Old 5th September 2005, 17:46   #1
DRC
DRC's Avatar
Thanked: 67 Times
PCD :: Expert advise please..
I had the first flat tyre this sunday, and went to the tyre shop for a fix.
There, the tyre guy tried to sell me a set of alloy wheels..
I asked "My petra uses 14'' 98PCD wheels, do you have 98 PCD alloys?"
He told me "PCD is all non-sense, All wheels are same as long as lugs match"
He pulled out a wheel which had a print 100 and I assumed its 100 PCD, he fitted that on the hub with 4 bolts. The wheel had 8 holes on it,
Then he showed me that it also fits on a Ikon, which was there around with a flat tyre and wheel removed, which is supposed to be 100PCD.
Now I am looking like a fool
Any expert views on this...
DRC is offline
Old 5th September 2005, 18:16   #2
Rtech's Avatar
Thanked: 371 Times
You are right, the tyre guy is wrong.
Yes, the wheel may fit, but it's essential to have the correct PCD.
Rtech is offline
Old 5th September 2005, 18:21   #3
DRC
DRC's Avatar
Thanked: 67 Times
Rtech,,
Could you please elaborate for me....What would happen if I fit mismatching the PCD... what is gonna break.. whell or Car??
DRC is offline
Old 5th September 2005, 19:59   #4
Thanked: 32 Times
This might help
http://www.team-bhp.com/forum/showthread.php?t=6908
hrag is offline
Old 5th September 2005, 20:15   #5
viper's Avatar
Thanked: 20 Times
Hey Guys,
Both of you are right. As you mentioned the wheel had 8 holes which means they are dual pcd rims. They are made in such a manner that they can fit different cars with different types of PCD's.
If the holes match and the tyres rotate without a problem whilst driving you have no reason to worry.
Viper
viper is offline
Old 5th September 2005, 22:51   #6
S600BENZ's Avatar
Thanked: 12 Times
P.C.D stands for Pitch Circumference Diameter. That means if you draw an imaginary circle which passes through the centre of the 4 holes on your wheel then the diameter of that circle in mm is your P.C.D. This is unique to each wheel and hub. That means that you have to have the exact same P.C.D on the wheel and the hub to match. Dual P.C.D means that the same wheel with 8 holes will fit 2 diff hubs having different P.C.Ds thats why the wheel fit the Petra which has 98 and the Ikon which has 108 P.C.D. Now the question is why did the 100/108 dual P.C.D rim fit the 98 P.C.D Petra. Since there is a very minimal 2 mm diff in the 98 and 100 P.C.D the guy basically forced it on the Petra since the larger 100 P.C.D wheel will go on the 98 P.C.D Petra. Now this is highly not recommended as the wheel will not be an exact fit on the hub. Some tyre guys also do the vice versa i.e fit a 98 P.C.D rim on a 100 P.C.D hub by shaving the insides of the bolt holes on the wheel and forcing the rim on the hub. Thi is also a very stupid thing to do. All this happens in India only as the dealers are so happy that a customer has come to them or liked a design they will sell sell them anything as long as it fits.
In singapore where I usually buy Rims for Mercedes they are so particular that they will not sell you rims with the wrong offset. That is being really professional.
Cheers.
S600BENZ is offline
Old 6th September 2005, 11:27   #7
DRC
DRC's Avatar
Thanked: 67 Times
Now, That I am planning to go for the alloys, (thou not immediately) and doing my home work..
How can I source 98PCD wheels...
I visited aura website and find the 98PCD wheels, but the dealers say they never make them..I am not sure though, but all of whom I spoke to had the same say!!
DRC is offline
Old 6th September 2005, 12:00   #8
PJSPEED's Avatar
If you are intrested in BBS let me know..........
We have RW 7 X 15" with PCD 98 Center bore of 58.1
Recommended tyre size 195/50R 15,205/50R 15 or 215/50 R 15
PJ
PJSPEED is offline
Old 6th September 2005, 12:30   #9
PJSPEED's Avatar
Originally Posted by PJSPEED
PJ
The size above is for Palio Sorry about that......
PJSPEED is offline
Old 21st September 2005, 22:27   #10
Thanked: 175 Times
Help with my PCD!!!!
Well a friend of mine is coming down from the states and i've asked him to get me a set of spacers for my rear wheels as the track width is less than that of the front wheels.........
Now the question i have is the PCD of my cars wheels as measured by me is 120.00mm can anyone confirm this for me???
I didint wanna start a new thread for this question, So if anyone can confirm that for me it'll be great........
Edmund is offline
Old 21st September 2005, 23:45   #11
PJSPEED's Avatar
Can you let me know for which car????
120 PCD looks like BMW ....
PJSPEED is offline
Old 22nd September 2005, 02:12   #12
Thanked: 175 Times
I Wish!!!!
No,no ......... not a BMW, PJSPEED.......a 1985 Suzuki 800......
Edmund is offline
Old 22nd September 2005, 17:44   #13
Thanked: 175 Times
Somebody........help!!!!!
Edmund is offline
