Scoop! Hero Maestro Xoom technical details leaked
The Hero Maestro Xoom is likely to be offered in three variants: LX, VX and ZX.
Hero MotoCorp is gearing up to launch a new scooter called the Maestro Xoom. Here's more information on the upcoming model courtesy of an ICAT (International Centre for Automotive Technology) document.
According to the document, the Maestro Xoom is likely to be offered in three variants: LX, VX and ZX. The new model is slightly larger than the Maestro Edge. It measures 1,881 mm in overall length, 731 mm in width and 1,117 mm in height, and the wheelbase is 1,300 mm.
The Maestro Xoom has a front apron that houses a large LED headlamp and X-shaped LED daytime running lights. The tail lamp also has an X-shaped graphic. The scooter is expected to come with a digital instrument cluster.
The Maestro Xoom will be powered by a 110.9cc, single-cylinder engine that makes 8.04 BHP @ 7,250 rpm and 8.70 Nm @ 5,750 rpm. The engine will be paired with a continuously variable transmission (CVT).
The scooter will be equipped with a telescopic fork suspension at the front and a conventional shock absorber at the rear. Drum brakes will be offered as standard, except for the ZX variant, which is likely to get a disc brake at the front. All variants will be equipped with Combined Braking System.
Thanks to the Team-BHP fan (he prefers to remain anonymous) who sent these images in. Heartfelt gratitude for sharing them with other enthusiasts via this Team-BHP share page!
Redlining the Indian Scene
