Old 24th April 2009, 19:15   #1
alexnazim's Avatar
Jerks during acceleration in my carb esteem
I am facing issues while accleration in my carb 98VX esteem. What could be the reason?
Can you please suggest any repairs/mods for smooth acceleration?
I am quoting an example for you to better understand the problem :
In the first gear once your car is at the speed of about 15Kmph(with the clutch fully released). You press the gas pedal gently to increase speed but before it accelerates you get a couple of jerks and then the car picks up.
Thanks for your suggestions/reccomendations in advance.
alexnazim is offline
Old 24th April 2009, 21:06   #2
frankmehta's Avatar
Thanked: 3,668 Times
i had a similar problem. please have your high tension cables that run from the distributor to the engine. i just had them changed and the car is running like a dream.
a choked carburettor perhaps?
frankmehta is offline
Old 24th April 2009, 21:08   #3
alexnazim's Avatar
Thanks and how much did it cost you to get those replaced?
Old 24th April 2009, 21:48   #4
frankmehta's Avatar
about 1.5k for the cables with labour at the maruti A.S.S. i suggest you wait for any more opinions on this thread before taking the plunge. im not too well versed with carburetted automobiles.
but my suspicion seems quite correct. lets wait and see what the gurus have to say!
Old 24th April 2009, 23:27   #5
Abbas's Avatar
Thanked: 581 Times
i had an esteem too and faced similar issue. I would suggest you check your fuel pump and carburettor. Its not a big deal.
Abbas is offline
Old 24th April 2009, 23:43   #6
Thanked: 727 Times
Fisrt thing first! check fuel filter and air filter
If its fine check the following.
1. spark plugs and related parts including coil.
2. improper timing
3. carb servicing/cleaning required.
SirAlec is offline
Old 11th February 2010, 19:15   #7
monster2's Avatar
Thanked: 12 Times
HI alexazim...
Need help on the same did anything help as in did the problem solve because facing something similar.
monster2 is offline
Old 12th February 2010, 10:10   #8
Perakath's Avatar
Thanked: 31 Times
Similar thread here: http://www.team-bhp.com/forum/techni...blem-help.html
Perakath is offline
