Originally Posted by Reinhard Wow! And I mean WOW! For your thread, let alone for your car. Rating it 5 stars for the lack of any more. Wishing you many happy, safe & fun filled miles with one of the most aspirational cars on our roads. Cheers. |
Hi Reinhard, Thanks very much! I am glad you liked the review.
Originally Posted by amol4184 Congratulations! After driving my V1 Thar, a friend said the AC output is so out of place in this car (considering how rudimentary everything else is) and defies all logic. |
Hi Amol, Yes, I went for another long drive last week and although it was very hot weather (38-degree-plus) for the most part, I never had to increase the A/C beyond the first setting. The blowers offer a very wide range of positions, both laterally and vertically and by adjusting them, I found a way to be comfortable in most conditions. For instance, during early mornings and evenings, point the blowers straight up towards the roof and you are saved from freezing cold draft. When it gets hot outside, point the right side blower at the face level and the left side one at the torso level. This seems to work well.
Originally Posted by PioneerNB Thank you thank you thank you... I was searching for such a review... but your review just helped bring my brain back from my heart |
Hi Pioneer, I am glad it helped, the Thar works equally on the brain and the heart! It is quite a capable and high-VFM car for single folks or small families who like the outdoors and also want to use it inside the city with the convenience of an auto transmission.
Originally Posted by ph03n!x CONGRATS ON THE MYSTIC BEAUTY, @84.monsoon! The car looks amazing, and your review is so very detailed.
The 1st speed of the wiper is actually a programmable intermittent setting. To use it... |
Hi Phoenix, this is very helpful thank you very much!
It defines logic a bit, why Mahindra would go for such a convoluted way to implement this, rather than use the rotary element in the wiper stalk as others do, however, I am glad there is a way to use it. Will try it out next time.
Originally Posted by diwakarmuthu Many congratulations on the new acquisition. The Mystic Copper looks dashing. For your road trips how many bags were you able to put in the boot? Can it hold 2 medium sized suitcases? |
Hi Diwakar, I did not load it to the max, as it was only me traveling this time. You can load a large suitcase and a duffel bag vertically along the side. Anything more is a problem. Alternatively, multiple soft duffel bags can be stacked on top of each other in two columns.
Originally Posted by Iyyer Congrats @84.monsoon! Wishing you happy and safe miles ahead!!...
1. @84.monsoon, you posted that "[u]Bumpy ride on anything but the smoothest of roads. So if I am to drive on state highways that are not so well maintained, would it be a problem?
2. While driving on the hills, did you engage the hill hold/descent control?
3. While driving on highway, did you'll feel more exhausted than driving any other category of vehicle due to the ride quality? |
Hi Iyyer, as long as the road is well paved it is not a problem. I drove on many two lane SHs recently, the roads were in good condition and I was doing 110 KPH very easily with no discomfort. However, if there are undulations on the road, like uneven surfacing, expansion joints, etc., these will start to transmit quite a bit of movement inside the cabin. Larger undulations such a potholes, rutted roads, broken tar exposing pebbles and stones gathered inside etc. it will cause the car to lurch quite a bit and is not comfortable at all. Medium to large bumps, taken at speed, will unsettle the ride and may cause the car to fly off and land with a shock. On one such incident, the car was being driven at close to 120 KPH by a friend on ECR, and crossed an unmarked speed-breaker (which was decent sized bump). Another friend sitting in the back seat hit his head on the roof (yes, this did happen although the roof is quite high, this is the level of bounciness this type of incident causes.
One does not need HDC or HHA unless going up a very steep hill, typically in off-road conditions. Normal motorable roads in hill stations, do not need anything more than 2H. While parked mid-way up a steep slope and starting the car from Park and moving to Drive, the HHA automatically holds the car in place for a second or so until you take your foot off the brake and press the accelerator to engage the engine fully to go up.
After an 8 hour drive in the Thar, I felt a little more tired than I would in my Sedan. It also took 25-30 minutes more for the journey than my sedan would. A funny thing I noticed after such a long drive is that for a few hours afterwards, you get a feeling of having a constant up-down movement of the body.
Originally Posted by navpreet318 How is the heat insulation from the Hard Top? Does the roof feel hot when you touch in while driving in the afternoon? Does the heat feel radiating down from the Hard Top?
The heat insulation is quite good in my view. I checked after driving in the Sun a few hours and yes, it did feel hot, but not so much hotter than other cars.
Originally Posted by Xaos636 Great review. I just read it in a flow and took quite a long time. Well written and explained in detail. You
I just noticed that the meter console does not look aligned to the outer cover. Doesn't look like photo angle too. |
Thanks Xaos - you are right, there is a slight mis-alignment in the meter console. I noticed this as well and will be pointing it out to the service folks. Not sure if it is worth correcting, I fear rattles may arise if they try to remove and re-assemble. Any opinions, anyone, if this is worth fixing?
Originally Posted by car_guy1998 Overall, a well written review from your side! And, BTW, is Thar suitable for ladies for doing daily commutes in the city traffic? |
Thanks car-guy. My wife found the Automatic car very easy to drive. The controls are very light and the visibility is great! The only aspect she had to get used to was the width of the car, which is quite a bot more than what she is used to.
