Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 16,788 views |
19th October 2011, 10:15 | #16 | ||||||||
Senior - BHPian Join Date: Jul 2008 Location: Pune
Thanked: 453 Times
| Re: City Sleek or Civic Sense? A short comparison of the two Quote:
Well like i said, am hear now. Quote:
(1) Thanks |
The following BHPian Thanks mdsaab for this useful post: | RavenAvi |
19th October 2011, 11:42 | #17 | |
Senior - BHPian | Re: City Sleek or Civic Sense? A short comparison of the two Quote:
I have started to get easy on my Shark after alloy upgrade. Now a days, I redline her only when roads permit, othervise she is in fuel saving mode only. | |
(1) Thanks |
The following BHPian Thanks Ace F355 for this useful post: | mdsaab |
20th October 2011, 09:29 | #18 | |
Thanked: 453 Times
That's the perfect combo of indulgence and Civic Sense! LOL! --- One more point which i would like to share. The Civic displays the outside temperature which i feel is quite an important feature. In the City you are left clueless about the temperature outside. Forgot if i mentioned this or not. The Civic with 2 trip meters is also way more useful than the City's lone trip meter. | |
(1) Thanks |
20th October 2011, 12:40 | #19 |
Distinguished - BHPian | Re: City Sleek or Civic Sense? A short comparison of the two OK- am back as promised! When shopping around for a C/C+ segment last year, it occurred to me what a VFM offering the City is: quite the "practical" choice to someone who feels the Civic's 13+ price tag is a stretch. In fact I never seriously considered the Civic at all, despite the likes of GTO and dot urging me to look at good used options. This thread has covered the main points, just adding my two cents here:
(2) Thanks |
The following 2 BHPians Thank noopster for this useful post: | mdsaab, RavenAvi |
20th October 2011, 15:01 | #20 | |
Thanked: 453 Times
(1) Thanks |
20th October 2011, 16:04 | #21 |
BHPian Join Date: Jan 2009 Location: Bangalore
| Re: City Sleek or Civic Sense? A short comparison of the two How about GC? Which one is better? Have been tempted several times to go out and buy either a second hand civic or city, but terrible stories on GC, especially for those of us in Bangalore, have kept me away... |
() Thanks |
21st October 2011, 09:21 | #22 | |
Thanked: 453 Times
Let's gather some facts first. Civic GC ~ 170mm Wheelbase ~ 2700mm City GC ~ 160mm Wheelbase ~ 2550mm This is the way i look at it. It's not only the GC that makes a difference it's the wheelbase too. Here is where the Pre-facelift Civic suffered. Softer suspension, and a long wheelbase meant that while crossing certain high speedbreakers it would scrape the bottom. and believe me the crunching sound of the car bottoming out on the tarmac was heart crunching. It seems Honda fixed this problem in the facelifted Civic by stiffening the suspension and the facelifted civic no longer has this problem of bottoming out on high speedbreakers. The City thus far has not bottomed out on Pune roads in my experience. Though the one area where is it's weak point is the lower part of the suspension right under the boot. That is quite low and i have scrapped it once while exiting from a rather odd parking slot. Both these Honda's suffer when there is more load at the rear. So three passengers at the back and the boot filled with luggage you better watch out as there are high chances that it may scrape. ~~~ So how do we tackle this issues? One correct your driving technique over large speed breakers by transversing them diagonally. Though this is difficult to do in regular city conditions. Even a slight diagonal attacking angle while crossing a speed breaker makes a big difference. and ultimately is the deciding factor between bottoming out or not. Secondly. One could upgrade the coil springs which would help out quite lot. It's a small modification to be done which is totally reversible should you want to go back to the stock setup. You can read more about this on GTO's brilliant thread on the same. So if you plan to go in for a pre-owned Civic try and go in for a facelifted example. Drive Safe! Last edited by mdsaab : 21st October 2011 at 09:23. | |
(1) Thanks |
21st October 2011, 09:42 | #23 |
Senior - BHPian Join Date: Dec 2007 Location: Gurugram
Thanked: 4,790 Times
| Re: City Sleek or Civic Sense? A short comparison of the two Bottoming does not have all that much to do with the Ground Clearance. What is the GC figure - the height of the lowest point of the car above the road. Now in modern fwd cars this is invariably the bottom of the front suspension/steering mechanism. This will invariably ride over the bump with the wheel, so is irrelevant. What matters is some point (normally inside the wheelbase) or the exhaust which will bottom. Now this will depend on the wheelbase (Civics is long), springing (soft suspension will go down more), and the load. This is why GTO's solution of adding a rubber donut to the coil springs seems to work in most cases http://www.team-bhp.com/forum/techni...uspension.html |
(3) Thanks |
The following 3 BHPians Thank sgiitk for this useful post: | aaggoswami, mdsaab, RavenAvi |
21st October 2011, 11:23 | #24 |
Team-BHP Support Join Date: Jun 2009 Location: Mumbai
Thanked: 21,046 Times
| Re: City Sleek or Civic Sense? A short comparison of the two Excellent thread and particularly interesting for me to read since we currently own both vehicles - a 2009 Civic A/T (just before facelift) and a 2009 City A/T. These cars replaced a Swift and an i10 respectively. I drive both cars regularly as well as get chauffered in each car very regularly so I have some perspective on back seat comfort as well as driving pleasure. I remember reading ages ago in a City Civic compare on some thread that the City is 90% Civic at 75% price and therefore a good buy. I couldn't disagree more!! While the City may be an excellent purchase within its own segment, the Civic in comparison is streets ahead and at least for me the price differential is worth the money. Key areas where I find the Civic comfortably out-does the City IMO are as follows - Comfort (front and rear, particularly rear). Everyone in my family agrees that the Civic is much more comfortable to be driven around in. My mum has finally come around to admitting that the civic (my primary ride) is indeed actually more comfortable to drive as well than the City (which she initially preferred because of the lighter steering). - Overall refinement. The city is a really buzzy engine and feels strained whereas the Civic feels really creamy and smooth right through the rev range. - Power: no comparison here. Load up the cars and the Civic will feel much more comfortable accelerating than the City. Its more direct steering also adds to the pleasure associated with its power delivery. - Steering feedback and overall handling: Civic far superior. I hate lifeless steerings and the City steering (for me at least) takes away significantly from the driving pleasure, particularly since I'm constantly comparing it to the Civic. - Equipment levels: Again the Civic is much better and the underequipped status of City shows. Simple benefits like electronic folding mirrors are a huge USP to me since I like to use both mirrors almost always (therefore folding at button press in tight situations helps) - Build quality: The city is well built no doubt, but the Civic just feels a little more solidly put together. I'm not able to explain or elaborate on this but just how I feel in each of the cars. City pros: To me the limited pros the City offers is better FE, smaller dimension (useful sometimes); bottoms out less (City is bad but Civic is worse so...) and lastly and most importantly much bigger and more usable boot. The boot in particular is a total joy and those international airport trips necessarily mean that the City will be taken out. Please bear in mind that I own both cars so there's no personal ownership based bias. These are purely my personal views based on first hand experience - you may of course agree or disagree but like I said, I own both so there's no "my car is better" bias in my analysis. Left only to my personal consideration, when it comes to replacing one of these cars, I'd upgrade my cars by selling the City and retaining the Civic as opposed to vice versa - lower FE be damned. But that's a matter for another day !! Cheers all. |
(4) Thanks |
The following 4 BHPians Thank Axe77 for this useful post: | mdsaab, Memphis, RavenAvi, sgiitk |
22nd October 2011, 10:17 | #25 | ||
Thanked: 453 Times
(1) Thanks |
22nd October 2011, 11:34 | #26 |
Senior - BHPian Join Date: Sep 2010 Location: Kolkata
Thanked: 440 Times
| Re: City Sleek or Civic Sense? A short comparison of the two Thanks for the well written comparo, rated it 5 stars . More than a year back when i looking to upgrade my car and visited a Honda showroom , the sales guy had asked me to TD the Civic when I went to have a look at the City . I think the dilemna between a City and a Civic is faced by many - my vote goes for the Civic . The digital odo is one to die for apart from the other good things ! I agree with most of your observations though am still vexed by the GC comparo which does not support our observations regarding bottom scraping especially when both are from the same stable and the suspensions are expected to have similar setup ( softness ) Last edited by souravc : 22nd October 2011 at 11:51. |
() Thanks |
22nd October 2011, 11:45 | #27 |
Senior - BHPian | Re: City Sleek or Civic Sense? A short comparison of the two Nice thread mdsaab; was missing you and charthom for a while now. Civic is any day a better car than City in all aspects. It handles much better, looks much better and performs much better. When I was buying Honda City, I too gave Civic a thought but the difference of around 4-5 lacs put my mind off and I went straight away for City. Also the City is more compact and fuel efficient than Civic and power wise also it is quite near to it (118 PS and 132 PS). City is VFM car in comparison to Civic any day. But if one has bucks then Civic is the car to go for. |
() Thanks |
22nd October 2011, 19:43 | #28 |
Distinguished - BHPian | Re: City Sleek or Civic Sense? A short comparison of the two The one place where the Civic definitely blows the City clean out of the water IMO is the cockpit. Just sink into the driving seat of the Civic and have a look at the "Fighter Jet"-esque instrumentation in front of you, and feel your heart suddenly beating "THUMP! THUMP!" into your ears! |
() Thanks |
22nd October 2011, 19:49 | #29 | |
Senior - BHPian Join Date: Dec 2007 Location: Ban Chang
Thanked: 732 Times
For the folks, who are discussing the key, just wait till I post a pic of a Singapore based 8th gen 08 Civic's key (my Sis-in-law's). It has an remote trunk opener key. I wonder why they missed this very useful feature in India. | |
() Thanks |
22nd October 2011, 19:59 | #30 | |
Distinguished - BHPian | Re: City Sleek or Civic Sense? A short comparison of the two Quote:
I, for one, find that as a very useful feature for a car. Most if not all 8L+ cars should come with one by default, actually. | |
() Thanks |
