran is offline   (1) Thanks
Old 2nd April 2023, 21:22   #8
Thanked: 12 Times
Perhaps try checking to see if there's an issue with the brake disks or caliper pins
R34ul is offline   (1) Thanks
Old 14th April 2023, 16:24   #9
Thanked: 496 Times
Suddenly the sound has stopped. I don’t know how, I had scheduled a workshop visit but cancelled it because sound is not coming now.
Old 30th April 2023, 10:13   #10
Thanked: 496 Times
Noise reappeared or I just got used to the noise and stopped noticing. I got it checked at vw workshop and they said it is a wheel bearing issue.
Old 30th April 2023, 11:35   #11
Thanked: 62,038 Times
When a bearings starts to me noticeable noises it is high time to change them out asap.
Jeroen
Jeroen is offline   (1) Thanks
Old 30th April 2023, 15:19   #12
Thanked: 496 Times
Got the bearing replaced. I don’t hear the sound anymore, fingers crossed!
