Closed Thread
Old 24th September 2007, 17:27   #31
Thanked: 268 Times
Originally Posted by sumitkalindi View Post
Though they need techies to be tampered with, disconnecting them is a simple DIY job. They usually take electrical pickup. So you just need to fing the right socket and disconnect it when needed. I had to resort to this method when i was stuck with a job that needed lot of travelling while my bike, PULSAR DIGITAL SPEEDO, was due to be serviced, I had just 20/25 kms left in the odo before it had to be serviced, and my expected running before I could even think of servicing the bike was around 190 KM.
Would be kind enough to explain more ?
mithun is offline
Old 24th September 2007, 22:03   #32
narayan's Avatar
Thanked: 2,488 Times
Originally Posted by sushrutha View Post
I don't agree on this . I have seen many vehicles where the speedo meter needle shakes even though they haven't tampered the odo.
This happens coz of the cable being short or something else to with the cable.
Heck when i changed my pulsar's speedo cable , now my speedo meter needle shakes ( I haven't tempered my odo)
true - in my car, speedo needle shakes at low speeds and then firms up as speed builds up
narayan is offline
Old 24th September 2007, 22:16   #33
Jaggu's Avatar
Thanked: 17,299 Times
speedo can shale cos of worn out cables as well as pinions.
Jaggu is offline
Old 30th December 2009, 15:07   #34
Thanked: 94 Times
Clocking back the mileage
I was in India in October/November and had use of a Sumo Grande. I knew the car had been used for taxi type service but it only had 30,000KM on the clock. The driver told me that there was a place in a local city where they went to get the mileage clocked back every now and then. His reason for doing this was to keep the vehicle within the limits for the Tata warranty. He told me the car had actually done close to 150,000KM in just over a year.
He said he kept a note of the actual mileage and got the oil services done accordingly and also full dealer services in accordance with his dodgy mileage. I was surprised that evidence of this high mileage was not very visible, the car was clean inside and out and no evident wear on things like the steering wheel. Ride was ok and no broken interior which you would expect from a vehicle plying its trade in rural India.
So if buying a used vehicle then dont fall for the usual "mileage is correct...digital computer recorder ..." blurb the seller will give you. Looks like there are plenty of techs who have the equipment and who will clock back these lcd type speedos in India.
Mods - feel free to move as I was unsure where to post this.
bigman is offline
Old 30th December 2009, 15:20   #35
beejay's Avatar
Thanked: 219 Times
There is a guy in Coimbatore who is a specialist in this line. He usually rotates for Volvos owned by tour operators. He says he can just about rotate any car.
Had heard stuff that the old analogue meters can be turned using a magnet. Any truth in this?
By the way, I think the service guys can make out if a meter has been tampered with. At least the tyres will be a sure tell tale and other things.
beejay is offline
Old 30th December 2009, 16:54   #36
phamilyman's Avatar
Thanked: 4,673 Times
I've seen old analog meters in bikes being turnable by hand. Don't see why the same for cars would be any different.
And no tell tale signs IMO!
phamilyman is offline
Old 30th December 2009, 18:04   #37
basilmabraham's Avatar
Thanked: 76 Times
How can the service guy see that the meter has been tampered with? As long as the mileage it shows now is more than that it had for the last service, I dont think delaer can find anything. Ofcourse, over worn tyres, worn out clutch and brake pedals, gear lever etc, may give away the actual usage of a car.
However, I dont think there is any way that you can acutally find out if the odo has been tampered with or not.
basilmabraham is offline
Old 30th December 2009, 18:44   #38
Thanked: 268 Times
Some threads of interest :
http://www.team-bhp.com/forum/techni...-tampered.html
http://www.team-bhp.com/forum/techni...-odometer.html
mithun is offline
Old 30th December 2009, 20:01   #39
NetfreakBombay's Avatar
Thanked: 1,130 Times
From one of the posts :
Yes its a very simple procedure done bu guys who repair meters. Have seen it being done in my presence and no one can make out unless and until the pcb is opened. The difference will be there in the soldering.
What they do is replace the chip that stores the odo reading by another one with the reading desired. This is done by writing a blank chip hooked up to a chip burner and a laptop. They charge about 1500 in Mumbai and takes approx 25-30 mins.
http://www.team-bhp.com/forum/techni...tml#post946122
NetfreakBombay is online now
Old 30th December 2009, 21:40   #40
MileCruncher's Avatar
Thanked: 1,345 Times
If this is the present state of affairs, then all I can say that I guess nothing is as it seems (including humans)
MileCruncher is online now
Old 2nd January 2010, 00:32   #41
GSMINC's Avatar
Thanked: 198 Times
An old friend of my mine from my rallying days runs a meter repair shop who claims that it's very easy to re-set electronic meters than the old analogue meters, he charges Rs.500-600 for every reset (he re-sets, but you can have any reading you want, it is a less than 5 minute job, ofcourse getting a parking place in russell market in less than 15minutes is anybody's guess), he is doing very well & operates from a shop near Russel market, Shivajinagar, Bangalore.
BUT, more than reducing your speedometer reading, he can fit a device in your vehicle which increases the reading & the fun is you can change it as and when you please, that is he fits a sensor & gives you a remote control(sort of remote which you get for your car ICE) & whenever you press it your readings increase.
this setup really helps tour/taxi operators to jack up their meter readings.
God knows where this world is going land up
GSMINC is offline
Old 23rd March 2010, 21:29   #42
Thanked: 89 Times
Originally Posted by anupmathur View Post
Consider buying a 'Tru-value' from Maruti, if you are looking at Maruti vehicles. At least they come with a warranty.
True Value don't bother to verify the milege themselves when buying. Why will they be bothered what they sell you.
It's not by hand. You have to remove the blades of a table fan and connect the cable to it.
@#1#
Live To Jive is offline
Old 24th March 2010, 12:33   #43
gpa
gpa's Avatar
Thanked: 362 Times
Originally Posted by GSMINC View Post
An old friend of my mine from my rallying days runs a meter repair shop who claims that it's very easy to re-set electronic meters than the old analogue meters, the fun is you can change it as and when you please, that is he fits a sensor & gives you a remote control(sort of remote which you get for your car ICE) & whenever you press it your readings increase
Shouldn't this friend of yours be hauled up by the cops?
gpa is offline
Old 24th March 2010, 13:28   #44
Thanked: 311 Times
Why?!! He pays them weekly!
That is how it is everywhere for all illegal activities!
Cops are a party to them ALL!
anupmathur is offline
Old 24th March 2010, 13:33   #45
gpa
gpa's Avatar
Thanked: 362 Times
Then perhaps the Lokayukta is the only way forward
gpa is offline
Closed Thread
