Old 3rd May 2023, 12:34   #1366
shandilyapiyush's Avatar
Thanked: 336 Times
Re: My first car: 2020 Maruti Suzuki XL6 Alpha MT Review
Originally Posted by saurabh041086 View Post
Is this pre facelift model which has recommended grade as 5W30?
My Ertiga is the 1st gen (2013) version with the K14 and 5w30 recommendation like you've said!
Currently service centres are pushing 0w16 for my Nov 2022 XL6, which i am somewhat uncomfortable with in scorching summers of Delhi.
Stick to the user manual recommendation, I'd say that should be alright considering MSIL would recommend a different grade if necessary for hotter regions. Is 0w16 the only grade given in your manual? If yes, just stick to it!
Cheers,
Piyush.
shandilyapiyush is offline
Old 3rd May 2023, 12:53   #1367
Thanked: 341 Times
Either 0w16 or 0w20.
saurabh041086 is offline
Old 3rd May 2023, 14:25   #1368
Thanked: 336 Times
Since your user manual has both grades listed, you could go for 0w20 if you feel 0w16 is too thin!
Old 6th May 2023, 13:21   #1369
Leoshashi's Avatar
Thanked: 43,503 Times
Since I have no particular issues with how the engine is running now, I'll probably just stick to w40 oil. Switching to a w30 oil and then if I do encounter what you've mentioned, it would probably only ruin my peace of mind knowing very well that the engine had no issues before switching back to 5w30.
My further queries and other discussions regarding the this topic was posted and continued on the thread you linked.
Thanks a lot for your replies Leoshashi!
Yes my intention was just to warn you about things which may go bad. In most cases, it won't cause anything negative, but one should know about both cases before taking an informed decision.
Is this pre facelift model which has recommended grade as 5W30? Currently service centres are pushing 0w16 for my Nov 2022 XL6, which i am somewhat uncomfortable with in scorching summers of Delhi.
If memory serves me right, manual says shift to 0W16 as soon as possible, 0W20 is just a stop gap measure in case 0W16 isn't available.
I agree the OE oil is crappy, and hence I've been sticking to 5K change intervals. There is another good option, Idemitsu 0W16 or Castrol Magnatec 0W16. I know someone who has used both, and they are way better than OE oils. If you can convince your MASS to source Castrol Or Idemitsu for you, nothing like it.
I am waiting for my warranty to expire, post which I'll shift to Castrol Magnatec 0W16. My MASS wasn't too enthusiastic about sourcing either.
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-screenshot-20230506-131935.jpg
Shashi
Leoshashi is offline   (1) Thanks
Old 6th May 2023, 13:40   #1370
Thanked: 341 Times
So xw30 is a strict no in your opinion? None of the service centres are willing to procure anything apart from Ecster.
I have an upcoming Spiti trip, so thinking that it will be extremely harsh for engine compared to my usual moderate traffic commute.
Old 6th May 2023, 14:44   #1371
Leoshashi's Avatar
No please don't. Stick to stock grade. You can always request the service centers to procure Shell/Idemitsu made 0W16 Ecstar. That is still better than Servo or Castrol 0W16.
Shashi
Old 7th May 2023, 11:26   #1372
Thanked: 341 Times
Shashi
Yes, they poured in Shell 0w16 Ecstar. Is it worth going to Castrol Magnetec 0w16 over this for harsh driving conditions?
Also, is the padding you applied inside boot under floor lids effective. Those lids make the irritating noise over every breaker and spoil the quietness in a nicely cocooned cabin?
Old 9th May 2023, 12:52   #1373
Leoshashi's Avatar
Yes, if your MASS agrees to source it for you.
Yes, they are effective, just make sure to put it in correct places such that the lid sits snug. Also if you have a 3D mat in place, the lid doesn't bounce around that much.
Shashi
Old 9th May 2023, 14:12   #1374
Thanked: 341 Times
Shashi
Thanks. MASS can't arrange anything at my place, will search and fill outside.
Interestingly, i have 3d mat over lid since day1. Now, you got thinking if this level of bounce is with mat, what would it be without one.
Old 29th May 2023, 12:31   #1375
Thanked: 990 Times
Hi Shashi,
Could you please help me with OEM reverse camera part number for 2023 XL6 Alpha + variant & if this can be fitted to Zeta variant.
Thanks for your valuable time & response.
.sushilkumar is offline
Old 1st June 2023, 20:56   #1376
nsbhagwat's Avatar
Thanked: 288 Times
Hi Shashi,
I just noticed tags of airbag stitched in seam on the driver and passenger seats on my 2023 ertiga zxi+.
Does it mean that this vehicle is equipped with 4 airbags?
Nikhil
nsbhagwat is offline
Old 1st June 2023, 22:31   #1377
BoneCollector's Avatar
Thanked: 11,377 Times
Originally Posted by nsbhagwat View Post
Hi Shashi,
Nikhil
Ertiga ZXi+ and XL6 Alpha+ have 4 airbags, front driver and passenger plus 2 side airbags. They don't have curtain airbags as of now.
BoneCollector is offline   (2) Thanks
Old 2nd June 2023, 10:58   #1378
Thanked: 990 Times
For XL6 , 4 Airbags are not limited to Alpha+ only but standard across the variants while Ertiga gets in ZXI+ only.
.sushilkumar is offline   (2) Thanks
Old 3rd June 2023, 22:56   #1379
Leoshashi's Avatar
Some updates:
-Updated the HU to MD-0922(Sept 22 version)
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-2.jpg
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-3.jpg
Did a deep cleaning and upkeep of the interior:
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-1.jpg
Odo is nearing 39k km
Shashi
Leoshashi is offline   (14) Thanks
Old 10th June 2023, 11:10   #1380
Thanked: 90 Times
Got the 3rd Free/10k service done on 2nd April. Booked home service via MS Rewards app and also requested Workshop GM of Hilltop Motors Ranchi, Mr. Rajiv Chakraborty to source 0W16 Shell oil for me. They usually stock Idemitsu, but he was kind enough to arrange that for me. I had also requested him to make sure they come with 16510M68K00 filter and not 16510M68K10 which is often used interchangeably by mechanics
Hello Leoshashi,
My 3rd free service is due next week. Since ODO reading is only 2750 kms, please advise if I should go with engine oil change this time (as due in 3rd service) or wait to reach 5-6k? If need to change, will definately ask to bring same MGO Shell 0W16 and filter you have mentioned.
Also suggest if I should get 4 tyres rotated or its not advisable with this ODO reading?
(planning to call them home as nothing major in this service)
India2022 is offline   (1) Thanks
