Old 18th September 2008, 13:10   #1
viper_711's Avatar
Thanked: 93 Times
Power steering oil leaked - is it safe to drive to workshop?
Hi BHPians - need some advice on the issue detailed below:
My Indica TDI has had a major power steering leakage while parked overnight in the basement. The oil has collected in a puddle on the floor.
I called the Concorde helpline and they sent a mechanic to check the issue. He couldn't figure out where the leakage has occurred and says that the car needs to be driven to the workshop.
The distance from my place is almost 14 kms. Is it safe to drive it this distance without any oil in the hydraulic system? What would be the best way to solve this?
viper_711 is offline
Old 18th September 2008, 13:17   #2
Thanked: 462 Times
Its not safe to drive like this, best option is to tow, next best option is to fill the oil again and drive, hopefully its a leak and not an immediate drain and you will reach the SS. And to keep checking after every 3-4 kms.
If it drains out immediately chances are steering will become hard and pump will dry out which might cause damage to the PS components.
dadu is offline
Old 18th September 2008, 13:24   #3
Thanked: 300,856 Times
Not safe at all, you could ruin your power steering system. Have it towed to the workshop.
GTO is offline
Old 18th September 2008, 13:29   #4
ramie2400's Avatar
Thanked: 66 Times
Towing the car to the service station will be much much cheaper than damaging the power steering unit driving without the oil,please dont risk it driving the car.
ramie2400 is offline
Old 18th September 2008, 13:38   #5
suman's Avatar
Thanked: 279 Times
I second Dadu's suggestion of filling & driving - also, maybe just the pipe from the fluid container has come off, has he checked that?
In a worse case scenario, I don't see any damage if you drive it carefully to the service center - just don't take any sharp or sudden turns, avoid potholes & you'll be OK. Its only 14 kms.
suman is offline
Old 18th September 2008, 14:01   #6
white_vdi's Avatar
Thanked: 38 Times
my indigo had the same problem...infact happened thrice in 8days before i sold her..
dont even think of driving her without the oil..i was told that the power steering pump would get damaged if driven like that and it costs more than 10k..
white_vdi is offline
Old 18th September 2008, 14:13   #7
Shashank.A's Avatar
I don't know if it will work in your case or not.
But In esteem power steering can be disabled by removing a belt. Its connected to the Compressor bearing of the car, so if you remove the belt the power steering and air conditioning would stop working in the car, and the car would like driving the normal steering. So I guess in that case no damage would be done.
But again you must check it is possible to do in Indica.
Shashank.A is offline
Old 18th September 2008, 14:38   #8
Pardon me if Im wrong but doesnt the esteem have an EPS? (electronic power steering)?
Gregory is offline
Old 18th September 2008, 14:41   #9
There are rubber or plastic seals that give way, which causes oil to leak. In some cars seals can be replaced, but in others, whole steering unit has to be replaced.
Towing is best, but I had power steering oil leaking problem in my Ikon & I continued to drive for 3-400km, nothing got damaged.
bhp1 is offline
Old 18th September 2008, 14:42   #10
Shashank.A's Avatar
I am not sure about the new ones, but my 97 model has a HPS.
Old 18th September 2008, 14:53   #11
tsk1979's Avatar
Thanked: 22,826 Times
Fill up oil and then drive to workshop, it won't fully leak within half an hour, unless you have hose crack leading to pressure loss and instant leakage.
If that is the case, even if you start the car, the power steering pump will work since the belt is common.
So best option, take off the alternator belt and drive to workshop.
Oil or no oil it won't matter as you will have manual steering with power steering pump off
tsk1979 is offline
Old 18th September 2008, 15:13   #12
viper_711's Avatar
Thanked: 93 Times
Thanks Tanveer - can you also guide me how to do this? is it possible as a DIY or do I need professional help? Where is this belt located?
I am stuck in Noida till Saturday and will have to take this up as soon as I'm back in B'lore.
Old 18th September 2008, 15:25   #13
tsk1979's Avatar
DIY is possible if you are mechanically inclined. Its very easy
1. Loosen the belt,
2. Take it off
But better will be to find any roadside mechanic and pay him 30-40rs.
Or you can ask the concorde guy to do the same if they are willing to come again.
But remember without the belt on alternator will also be off, so your battery won't be charging at all only discharging, so keep stereo etc.,
Such sudden leaks usually happen when you hit the underbody. In your case since the entire oil leaked I suspect something is busted.
I am wondering why could the Concorde guy detect the problem.
Fill 500ml oil and see if its leaking, start the car in a dry sport and observe. If its a big leak it will start leaking again.
If you don't see it leaking drive to the workshop.
Are you sure its power steering oil only. did the reservoir go empty?
tsk1979 is offline
Old 18th September 2008, 15:26   #14
Thanked: 462 Times
Which is good, you can meet tanveer in NOIDA and he can demonstrate you this in his ....safaaa...eer...indica
dadu is offline
Old 18th September 2008, 15:27   #15
white_vdi's Avatar
Thanked: 38 Times
it is hard to reach the alternator belt like that without professional help..i was asked not to drive the even for a km without the oil...
in my case the hose connecting the pump and reservoir was cut so the oil got drained in secs...
my advice would be tow her or get some help at your place...
