Re: Automatics : P or N at signals / traffic lights? Gear shift lever position should be changed only when the car is not moving. For all shifts, we first depress brake paddle.
Even while shifting to P, depressing break paddle alone will be enough. Car won’t move. But after shifting to P, if we disengage the brake paddle without engaging parking brakes, the weight of the vehicle will be entirely on just a pin in the gear box, which can snap. That will be an expensive repair, even if it didn’t lead to any accident.
Engaging hand brake while the foot brake paddle is depressed, doesn’t make any difference; except that it helps to follow a safer routine / process during shifting the gear position to P. |
