Old 12th April 2011, 10:47   #3211
tsk1979's Avatar
Thanked: 23,494 Times
re: The Tata Safari 2.2L Technical / Problems Thread
But why do you want to go for a suspension overhaul? Are the shockers leaking? OR some other major issues?
tsk1979 is offline
Old 12th April 2011, 11:32   #3212
jkdas's Avatar
Thanked: 1,497 Times
@Sumit, clutch is normally not covered under warranty. Even if there is a problem with the reverse gear, the A.S.S would cover that problem, but not the clutch itself.
If you are under 25k on odo, I guess you can get it changed for free (info I read here )
Originally Posted by v&v View Post
It depends. it can range from 10k to 14k. Clutch disk around 4k.
14k? I dont think if costed me that much!
jkdas is offline
Old 12th April 2011, 11:39   #3213
rrsteer's Avatar
Thanked: 3,505 Times
No nothing of that sort. Preventive maintenance actually. Do you not recommend doing that?
rrsteer is offline
Old 12th April 2011, 11:40   #3214
Thanked: 716 Times
Just my 2 cents if you are getting a paid job done never use word overhaul.
In my experience ( at Maruti *** not at TASS) if you tell them a specific job like bush replacement the labor will be reasonable but if you ask for overhaul then labor will be bomb for same bush replacement even if there is no other job to be done.
So better to let them come back and tell if it needs overhaul.
amitk26 is offline
Old 12th April 2011, 11:47   #3215
Thanked: 265 Times
Thank you Jyoti but can anyone else please confirm this? I really don't want to spend any money if I don't have to and yes, the reverse gear problem is getting worse with a severe stench coming on every time I reverse the vehicle on a slight incline which was definitely not there before the TASC was sitting with the vehicle for 3 months. My vehicle has done only 3685 kms. till date!
SumitB is offline
Old 12th April 2011, 12:50   #3216
bantejas's Avatar
Thanked: 30 Times
I can second that. It is actually 30k. I got to know from the TASS yesterday only.
Tejas
bantejas is offline
Old 12th April 2011, 12:52   #3217
LionX's Avatar
Thanked: 1,210 Times
@Sumit, Yes you can get it changed FOC if its a manufacturing defect. I have got mine changed even at 15K kms.
LionX is offline
Old 12th April 2011, 16:23   #3218
Thanked: 265 Times
Tejas
Thank you. This information will come in handy at the TASC!
My TASC has a habit of charging for everything. Even things which are clearly mentioned in the User's Manual as free are charged (eg. I am charged for Top Ups of fluids in the first service!). I don't think that they will consider this a manufacturing defect!
SumitB is offline
Old 12th April 2011, 17:58   #3219
condor's Avatar
Thanked: 16,902 Times
@Sumit, fluids are consumables. Will normally be charged, unless T.A.S.S does a good-will top-up.
Can you check & share the part in the users manual where it says it is free ?
condor is offline
Old 12th April 2011, 18:35   #3220
Thanked: 265 Times
I don't have the manual handy but I will definitely post it once I have confirmed. I am talking about coolant top ups which are to be done in case of leaking coolant reservoir, etc. I read somewhere on the forums that these are to be done for free since these are an outcome of shoddy Tata QC and faulty component which is not due to fault of the customer. Similarly, my TASC charged me for the faulty power window which was due to stiff rubber beading. Every other owner who had this problem fixed did not pay a penny whereas my TASC made me pay 310/- for the lubricant.
SumitB is offline
Old 12th April 2011, 18:51   #3221
simply_sunny001's Avatar
Thanked: 19 Times
The case of coolant leaking due to Faulty Radiator Cap was of Tanvir's and its totally fair as well.
How can TATA charge the customer for the coolant lost due to a faulty part.
simply_sunny001 is offline
Old 12th April 2011, 18:53   #3222
Lukeskywalker's Avatar
Thanked: 1,244 Times
Oils, grease, lubricants, emery paper, coolants etc. are chargeable as consumables, I doubt if the manual says otherwise. Leakages could be a manufacturing defect, so they will repair the cause of leakage but you will be charged for the replacement of leaked fluid nevertheless.
Lukeskywalker is offline
Old 12th April 2011, 18:59   #3223
Thanked: 265 Times
I was charged in both the 2 services for coolant top-ups which was due to a leaky reservoir and pipe. The TASC knew that it was the case but they were not able to determine the source of the leak until the 2nd service. This was the case in both my Safaris.
Tanveer is of a different opinion. He has always maintained that top-ups due to a faulty component should not be charged. His TASC also concurs and does not charge for such top-ups.
SumitB is offline
Old 13th April 2011, 09:05   #3224
anujmishra's Avatar
Thanked: 529 Times
I had same issue in my Safari and they replaced the cap of radiator and top up leaked coolant. They did not charge me anything. It was goodwill top-up of upto 1 litre of coolant.
anujmishra is offline
Old 13th April 2011, 10:36   #3225
Thanked: 463 Times
Except for routine service wherein you have to pay for any change of oil, filter etc. I have never been asked to pay for any topups.
dadu is offline
