Old 16th August 2007, 10:59   #1
vidvai
Posts: n/a
The Newbie Thread: Things you were scared to ask
Hey,
Well, I have recently realised that my knowledge(if you can call it that) is even less than negligible and most of the things that i dont know/understand are things which i assume would be laughed at or would be too obvious to ask.
Hence, this thread.
I would like this thread to be used by everyone who always wanted to ask something but didn't because they were too ashamed to ask.
My list:
1. How is the ICE connected to the battery? Does one directly just join the wires to it? Is there some connector? How?
2. How does one connect something which can work from the cig lighter, directly to the battery? For eg, I have a pair of black neons in my car, they each had a cig lighter connector, but the installer connected them directly to the car with an anupam switch in between. How is this done?
3. How does one remove the carpet for all the wires etc?
4. Is it possible to remove the seat covers, wash them in a washing machine, get them ironed and them put them back on yourself?
5. What does it take for a tyre to burst?
The list is never ending and i will keep posting.
I just hope that this thread would help people like me do some DIYing and save some money in the process.
Mods, please move this to the appropriate forum if this is not fine. Thanks.
V
Old 16th August 2007, 11:17   #2
Vid6639's Avatar
Thanked: 43,486 Times
It's not connected directly to the battery but there is one set of wires which comes from the battery and is routed all around the car. This bunch is an indirect connection to the battery with relays and switches. This comes out near the dashboard and is called the wiring harness. That's why the system turns on only when you turn the key.
The cig lighter is just a 12V supply. If you tap the wire by making a cut to it and connect the wire you can operate them with a switch. I don't think this is advised as it is better not to do any cutting of the original wiring in the car.
Carpet is just fixed to the body with button clips. Just unbutton all the clips and you can see the naked body underneath where all the wires are routed.
No the original seat covers are stitched on so really cannot be removed unless you plan to replace them permanently.
There are many factors for this. From tyre wear, to overinflation, to puncture. You can search around in the tyre section.
Hey Vidvai, Actually there's nothing to be ashamed in asking. Even if you ask in the relevant section you will get a response. Remember almost all of us started off as newbies who din't know much. Also, more often than not your questions may have been answered to in another thread.
ps: your answers in bold.
Vid6639 is offline
Old 16th August 2007, 11:24   #3
vidvai
Posts: n/a
Thanks alot vid6639!
"4. Is it possible to remove the seat covers, wash them in a washing machine, get them ironed and them put them back on yourself?
No the original seat covers are stitched on so really cannot be removed unless you plan to replace them permanently."
Not the factory fitted ones, the aftermarket ones. The only thing i want to know is whether it would be simple enought to fit them back on.
"1. How is the ICE connected to the battery? Does one directly just join the wires to it? Is there some connector? How?
It's not connected directly to the battery but there is one set of wires which comes from the battery and is routed all around the car. This bunch is an indirect connection to the battery with relays and switches. This comes out near the dashboard and is called the wiring harness. That's why the system turns on only when you turn the key."
So all the wires form the ICE (HU, Amp) go to the wiring harness?
Old 16th August 2007, 11:25   #4
vidvai
Posts: n/a
Another question:
What controls the battery charging? As in, how does the battery start charging on its own once the car starts? Is there some sort of "tripping" that happens? Something like a UPS?
Old 16th August 2007, 11:57   #5
Vid6639's Avatar
Yup most of the cloth seat covers can be dry cleaned.
Nope only to the HU. the Amp is connected direct with a fuse in between.
The engine charges the battery via the alternator. The alternator converts mechanical energy from the engine into electrical energy. this is the basic principle.
Vid6639 is offline
Old 16th August 2007, 14:28   #6
CrAzY dRiVeR's Avatar
Thanked: 73,540 Times
Should be simple enough if you know what you are doing.
However, its better to use the vaccum cleaner for fabric seats, or cleaning foam for leather seats. For more info, see this thread
http://www.team-bhp.com/forum/owning...esthetics.html
CrAzY dRiVeR is offline
Old 16th August 2007, 15:33   #7
kaushik_s's Avatar
Thanked: 164 Times
Hey, my music system(blaupunkt) can be turned on and off without the key also by pressing the Blue Dot (of course it works normally with switching on and off with the Key) Does that mean it's not connected in the normal way ?I hope there is nothing wrong with it.
Kaushik
kaushik_s is offline
Old 16th August 2007, 19:17   #8
vidvai
Posts: n/a
A similar thing happens with my kenwood system, but only the cd eject function works.
Old 16th August 2007, 20:05   #9
Sam Kapasi's Avatar
Thanked: 2,378 Times
Kaushik
What is there to be scared to ask such things?
Let me explain to you Kaushik.
Every HU has 2 power connections.
  1. Yellow - Always on
  2. Red - on when the key is on
Now actually the HU runs from the yellow wire. But the red wire is used to trigger it on or off.
This is all fine, but in older european cars, there was no accessory position on the key. Take the Fiat (built like a tank) Uno for example. The key was either off - or in ready-to-fire ignition mode, with the ignition coil/heater etc. on.
When the car has an accessory position, you can switch the HU and the Cig Lighter etc. on without actually switching anything else on. This is useful in case you want to sit by the sea and make out with a special lady, while you listen to music.
But if the car has no accessory position, then in trying to keep the HU on, you run the ignition coil, heater etc. throughout the make-out session. This is not good for the car and for the battery.
To overcome this possible situation, the Germans at blaupunkt came up with a design that allowed you to switch the HU on without the key. Even though the HU has switched off (Because you've turned off the key) by pressing the blau punkt (the blue dot/point) you can switch the HU on for the make-out session.
But again (german engineering at it's peak) with the key missing in the car. the HU will turn itself off again in a hour, to prevent the battery from running down. So restrict your making out to 60 minutes. OK? OK!
Sam Kapasi is offline
Old 16th August 2007, 20:06   #10
Sam Kapasi's Avatar
Yes. This too is designed this way. So you can ejaculate the CD without fumbling for the key.
Old 16th August 2007, 20:11   #11
Sam Kapasi's Avatar
Yes, everything except the amplifier. Because the amp needs extra juice, with no restrictions in between, it is routed straight to the battery.
Old 16th August 2007, 21:24   #12
vidvai
Posts: n/a
So basically, its just connected to the battery? Thats it? Would that not mean that the amp is always on? As in, i think the battery would be an independent source of energy right? So, since the wiring harness et al dont come in between, the amp would be supplied with electricity all the time, or does the HU actually control the "switch on" and "switch off" of the amp?
Old 16th August 2007, 22:23   #13
bullboy's Avatar
Thanked: 92 Times
what is the red triangular button seen on the facia of some modern cars?
bullboy is offline
Old 16th August 2007, 22:25   #14
Thanked: 320 Times
Sam sir what is this "ejaculate" or you mean to say ejact.
Ajaybiz is offline
Old 16th August 2007, 22:29   #15
esteem_lover's Avatar
Thanked: 502 Times
correct yourself, it is eject, not ejact ....LOL
Obviously Sam Kapasi did not mean that, if he did there would have been a smiley right next to that. Why would you want to talk about something that has not been said ?
esteem_lover is offline
