Thread Tools
Old 4th June 2007, 12:52   #1 (permalink)
noidaboy's Avatar
Infractions: 0/2 (8)
Default does a reverse woofer install really help
checking out the various ice installs i have noticed people install reverse woofers...does is make a diffrence?? wats the funda behind it
__________________
"its not WHAT i drive... its the WAY i drive"
noidaboy is offline   Reply With Quote
Old 4th June 2007, 14:27   #2 (permalink)
Team-BHP Moderator
navin's Avatar
what do you mean by reverse woofers?
__________________
Scixelsyd Etinu
Old 4th June 2007, 14:38   #3 (permalink)
mclaren1885's Avatar
Meaning the subs mounted the other way. Like this
__________________
ICNSAFYNCILWU. WMUL. AWLUFAEAE.
Old 4th June 2007, 15:48   #4 (permalink)
noidaboy's Avatar
thanx 4 this picture buddy...
yeah this is what i want to knw... whats the point of such installs??
__________________
Old 4th June 2007, 17:58   #5 (permalink)
hydrashok's Avatar
Show, show & show! Most Audiobahn subs get mounted this way, to show off all that chrome on the frame and the magnet.
No difference in sound by mounting them this way.
This kind of install maybe necessary in some (rare) cases where the enclosure volume is lesser than the volume of the driver (the part that goes into the enclosure) or where the volume is so small that the driver cannot be installed in the normal way. The two Kicx subs in EVO's TT are a good example of this.
EDIT: I guess mounting them in reverse does keep them cooler (esp. vis-a-vis a sealed enclosure), but I don't think this really is a serious criteria.
__________________
Seven are my colours
Many are my lovers
What was three will soon be two
The music will again sound pure and
true
Old 4th June 2007, 18:24   #6 (permalink)
kpzen's Avatar
I think EVO6 has inverted subs in his Audi TT....Can find the pics now!!
How come?? All the parameters will change na....
Will it sound same as a sub in a ported box.....?
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
Old 4th June 2007, 18:55   #7 (permalink)
hydrashok's Avatar
Nope. Nothing changes. Except that, if the enclosure volume specified by the manufacturer includes the displacement of the magnet & frame and stuff, that displacement must be reduced from the final enclosure volume while mounting the subs in an inverted way.
Using an inverted sub with a ported enclosure is likely to be a beeeatch. Don't ask me why, I have no solid reason to give -- just a feeling. Too much math is going to be involved there (the enclosure will most likely be fiberglass and without a single measurable edge), and I wouldn't want to do any of that calculation if my life depended on it.
One problem that is likely to be there is that, if somebody is sitting close to the inverted sub, he is likely to hear a lot of slapping (?) type sound of the movement of the cone and spider and stuff. Again, this would depend on the build quality of the sub (there, I've said the 'B' word) and a really well put together sub may not make this mechanical noise.
All that inverting a sub involves is wiring the sub out of phase. If the amp has a reverse-phase switch that would also do, I think.
__________________
Many are my lovers
true
Old 4th June 2007, 19:09   #8 (permalink)
kpzen's Avatar
Anoop.!
Thanks for explaining !
Now for the calculation thing i'll catch LBM
Off topic: Have u used fibre wool inside your sub box? I heard using it gives more low bass from the Sub....Is it true?
Sorry for pestering u....Just clearing my doubts
__________________
Old 4th June 2007, 19:28   #9 (permalink)
hydrashok's Avatar
Nawww...
I have used a bit of polyfill in my box, though it is built to specs. It sounds good to me, so I haven't uh, argued the use.
Polyfill is used to make the sub driver think it is in a larger box than it is actually in. This does make the output sound a bit deeper. (But I personally don't understand why a box built to specs needs polyfill, as the driver gets exactly the enclosure volume it needs). I'm sure polyfill really helps when we are not able to build a box (due to space issues in the car) as large as a sub-driver needs. Then, we can build a slightly smaller box (as large as the space allows) and use polyfill to fool the driver into thinking it is in a bigger box (of about the specs it really needs). But this I guess, would need a lot of experimentation to get it right. And again there must be a limit to which polyfill can held compensate for box-size.
And as I understand (damn, all that I know is theoretical, 2nd hand knowledge) polyfill helps more in a ported box, than in a sealed box. Basically because the ported boxes (for the same driver) are bigger than a sealed box, and considering the usually tight available space in our cars, we need to really con the sub-driver into seeing a bigger box. And I've also heard that polyfill also helps reduce port-whistle (I guess, by damping/slowing down the air movement caused by the back-wave).
And yes, I guess l_b_m can do all that calculation-giri with one hand tied to his back
__________________
Many are my lovers
true
Old 4th June 2007, 22:32   #10 (permalink)
noidaboy's Avatar
but having woofers magnets facing each other..wud have some bad effect or something???
what kind of box's are prefferd for maximum bass??
__________________
Old 4th June 2007, 22:54   #11 (permalink)
Team-BHP Moderator
navin's Avatar
a) woofer magnets are too far apart and besides their magnetic field is concentrated towards the pole piece.
b) Box size and type depends on the T/S specs of the woofer.
__________________
Scixelsyd Etinu
Old 5th June 2007, 01:32   #12 (permalink)
I have installed reversed sub woofers in my innova right now. I tried both way but i do not feel the difference in sound.
May be it depends upon brand and show off.
Mugen_Power is offline   Reply With Quote
Old 5th June 2007, 13:00   #13 (permalink)
noidaboy's Avatar
dvc
i have 2 pioneer 306 dvc's currently installd.what kind of box will be suggested best for them
__________________
Old 5th June 2007, 13:44   #14 (permalink)
Team-BHP Moderator
navin's Avatar
Are they 306C or 306F?
__________________
Scixelsyd Etinu
Old 7th June 2007, 10:24   #15 (permalink)
noidaboy's Avatar
They are pioneer 306dvc. i will post the pic as soon as i can
__________________
Thread Tools
Single Reverse Light X-Machine Modifications & Accessories 5 12th August 2007 10:41
Normal and Reverse sub setting on HU ?! NIP Ask the Gurus 82 23rd July 2007 13:50
Reverse Lcd In Safari Jas6789 Modifications & Accessories 11 20th January 2007 20:25
Reverse Gear ramkya1 Technical Stuff 23 12th January 2006 22:27
Reverse Problem dev Shifting gears 0 28th October 2005 16:42
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
