Old 18th May 2008, 11:14   #16
Dhar's's Avatar
Thanked: 628 Times
@ Redfire
Congrats! and all the best on your DIY project. Appreciate your DIY spirit.
More pics and details please. (Amp placement, distribution block, RCA cable sub etc etc.)
Please give the source for Finoles cables in TVM.
(Last time I searched whole of Kollam and couldnt get anything more than 12ga and I had to run two cables).
I suggest that you run those cables through flexible conduit at least where the cables has a possibility of rubbing against metal (if you already haven't).
Dhar's is offline
Old 18th May 2008, 11:41   #17
Thanked: 306 Times
In the above pic
  1. Lug
  2. Spring washer
  3. Simple washer
  4. ????? (Seatbelt retanier part)
  5. ????? (Seatbelt retainer part)
  6. washer
  7. ???? (seat retainer)
If 1 is the thimble/lug it is not fully tightened kya ?
If it is loose then it might serious damage to the amp due to loose connection. As in the pic it is seriously loose
Have you scraped the paint before fitting it there.
low_bass_makker is offline
Old 18th May 2008, 14:18   #18
Bass&Trouble's Avatar
Thanked: 137 Times
Originally Posted by redfire View Post
My co-installer. Had a very hard time controlling this installer from running around the car and 'installing' various things
Looks like he was looking for a good point to ground your amp.
Originally Posted by DerAlte View Post
BTW, is "leg" related to "lug" the same way as "Gelf" is related to "Gulf"? (Apologies, please don't be offended, I'm just pulling your "lug")
Masterpiece.
Bass&Trouble is offline
Old 18th May 2008, 14:52   #19
redfire's Avatar
Thanked: 27 Times
Originally Posted by low_bass_makker View Post
tightened kya ?
Thanks LBM for pinting out this as this is a very important thing in power connection. But the connection is fine and tight. The shape of that body part and angle of the pic makes it appear loose. I have dealt with power and UPS things a lot in office and know how it will impact. I haven't scraped paint though. Have read it somewhere else too. Will do it and refit it anyway.
Available at any decent electrical shop. I got it from a shop at Saphalyam complex - Palayam. Yes, The part of cables in engine compartment are covered with flexible conduit. Waiting for remaining materials (RCA, damping etc) to come. Will send a detailed report with pics after that.
redfire is offline
Old 18th May 2008, 15:01   #20
Thanked: 137 Times
Please do it. Paint will act as an insulator between the ring terminal and the chassis. After removing the paint and re-tightening, use something like hot melt to seal all the connections to prevent the exposed car's body at that point from corrosion.
Old 20th May 2008, 22:42   #21
redfire's Avatar
Thanked: 27 Times
Changed RCAs and SW speaker wire
Hi All,
Today afternoon I got my parcel from B&T and could change RCAs to both amps and speakerwire to sub. The keen observation of installers work helped me to remove the HU block, remove both RCAs (to each amp) and run the speakerwire without any hastle. It took 2 hours to complete the job. Now I have peace of mind and can proudly say that I am running on standard cables and wires (Ichibahn RCAs and Illusion speaker wire). Here are some pics which may help to understand.
Ichibahn RCA (black) against 'Boss' RCA
Illusion speaker wire (black) with local wire
To remove HU block in Swift, take out the nut here (look through glove box)
HU block poped out
HU connections, see old blue 'Boss' RCAs
Routing of RCA
My 12v accessory light helps a lot (with magnetic base)
New banana connectors for sub box
Blau PA275 amp with new power and RCA under co-driver seat
Blau GTb1200 at boot
JBL GT5-A402 amp under driver seat
This time my co-installer was more busy, trying to plug RCAs
item for weekend - noisekill
redfire is offline
Old 20th May 2008, 23:52   #22
srijit's Avatar
Sigh. I was at a friend's house when you called :(
Looks like you got a good helper. I would probably have pestered you the whole time
srijit is offline
Old 21st May 2008, 14:03   #23
MillionSwords's Avatar
Cool - looks wonderful!
Hey redfire,
All looks cool and nice!
Cheers to your DIY spirit and successful installations.
Hope the NoiseKill comes in good too! Get some one to take pictures while you are at work!
can you post pictures of your
1. Magnetic Base 12V light and
2. Your Wireless Drill
Where did you get them and how much do they cost.
Is your drill powerful enough? [you can scrap the paint off the body using a grinding bit on this grill, do you have one?]
cheers,
MS
MillionSwords is offline
Old 21st May 2008, 17:45   #24
redfire's Avatar
Thanked: 27 Times
Completed remaining cabling and front doors damped
Hi all,
completed wiring new speaker cables from Amp to comps and also done one major step! damping the front doors. Used 20 sqf of noisekill. As someone pointed out we can use another 10sq or more if you want to stiffen it. But 20 (10 sqf each) is a decent quantity to start with for basic damping the front doors. Thanks to Srijit who came and helped me. Greenhorn - please accept my sincere apologies as I had time only today afternoon. Coming days in this week I am busy in afternoons and working this weekend. Will do the rest soon (hatchdoor is a must).
Impression - doors feel heavy as a big car. Doors closes with a more good thud. On our testride with ICE, I felt less vibrations are affected inside and an increased clarity in vocals and mid. Definitely, damping the rear doors and hatchdoor (must!) will help to improve.
GTO607Cwoofer
Front right door, doorpad removed
FR door, noisekill applied layer1
FR door, noisekill applied layer2
FL door, noisekill applied layer1
FL door, noisekill applied layer2
Finished door
View from rear
redfire is offline
Old 21st May 2008, 17:52   #25
Thanked: 137 Times
Hi redfire, thats an awesome job with the cabling and damping. cheers:
WRT your little one: Looks like he has a thing for The Doors. lol. He seems to be trying to plug in whatever he can get his hands on into it.
Old 21st May 2008, 18:00   #26
jkdas's Avatar
Thanked: 1,497 Times
Man! nice job.
Heard you were in bed ! We should have a meet soon. How about this Saturday morn.
Edit: Pricing would help others who wanna do DIY.
jkdas is offline
Old 21st May 2008, 18:01   #27
greenhorn's Avatar
Thanked: 4,910 Times
no issues mate. the pix are all i wanted.
And my apologies for not showing up at your place so far. It's been a busy week preparing for mom's transfer
besides, now i have bigger problems than rattling door panels.The rears sound very muddy :( started saving up for my subwoofer fund
greenhorn is offline
Old 21st May 2008, 18:05   #28
redfire's Avatar
Thanked: 27 Times
Originally Posted by MillionSwords View Post
Hey redfire,
Thanks MS, see the noisekill installation.
cheers,
MS
As you can guess, from US when I visited last year. Bought from a Wallmart. Some 7 and 13$ respectively IIRC. The torch is extremely good. Drill is OK for our general applications. I have even drilled wall to install wallplugs. I think I can use them to scrap paint wit grinding bit.
Thanks Sir, with your great help and sending goods ontime made it easy for me.
Hehe, since he cant get into the car he concentrated on doors.
Pic of my 12V torch
redfire is offline
Old 21st May 2008, 18:34   #29
Thanked: 306 Times
I liked your DIY and your torch also
Keep up the good work.
Old 21st May 2008, 18:41   #30
redfire's Avatar
Thanked: 27 Times
Many thanks LBM. Actually it was your detailed posts and charts regarding cables I reffered a lot for ths DIY. Now next thing is to tune the system properly with new accessories in place. All suggestions welcome .
redfire is offline
