Old 6th December 2008, 14:32   #1
toiingg's Avatar
Thanked: 266 Times
OHC 1.5 Gear /Transmission Oil
Hi Guys,
Need help from fellow OHC 1.5 owners.
I don't have the user manual. Can someone please let me know the grade, and quantity of Gear oil recommended by the company.
Which one are you using ?
toiingg is offline
Old 6th December 2008, 16:59   #2
razor4077's Avatar
Thanked: 298 Times
Checked the Lancer logs - am using Castrol Protector Series Transmission and Gear oils. Had bought 1 litre dubbas of each. OHC should be similar I guess, but owners will have to confirm.
razor4077 is offline
Old 10th December 2008, 18:23   #3
toiingg's Avatar
Thanked: 266 Times
What? 4 days and not a single response from fellow OHCians ?
Come on, get off your lazy bums, open the manual and let me know. Please.
toiingg is offline
Old 10th December 2008, 19:06   #4
narayan's Avatar
Thanked: 2,372 Times
will tell you tomorow toiingg after seing the manual. but did u try calling up service center to know this ?
narayan is offline
Old 10th December 2008, 19:45   #5
toiingg's Avatar
Thanked: 266 Times
Thanks Narayan.
I don't take it to HASS, don't trust them. The local garage where i get it done, is guesstimating 2.5 L. Some other mechanic i asked, said 2L. That's where the confusion lies. Don't want to over or under fill.
Also i wanted to know what grade the company recommends, so i could take a look at different brands and choose accordingly.
toiingg is offline
Old 10th December 2008, 21:05   #6
johnda's Avatar
Thanked: 19 Times
Originally Posted by toiingg View Post
.. The local garage where i get it done, is guesstimating 2.5 L. Some other mechanic i asked, said 2L. That's where the confusion lies. Don't want to over or under fill.
hey Toiingg, I saw this thread only today, well i checked the manual and in the engine oil maintenance section, the only things mentioned are (typing as found in the manual)
*Always use a premium-grade detergent oil.
*select the proper SAE viscosity oil according to the chart (I can try to take a photo of the chart if you need it)
*always use a fuel-efficient oil that says "API Service SG, SH or SJ"
IN the change oil section I found this.
*Put a new washer on the drain bolt, then reinstall the drain bolt. Tighten it to: 44N.m(4.5kgf.m, 33 ibf.ft)
* refill the engine oil, engine oil capacity (including filter): 3.3 L (3.5 US qt, 2.9 lmp qt)
This is all I found, hope this was useful. Oh BTW I get my oil changed at the HONDA so i dont have a brand.
All the best.
johnda is offline
Old 10th December 2008, 21:08   #7
Tejas@perioimpl's Avatar
Thanked: 9,582 Times
Hey, i saw this thread today as well. I checked my car's manual and agree with johnda.
I use castrol for my car. I'll check on the label for the exact series and post later.
Tejas@perioimpl is offline
Old 10th December 2008, 21:13   #8
johnda's Avatar
Thanked: 19 Times
Tejas, please check on the Oil Container if there is anything pertaining to the 'SAE viscosity' based on the chart in the manual.
johnda is offline
Old 10th December 2008, 21:15   #9
toiingg's Avatar
Thanked: 266 Times
Thanks Johnda, engine oil i know is 3.5 L.
I need to know about the Gear Oil.
toiingg is offline
Old 10th December 2008, 21:27   #10
johnda's Avatar
Thanked: 19 Times
Oh you mean transmission Fluid! the manual does not mention the quantity of oil needed, Although for grade, the manual recommends {API Service SG, SH or SJ rated motor oil with a viscosity of SAE 10W-30 or 10W - 40 }
johnda is offline
Old 11th December 2008, 06:12   #11
Thanked: 973 Times
I think these specs are for engine oil.transmission oil will be GL rated ,something like API-GL4/SAE 75W-90.
rb2399 is offline
Old 11th December 2008, 10:36   #12
toiingg's Avatar
Thanked: 266 Times
That's what i was thinking. The oil i saw for transmission had a grade rating of 90 or something.
toiingg is offline
Old 12th December 2008, 09:24   #13
johnda's Avatar
Thanked: 19 Times
The specks i gave were from the manual, they don't give you a brand all they mention is to get Genuine Honda Manual Transmission Fluid.
Since this is been troubling us, Toiingg Please Update this thread with Brand and Grade after you get the Job done. Thanks.
johnda is offline
Old 13th December 2008, 15:07   #14
johnda's Avatar
Thanked: 19 Times
I know this might be too late, but for the forum -
here is the capacities for Type 11 OHC Gear oil. 1.8L for change and total of 1.9L for Automatic: its 2.4L for change and 5.4L total.
johnda is offline
Old 14th December 2008, 20:28   #15
toiingg's Avatar
Thanked: 266 Times
Thanks Johnda, thats just the information that I was looking for.
I found 2 brands of Gear Oil (both Grade 90) ... Shell costing 130/L and Castrol @ 198/L. I'll be taking 2L and would prolly go with castrol.
toiingg is offline
